Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Washer will not fill up or use cold water
By traceylore on Aug 19, 2009
washer will not use or fill up with cold water and hot water won't wont rinse
Solution #1
posted on Aug 19, 2009
Not Rated)
canbruce75
Rank: Guru  Washers & Dryers  Expert
Rating: 92%, 818 votes
Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are clean of rust or debris. The solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Are there any new washing machines made that still have direct drive. That means that the agitator... (More)
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
Washer is not working when any cycle (excluding cleaning and drain/spin) is chose. It happened a... (More)
Answer
won't drain or spin, stalls
Answer
I turn on the washer and then choose my setting- however, once I push start, the machine turns off. ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
