Hi I have a sony KDP-57XBR2 HD Projection television set and the problem is that after a few minutes of use the screen gets red. The image is not distorted, but the red becomes more intense until the whole picture is red. If the tv is then turned off and a few minutes passes the picture will be fine until the red cycle starts over again. Any idea where the problem may be located with this??? thanks for any help!
I had the same problem in blue. I took the right front speaker cover off (pops off) and the access panel on the right side 2 - 4 screws. In the upper right corner is a black plastic box with 2 rows of 3 adjustment screws. All I did was turn one of the "screen" screws (not the "focus" screws). Hope this helps. May only be a temporary fix, but good luck...
ok,your porblem is very simple,reheat or resolder the main board your tv.
