Dell 1600n All-In-One Laser Printer
Problem for Dell 1600n All-In-One Laser Printer
Frequent paper jams on a Dell 1600n AIO
By support964 on Aug 19, 2009
frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open up back to clear paper.
Solution #1
posted on Aug 19, 2009
Not Rated)
GeOrGeEtUk
Rank: Wiz
Rating: 82%, 61 votes
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Thanks
Was this helpful?
Yes
No
Solution #2
Not Rated)
ThiruBulls
Rank: Wiz
Rating: 83%, 58 votes
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing.
Was this helpful?
Yes
No
Popular Solutions for Dell 1600n All-In-One Laser
Questions and Unsolved Problems for Dell 1600n All-In-One Laser
Do you recommend Dell 1600n All-In-One Laser Printer?
Answer
Answer
my laser printer gives message open heat error how can I fix
Answer
Had a document jam on Dell 1600n MFP. Cleared jam, but I can't get [Document Jam] to go away on... (More)
Answer
my Dell 1600n Laser Printer gives message Open Heat Error
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , OH
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
