Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
GE DW beeps and won't start
My DW internal detergent cup won't close correctly. Once I get it to close, I close the outer door, move the 'loc' latch over to the right but it doesn't stay, instead the DW starts beeping continuously and won't start... please help
    Novelist:
  • 148 Answers
Look for parts for the unit. you indicate its defective. if you can't replace the parts yourself, then you will need to get a repairman in for that.
be careful regarding the cost. some home repairs cost more than a new unit, so if its a base level unit (low cost) you might want to consider a new unit. you can also save money by taking the unit in to the service center. call first and work out a deal in advance. this only makes sense if you have a lot of free time and do not value you time very much.
good luck
mark
Posted on Dec 28, 2007
How do I get my ge dishwasher to run? the lights
Hello there and welcome to fixya
If electrical power is available to the dishwasher but the appliance doesn't run, the problem is likely to be a defective door switch, timer, or selector switch. Make sure to turn off the power to the dishwasher before attempting any repairs
To solve a door switch problem, you may be able to adjust the door latch's strike slightly, using a screwdriver
then make sure the door closes securly, if this doesent work
please check the timer as follows
Dishwasher timer concerns can be classified into two general categories: the timer cannot be advanced manually and appears to be stuck or intermittent automatic timer advancement.
1. The timer dial cannot be advanced manually and appears to be stuck. Stuck timers are generally caused by objects that prevent the detergent cup from opening, or by a sticky substance between the timer dial and the control panel.
  • Objects that prevent the detergent cup from opening: If your timer will not advance, open the dishwasher door and check for items that may be blocking the detergent cup.
    Also, check the detergent cup:
    • It should be fully closed at the start of a cycle.
    • It should be fully open at the end of the cycle.
    • Almost fully open between main wash and final rinse.
    If it is in any other position, try to open or close the cup while at the same time rotating the timer. This should free it up. To prevent a reoccurrence, make sure nothing blocks operation of the detergent cup when the dishwasher door is closed and operating.
  • Sticky substances like orange juice that get between the timer knob and the front of the control panel on some models will bond the timer knob to the control panel. If you have this condition, it will be virtually impossible to rotate the timer knob while gently pressing the knob in toward the dishwasher. It will rotate normally if the knob is gently pulled away from the dishwasher while rotating the knob.
    This problem can be solved by gently pulling the knob away from the control panel and cleaning behind the knob with a damp cloth. Do not use excessive force because the knob is attached to the control panel on models affected by this problem. If this operation cannot be performed, service should be contacted to repair the problem.
2. Intermittent automatic timer advancement. This can be described as the timer can be advanced manually, but it does not advance automatically in spots for up to 30 minutes.
  • This is almost always a normal condition and always occurs on models with a "Delay Start" feature.
    Delay start timers increment or advance a couple of degrees once every minute or so during most of the cycle. However, during certain parts of the cycle they increment once every 30 minutes. This gives the dishwasher time to do the job of cleaning your dishes. The long increment times occur during "Delay Start", "Hot Start", "Normal Wash" and "Dry" cycles.
    The timer will not move at all during these delay periods. This is normal operation and service is not needed. If you notice delay times substantially longer than 30 minutes, replace the timer
  • Also ensue that you are getting adequate water pressure and the unit is getting water inside and that the water is at the right temperature 140 is the min. for most units
  • Please check the above and let me know what you have found so i can continue to help there is a lot of things to check but these that i have provided are the most common thing that need to be checked first ok?
  • Best regards Mike
Aug 21, 2011 | GE Dishwashers
Detergent dispenser problem
Is it new? Even if it was or wasn't, I strongly feel that you probably didn't set something properly. Read the manual it came with, particularly the troubleshooting section. Not a big problem. Let me know how it goes. :)
Jun 29, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
The detergent cup lid stopped closing on my old GE Model # GSD600G-0l dishwasher. Tried turning the dial clockwise to the Off position, but it won't work.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
May 10, 2011 | GE Dishwashers
Dryer is running, but rotating very slowly. it generates heat, but makes a very loud noise. it's a GE Adora Dryer
Instructions
1. Wait approximately 90 seconds for the light to turn off if the "Start/Reset" indicator light flashes. Press the "Start/Reset" button to restart the wash cycle.
2. Close the dishwasher door and move the latch to the locked position if you hear a beep once every 30 seconds when the dishwasher should be operating. The dishwasher will not operate if the door is open.
3. Turn on the hot water faucet and feel the water to check if it is hot. Wait for the water to warm up before running the dishwasher if the water is not hot. Check that you have proper water pressure and wait for the pressure to return to normal if it is low. Your dishes may not come out clean if the water is not the correct temperature or if you have low water pressure.
4. Move the dishes on the racks so that they do not block the detergent dispenser or washer arms on the bottom of the machine. The dishes will not come out clean if they block the detergent dispenser or the washer arms.
5. Load the proper amount of detergent in the dishwasher if you find spots or film form on your glasses. If you have hard water, use a rinsing product such as Jet-Dry in the dishwasher to clean the spots or film. If the problem persists, wash smaller loads of dishes.
6. Add only automatic dishwasher detergent to the dishwasher if you find excessive suds in the tub after running a cycle. Measure out the proper amount of detergent.
7. Press the "Heated Dry," "Hot Start," "Hot Wash" and "Added Heat" buttons, if you find that your dishes are not fully dry after a wash cycle completes.
8. Press and hold the "Heated Dry" button on the dishwasher for approximately three seconds if the control pad does not respond to button presses. This is the child lock that prevents unwanted use of the dishwasher.
Feb 24, 2011 | GE Dryers
Hello. I have a GE Potscrubber 600 dishwasher. The soap dispenser will not close. This seems to be a common problem. Any help would be great, thank you.
Main detergent cup won't close on GE Potscrubber 700 GSD700.A workaround is to add the additional detergent with rinse aid 18 minutes intothe wash cycle. To repair, switch off power through circuit breaker. Set timerknob to 12 o'clock. If the detergent cup lever spring opens the cup after it isclosed, remove screws on panel that holds detergent cup and remove the panel upand out of door. Remove timer cover by moving it right and pulling up to exposetimer, see photo 1. _1909.jpg If a spring is loose, it can be reattached as follows.Remove two screws that hold timer, then remove timer. Do not remove timer knobfrom front of GSD700 because knob is designed for removal from rear of panel,after the timer is out. If spring attachment point broke off, reinforce it withepoxy (JBKwik), see gray cone upper right of center in photo 2. _1910.jpg After epoxy cures, drill and tap a hole for a metric 3 - 0.5mm-8mm screw (4-40 may also work). Install spring between new screw anddispenser linkage and tighten screw, see photo 3. _1911.jpg Install timer, jiggle knob so it engages timer and securetimer with two screws. Pull dispenser lever down to make sure it moves andsprings back. Replace round switch and cover. Install white cover with leverextended through it. Install cover screws, close soap door, and rotate timer,soap door should open after about 90 degrees of rotation followed by rinse aidactuation.
Oct 24, 2010 | GE Dishwashers
The detergent cup will not close on GE GSD5120 dishwasher
they get warped and the latch gets waren out . replace the cup assy . this is a common repair . mm
Dec 08, 2009 | GE 24 in. GSD5120 Built-in Dishwasher
Rinse cycle continues after the door is open
There is a door interlock within the door assembly. I believe it's mechanically stuck rather than needing replacing.
Turn off & unplug. You should be able to get to the internals of the door via screws around the edge. The interlock will be very close to the handle catch. Check operation by inserting a dummy catch to lock onto it.
If it is stuck solid - order a replacement.
Aug 04, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Soap dispenser does not open during wash cycle
  • Hi,
    please try this...
    imer:
            On mechanical set ups the timer is attached to the detergent cup by an actuator arm. This arm is usually plastic, and if it is broken or otherwise defective then the detergent cup wont be opened. Check the linkage to make sure it is functioning correctly.
    Bi-metal switch or wax motor:
            The bi-metal switch is simply a very precise device that warps, bends, or otherwise deforms when power is supplied to it. The timer operates the bi-metal switch, which inside the dishwasher door. Then the switch is supplied with power and it is working properly, the bi-metal switch deforms away from the latch holding the detergent cup closed and the cup opens dumping the detergent into the washer.
            Some dishwashers have this switch wired through the motor power feed or the heating element. If they are defective then the detergent door will not operate correctly. If the switch itself is defective then you will need to replace it. Another type of mechanism is a wax motor. Wax motors are sealed units filled with wax and found in newer dishwashers and work by heating the wax and forcing up a piston which in turn mechanically opens the detergent cup door. This type of device is also controlled by the timer.
    Detergent cup:
            Sometimes the detergent cup becomes built up with old detergent that prevents it from opening correctly. It's usually a simple fix to clean this out. If cleaning it is impossible then you may need to replace the cup assembly.
    please rate my suggestion..
Apr 14, 2009 | Dishwashers
My GE Washer Door Won't Lock
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Feb 19, 2009 | GE WBVH6240F Front Load Washer
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
188 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
