Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
Flashing My Hdtv starts up fine, however when on it randomly starts to pop and flash. How can i stop this or how much would it be to get this repaired.
    Problem Solver:
  • 8 Answers
Pop and flash meaning that the picture turns on and off? Many people's tv eventually just turns off all together. Furthermore, if you notice a crackling sound, it isn't just the sound of the tv turning off, it is the sound of sparks and flames emitting from the back of the television. Take notice of this as it is a fire hazzard. If you do notice this, please report the problem to the consumer product safety commision. I beleieve this common problem with large sparks and flames warrants a recall.
https://www.cpsc.gov/cgibin/incident.aspx
Posted on Feb 07, 2008
SOURCE:
Will the alarm kill switch on a 96 gti golf be active if no led lights are flashing
have a look at the earth lead from the body of the car to engine to see if this is corroded an easy test would be to put a jump lead from negative of battery to anywhere on engine gearbox if this doesn't solve issue check the lead going to starter motor for corrosion and tightness
Apr 03, 2014 | 1996 Volkswagen Golf
When starting computer screen immediately starts flashing colors. Nothing else. Then stops. And glitches randomly.
Turn off your pc and connect another monitor. If the external monitor works fine then the screen cable is damaged or your laptop's LCD needs replacement.
Jan 20, 2013 | Computers & Internet
I have a 1999 Oldsmobile allero and I am having trouble with the theft lock, randomly my car will not start and then my security light will start flashing and I have to wait for about 15 min for the light...
You are experiencing GM passlock security system. Yours is starting to fail. When the system gets old it fails to communicate with all the parts of the system that need it. When the communication is broken, the car goes into anti theft mode and and turns off the starter and/or the injectors. After ten minutes it trys to connect the communication again, this is why it will work after a while. Go to this link, it has a ton of info and some ways to bypass this system so it will never happen again.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jul 26, 2011 | 1999 Oldsmobile Alero
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Flashing black and white vertical lines
Vertical lines in the display indicate a failing screen. New screens are expensive and not worth the labor and parts charges to repair it. It's new monitor time.
Jul 28, 2017 | Samsung LTN1535 15 in. HD-Ready LCD...
Flashing red center light
With most flat panel TVs, the TV turn itself OFF when it has a fail electronic part and the red light starts flashing. They call this "Protection Mode". The flashing red light should be a error trouble code.
But, it's weird that everything is working and the red light is flashing. Since you just recently bought the TV, I would get it check out while it's still under warranty. Better safe, than sorry.
Jul 20, 2009 | LG 26LX1D 26 in. LCD HDTV
My husband was watching the television and it just made like a small pop sound then the little blue power light started flashing and the two red lights that say temp and lamp started flashing, what is this...
Lamp seems popped and requires replacement.
Lamp replacement procedure is written on user manual of TV.
Let me know model number of TV if you need user manual copy.
May 13, 2009 | Hitachi 65S500 65" HDTV-Ready Rear...
I have a 6 year old Samsung PCJ522R 52" TV.
It sounds like at least one of 3 "IHVT",s popped. in short, a "IHVT" is a high voltage transformer. It will have to be replaced along with any other parts that were damaged in the process.
They do produce a strong odor when they pop!!
It is repairable but at a price. there is a good chance that parts will have to be ordered.
you might consider buying a new LCD HDTV instead of fixing this one.
Dec 27, 2007 | Samsung PCJ522R 52" Rear Projection...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
55 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
