Question about PSB Alpha Sub Zero Subwoofer
No LED light on PSB Alpha Subzero-i and keeps blowing fuses.
I get no green light when I plug in and turn on the sub. Used the replacement fuse - no cigar. The sub uses 1.6a fuses, went to hardware store and bought 2 however they were only 1.5a (all they had), both blew instantly upon turning the power on.
Help.
Thanks
Winston
  • 2 more comments
  • Anonymous Jul 10, 2008
  • Anonymous Dec 05, 2008
    I have the same problem. After a couple of years, the sub was not working. The fuse had blown. I replaced it with the supplied fuse, which blew right away as soon as I powered up the unit.
  • whittingtom May 04, 2009
    sub do not wook keep blowing fuses
  • atomboer965 May 11, 2010
    I had a similar problem with my PSB subzero 5i subwoofer. I took it to our local authorised dealer and they replaced a circuit board. They say it could have been a power surge that could have been the problem. It is playing fine now. Great to have it back, it makes such a difference.
Go to a 2 amp fuse. There's obviously too much juice for a 1.6 amp fuse to handle, so graduate in small increments the load capacity of the fuse. After replacing, slowly increase the volume to where the source material is at a comfort level, and see if it can handle the juice.
Posted on Sep 22, 2008
Others have had similar problems with the amp on this model. There is probably a circuit design error which causes some components to blow and as far as I've read, fixing it (or replacing the fuse) won't make the problem go away for long. Try contacting PSB or the retailer.
Posted on Jan 06, 2008
Brack lights wont light up on my 1988 ford ranger we keep blowing fuse and put in new brake switch
If you keep blowing the brake fuse than you have a short in the system. Unplug the brake switch. Install a new fuse. If it did not blow than the problem is after the brake switch. Next unplug the turn signal switch, then plug the stop light switch back in and press the brake pedal. Did the fuse blow. If not than the wiring is good in between the two switches. With the turn signal switch disconnected use a jumper wire in between the light green wire (power from the brake switch) and the orange with light blue wire (power to the right brake lamp). If the fuse blows than there is a short in the right side brake circuit between the plug in and the rear socket assembly. If the fuse does not blow than jump from the light green wire to the Light green with orange wire (power to the left brake lamp). If the fuse blows than the problem is in the left hand brake wiring circuit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 04, 2013 | Cars & Trucks
Fuse replacement
The fuse is integrated in hte AC socket. You'll need a small screw driver to pry up the part that talks about the power requirements. Check the online manuals for more details.
Aug 24, 2013 | PSB Alpha Sub Zero Subwoofer
KLH ASW8 Powered subwoofer keeps blowing 3A-250V fuses
The transistors at the output stage of the sub amplifier circuit might be shorted so each time you power on, the circuit draws a very high amount of current which causes the fuse to blow. It's definitely a problem with the circuit so using a higher current rated fuse would probably just result in damaging the amp even more. You should ask a qualified electronics technician to take a look at it. I hope you can fix it.
Oct 17, 2012 | KLH ASW8100 Subwoofer
I have no green power light on my subsonic 5i which screws do i remove to replace a fuse inside
Make sure you the plug eorks before you do anything. Plug in a lamp or something. The fuse is inside where you plug the input.
Sep 01, 2010 | PSB Alpha Sub Zero Subwoofer
Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
LED Light green but no sound.
disconnect all power cables first then short between G&P G&R try again with only one speaker at a time.
Aug 21, 2007 | Alpine MRV-T707 Car Audio Amplifier
PSB Alpha Sub Zero Subwoofer Logo
1,644 people viewed this question
Top PSB Audio Players & Recorders Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Terry Weaver
Terry Weaver
Are you a PSB Audio Player and Recorder Expert? Answer questions, earn points and help others
