1993 Chevrolet K1500 Logo
Posted on Aug 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1993 chevy 1500 4x4 pickup no power to front actuator
Replaced 4x4 module switch @ transfer case. now has power into & out of switch when transfer case is engaged but still no power @ actuator
Anonymous
Level 2:
  • Expert 132 Answers
  • Posted on Aug 27, 2009
Anonymous
Expert
Level 2:
Answers
132
Questions
Helped
63985
Points
362
Check all wire conections also replace the actuator on the front axle but check for power there first if you have power replace that switch as well .
2helpful
2answers
02 Yukon keeps blowing a fuse even when the switch is unplugged on the 4x4
There is an actuator motor located on the transfer case. It selects range; hi neutral and lo and engages the front differential. There is a second clutch actuator motor on the front differential that engages the front wheel hubs.
You will need to disconnect both motors to eliminate electronics. It could also be you have an abraided wire to either the transfer case or the front differential. If unplugging both actuators doesnt stop fuse blow, you will need to test for signal or power to ground shorts.
Free (with ads) schematics are available using the "carmin std" app.
Four wheel drive won't engage replaced the wheel speed sensor and the actuator 2002 GMC Sierra 1500 4.v6 w engine code checked the fuse and to see if power is getting to the actuator
Your best bet , take it to a qualified repair shop , before you replace more part's that arn't needed . Did you check to see if any DTC'S - diagnostic trouble code's are stored in the transfercase control module . Which transfer case does it have ? How many buttons on the instrument panel 4X4 switch ?
The NVG 236/246 transfer case features a 4 button shift control switch located on the instrument panel.
Do you know what a DTC is ?
DTC C0367
The front axle control circuit consists of an electric motor actuator which engages and disengages the front axle. The front axle actuator's motor consists of a Permanent Magnetic (PM) motor, a worm gear controlled plunger, a front axle switch and an electronic control circuit all within the actuator assembly.
The front axle actuator has four circuits connected to it, a front axle feed circuit, front axle ground circuit, front axle control circuit, and a front axle switch circuit.
Whenever a shift to AUTO 4WD, 4HI, or 4LO is requested, the automatic transfer case control module engages the front axle by grounding the front axle control circuit through a current limiting driver.
This DTC detects a shorted actuator, or a short to 12 V on the Front Axle Control Circuit.
Your vehicle can set a number of them .
DTC B2725
DTC C0300
DTC C0305
DTC C0308
DTC C0309
DTC C0310
DTC C0315
DTC C0323
DTC C0324
DTC C0327
DTC C0362
DTC C0367
DTC C0374
DTC C0376
DTC C0387
DTC C0550
DTC C0611
Without a professional scan tool an factory service repair info. you really shouldn't be trying anything , take it to a qualified repair shop.
The NVG 263 transfer case features a three button shift control switch located on the instrument panel.
New Venture Gear 263 Selectable Two Speed Transfer Case
The NVG 263 transfer case features a three button shift control switch located on the instrument panel. When the vehicle has the ignition key in the RUN position, the transfer case shift control module starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/gear position. At a single press of the transfer case shift control switch, the lamp of the new desired position will begin flashing to inform the driver that the transfer case shift control module has received the request for a new mode/gear position. The lamp will continue to flash until all shifting criteria has been met and the new mode/gear position has been reached (or has been engaged). Once the new mode/gear position is fully active, the switch indicator lamp for the new position will remain ON constantly.
1helpful
I can here the tranfercase locking in but its not turning front tires at all ?
Your vehicle had option of two different 4x4 systems ,
The NVG 263 transfer case provides the driver with 3 manual mode/gear positions:
• 2HI - 2 Wheel Drive high range
• 4HI - 4 Wheel Drive high range
• 4LO - 4 Wheel Drive low range
OR
The NVG 236/246 transfer case features a 4 button shift control switch located on the instrument panel. When the vehicle has the ignition key in the RUN position, the transfer case shift control module starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/gear position. At a single press of the transfer case shift control switch, the lamp of the new desired position will begin flashing to inform the driver that the transfer case shift control module has received the request for a new mode/gear position. The lamp will continue to flash until all shifting criteria has been met and the new mode/gear position has been reached, or has been engaged. Once the new mode/gear position is fully active, the switch indicator lamp for the new position will remain ON constantly.
If there are problems with electronic part of the systems the shift control switch light will flash warning of a problem , If no lights you have a mechanical problem in the transfer case itself .
The front axle control circuit consists of an electric motor actuator which engages and disengages the front axle. The front axle actuator motor consists of a Permanent Magnetic (PM) motor, a worm gear controlled plunger, a front axle switch and an electronic control circuit all within the actuator assembly.
The front axle actuator has four circuits connected to it, a front axle feed circuit, front axle ground circuit, front axle control circuit and a front axle switch circuit.
Whenever a shift to AUTO 4WD, 4HI, or 4LO is requested, the transfer case shift control module engages the front axle by grounding the front axle control circuit through a current limiting driver. Test Description
The numbers below refer to the step numbers on the diagnostic table.
Tests the electrical function of the front axle actuator. Helps determine between mechanical and electrical malfunctions.
Tests for proper power and ground at the front axle actuator.
Tests the operation of the front axle control circuit.
Helps determine if the transfer case shift control module is able to monitor the front axle switch.
Tests the front axle switch circuit for an open or high resistance.
Measures the voltage between the front axle feed circuit and ground.
Tests the front axle control circuit for an open or high resistance.
Inspects the front axle for a mechanical malfunction.
Tests for open in the front axle feed circuit.
My isuzu rodeo pickup four weel drive not working
You have a transfer case actuator and a transfer case module,The easiest one to inspect for bad connection is the the transfer case actuator,you will need a 12 volt test light and check for power,what year do you have and do you have automatic transmission or manual
Hello, I have a 1992 Chevy K1500 pickup, 5 speed, 4WD. I just replaced thermal 4WD actuator for the front axle with the new motor type and with a new wiring harness. Always goes into 4WD right away now....
Sounds like you have the actuator switch set to tight. You might want to try to adjust the switch so it has a little room between the switch and the shifter. Hope this helps.
1helpful
1993 chevy pickup 2500 4 wd. 4 wheel drive will not engage. replaced actuator. still did not engage. replaced 4wd switch on transfer case. still does not engage. the 4wd indicator light comes on but it...
physically watch the actuator and have someone else activiate it. If it moves like it's supposed to...you could have a broke axle, third member or even the locking clips on one of the front hubs...
I have a 93 chevy 2500 4x4 truck. It will not go into 4 wheel drive. The thermal actuator has been replaced.
4wd fuse is good. Check the switch on top of the transfer case. This is what sends power to the actuator.
3helpful
01 Chevy Silverado 4 X 4 not working. 4WD light
Having the same exact problem but with my 1999 escalade. Thought it was the actuator bought a new one installed it transfer case would engage but front end wouldnt lock. Took it out of housing left it plugged in got a friend to go through all the 4wd for me and the plunger never moved out the actuator. Checked my wiring harness which is a four prong ann it had one hot prong like it is suppose to. Traced wires even replaced dash switch same problem. Taking it to local dealership tom to have it checked for codes. I was told it could be the transfercase actuator even though its workin that actuator is what sends power to the front to engage the actuator to lock the differential.
7helpful
98 Chevy S10 4wd drive will not engage when button is pushed
your problem sounds like either the transfer case control module located where you hear the clicking sound, or the actuator on the transfer case itself.
try unplugging the transfer case control module and then plug it back in, try engaging 4wd again (make sure your in neutral, coasting at 1-2 mph might help as well) if it still doesn't work check the actuator itself to see if the actuator is trying to engage. if the actuator is trying to engage but doesn't, take the actuator out and check it for wear or damage. if the actuator seems fine and it responds to the buttons when pressed i'd go after the transfer case control module as the culprit. ran into that a few times on those s-10's. 3 out of 4 that i've seen were fixed with a new tccm. 1 of the 4 needed an actuator, check your local junk yard for a working tccm or actuator.
hope this helps!
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
