No sound have the equipment plugged in but we have no sound
  • 2 more comments
  • kstcd Dec 09, 2007
    I have hooked up my subwoofer as detailed in the manual, checked and recheked all set configs and wiring. Still no sound coming from sub speaker
  • MswLori Dec 21, 2007
    I have a yamaha ysp 1 system 4 two yrs and all of the sudden I can no longer get any sound out of it. Preceding the lack of sound, for about a month there was a loud popping and sqealing sound when one turned it on and then one day I had no sound.
  • Anonymous Mar 21, 2008
    Worked fine last time we used it, just got it out of it's box and turned it on and no sound. Tried new batteries but still no sound. Everything is plugged in correctly.
  • topcon1 Dec 14, 2008
    My system emits a loud hissing & popping sound when turned on. If I turn it on & off a few times sometimes it will turn on but be silent, no matter the input selected. Please help.
    Scholar:
  • 51 Answers
If you have a wireless speaker system, chances are the transmitter/receiver parts have drifted off frequency (very common with consumer grade equipment which is designed very cheap since it only needs to work at one frequency). This problem might be fixed but you have to go inside and adjust it, if it is adjustable. More likely, you'll have to replace the entire system. If they are NOT wireless, try turning the volume control back and forth like 100 times. If the control has become dirty, this operation will clean it and hopefully restore operation. Also twist all plugs in their jacks, remove and reinsert them several times to clean those contacts, maybe even spray a quick shot of WD-40 into the jacks beforehand. My suggestion is to never buy a wireless speaker system, as you're left with perfectly good (but useless) speakers when the electronics fail. Sort of like buying a TV with a built-in DVD player. The DVD will last 3 years max while the TV usually lasts much longer. If you're buying fancy speaker electronics, go with Bose, Sony. etc. You get what you pay for.
Posted on Dec 27, 2008
SOURCE:
Low sound coming from speakers, volume needs to be at 55 in order to hear anything. how can i fix it
Try using a "cheater" plug at the electrical outlet to the wall for your front end equipment. It does a "ground lift". If your equipment plug is 3-prong, a cheater plug will make it a 2-prong.
Oct 03, 2016 | Paradigm Audio Players & Recorders
When using headphones sound only coming out of one ear
Could be a broken wire or faulty plug/socket. Try another pair and if the problem is the same with those, the fault lies with the equipment you are plugged into. If the faulty headphones work fine in another piece of equipment then again the original equipment has a fault. If the original headphones have the same fault in another piece of equipment, then they are faulty. It is all about elimination. Once you find the faulty piece (headphones or equipment), then you can start to try and trace the cause.
Feb 10, 2016 | Televison & Video
Trying to get the sound system to work for my toshiba 32C110U
Modern TVs have digital only sound out. Coaxial and optical. You want to make sure they are engaged. You have to go to "sound" or "setup" menu and choose "audio out streaming". It might be: PCM, Dolby digital, Analog(if your set has pair of RCA plugs, as an"audio out"). Also: if your set has only Coax(orange) or optical, your receiver must be equipped with that.
Dec 10, 2011 | Toshiba Televison & Video
I have a 3M STV Digital 6 surround sound system. The receiver is emitting a loud buzz the minute I plug it in. The only way to eliminate the buzz is to unplug the power cord. Any suggestions to remedy this...
A loud hum could be caused by an Earth loop. This is caused by connecting various stereo equipment into different mains power outlets.
To overcome this problem, use a power board and plug all the stereo equipment into this single power board.
May 27, 2011 | Audio Players & Recorders
I can't figure out where to plug it in
Any sound system that has a mic in will accept this microphone although you may need a 3.5 to 2.5 or 3.5 to 1/4" stereo adaptor depending on the equipment your plugging the microphone into.
Jun 20, 2010 | Philips PH62080 Uni-Directional Microphone...
Install speaker in dell pc mine has no sound Logitech L S 11
make sure the mute box has no check mark in it......make sure your plug (jack) in the rear or front of the computer that goes to the speakers are plugged into the right place.....go into the control panel and go to sound settings make sure the computer is set up for the right kind of equipment you are using.......
Dec 07, 2009 | Dell Computers & Internet
Motor trend 2400 watt inverter has 147 VAC from both hot and Neut
Assuming you are testing alternating current and not direct current that sounds quite normal. Plug with confidence. You are using equipment designed for 110v-120v and you're getting 113.8v where it matters most. Higher voltage to ground is nothing unusual, that's just how this inverter is designed.
Jan 10, 2009 | TREND Motor Trend Inverter 2400 Watt ...
Set-up problem with sound and speakers
I sent this TX-SR605 system to an authorized dealer for repair. It seems like it is a very simply problem - the internal set-up mic jacket closed circuit, so the system think the set-up mic is always plugged in (even when physically unplugged it, the system still detect plugged in). And it enters the automatic speaker setup and never quit.
Now I have the receiver back home and tested it. Everything worked O.K. now. It is a pity that this new-bought equipment (just one month) need repair for just a small action of plug in a mic ( I swear I plugged it in very tenderly). It is shame for such a unreliable performance happened on brand name like ONKYO. How can you be confident for an equipment failure in one month.
Dec 25, 2007 | Onkyo TX-SR605 Receiver
578 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
