Question about Maytag Neptune MCE8000AY Electric Dryer
Problem with upper cabinent of Maytag Drying Center.
I have the Maytag Neptune Drying Center and have a problem. The lower unit works fine, but the upper cabinet is not working right. All the conrols light up but the unit is not drying clothes. The display came up with a PF notice (power failure). We have restarted it and the timer counts down the time, but the unit is not working. Help.
  • 2 more comments
  • Anonymous May 28, 2008
    I have the same problem. The display states PF and clicks when you hit the on button. Unplugging the unit did not help. Maybe it is the motherboard. If you have severe weather, how do you protect this in the future? The fuse box I would think would be enough to protect it. Please help.
  • Anonymous Jul 09, 2008
    Ihave put a new relay board in now the bottom dryer works but the blower motor for the upper unit will not come on.Is there a a fuse that works that motor and where is it
  • Anonymous Dec 12, 2008
    The bottom unit works fine, but the upper cabinet wont heat up and dry the clothes. It goes thru the entire cycle, but never gets warm or steams or dries the clothes. I assumed that the upper unit used the heating function thru the bottom unit because there isnt a separate heating element or motor or blower or anything for the upper cabinet.
  • genesaudio Apr 30, 2009
    I'm having a totally different problem with my dryer. The indicator lights for the lower dryer unit have stopped working. The only lights that work are the time. I went online to find a parts list but it doesn't list the lights. Are they part of the console w/membrane pad?
Mine did same thing within warranty. There is a motherboard problem in them that is cause by power surge during an eletrical storm. First try unplugging for 10 minutes and see if it resets. If that doesn't work, you need to have the motherboard replaced that runs the unit.
Repair man took the front off my unit and replaced entire motherboard. He stated that it was a known issue with that motherboard. I have had no problems since my motherboard was replaced 18 months ago.
Posted on Mar 27, 2008
The lower portion of my Neptune Drying Center does not get hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 31, 2011 | Maytag Neptune MCE8000AY Electric Dryer
I need to take off the lower front of the dryer unit to gain access to the igniter
Just remove the control panel. The screws are accessible from the drying cabinet. There will be 5 screws holding the bottom panel in place from the top. It tilts out then up off the clips.
Sep 08, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Maytag MCE8000AZW Neptune Drying Center. Display
my bottom dryer the light dont come on or when i press start it wont start all i hear is a click...any solutions?
Jan 31, 2010 | Maytag Dryers
MCG8000AWW Neptune Drying Center initially has heat, then not
hey u burned the ingniter with all that lint, so just buy it around $100 , replace it and back in business.
Feb 28, 2009 | Maytag MDG21PD Electric Commercial Dryer
Maytag mce8000ayw start button won't work
your starter button needs checked at least but most likely replacded
Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
818 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
