Same problem as this one previously posted: After a power outage, my InFocus Screenplay 61md10 HDTV had a dark screen and was unresponsive to remote commands or the control buttons on the front of the display. The blue lights on the control buttons on the front of the display come on, but is otherwise unresponsive. Tried removing plug and powering up again, but the same symptoms re-occurred.
The answer was to access the service menu and reset the TV.
Can anyone help with how to access the service menu on this model to reset the TV?
With a non responsive remote that would be inpossiable you need to replace the control board inside around $100 bucks then you can have a good tv again but to get to the service menu your controll has to be working.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Testimonial: "I'll try the fix. Thanks for the info!"
As a genral rule yes if you replace the control interface that will fix the frount panel and remote infered unit as well. the service menu codes for this set is only for a qualified service engineer as you can seriouly put this thing further into a repair stack and cost you more money to fix so I cannot devoldge. But you can factory reset from the menu your unplug the unit. replace the control unit you be glad you did! Please rate/review thanks
Infocus 61md10 nopawer blu eld no
SOURCE: InFocus ScreenPlay Projection HDTV does not turn on
I have the same problem, has anyone fixed this issue yet? I have no way to access any menus because the screen doesnt turn on, I also cant hear the fan turn on
thanks
Sorry, the blue controls (on/off, channeland volume )on the front of the TV don't work either. Will the control board fix both problems? Then will I still have to get into the service menu to reset the TV? How do you get inj to the service menu if I replace the control board? I don't recall any menu selection for that feature (I'm sure to keep from accidental access). Thanks for the first reply.
