Question about Proview PL926WBi 19" LCD Monitor
Screen goes dark
I have a proview fv926w monitor when i try to power up it comes on for about 5 sec. look king of pink color then goes black.
    Sergeant:
    Champion:
  • 270 Answers
It indictes problem with ur crt tube in monitir
Posted on Dec 02, 2007
SOURCE:
ProView 19" Flat Screen Monitor comes on with
The dark or black picture is caused by a failure in the back light power supply. The problem can be corrected by replacing a few parts called capacitors on the board. Replacing them will require a little soldering but anyone can do it. Here is a link to a page that shows what needs to be replaced.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 17, 2011 | Proview PL926WBi 19" LCD Monitor
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor goes black after about 7 to 10 seconds. I can turn power off and then back on and it will be ok for about 10 seconds before it goes black again.
Check whether the cable from the system to the screen is connected properly and there is not loose contact. Also take the system into BIOS and check whether the same issue is happening in the BIOS screen.Try a factory reset on the screen by pressing the OSD button on the screen.
Switchoff the screen and disconnect all teh cables including the powe cable and press and hold the power button for around 40 sec and now reconnect the cables and try to power up the screen
Jan 04, 2011 | Proview PL926WBi 19" LCD Monitor
Proview monitor PL926WSi Screen goes out after about 5 seconds
Hello Joe,
A red or pink coloration on the screen indicates bad backlight bulbs. They are just like standard fluorescent bulbs just much smaller. When they start failing they light up with a pink color and that will make the screen look pink or red. You can change them but it may not be worth the trouble. You can do a Google search for compact fluorescent tubes and check prices.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Oct 18, 2009 | Computers & Internet
Computer Monitor Goes Blank
Pink tink = bad LCD Inverter (aka backlight) thats what you will need to replace :)
Jun 26, 2009 | Proview PL926WBi 19" LCD Monitor
Proview monitor won't keep the screen on
bzinbby1, Hi, I think I know what's wrong. In fact I already know what's wrong! But I want you to do one test to let me know how bad it really is! Here is the test. I want you to reconnect your Proview to an already fully booted "KNOWN GOOD" pc with WIN DESKTOP showing. Then and only then power up the Proview and hold a good, bright flashlight 2 inches from the lcd screen after the screen goes to BLACK! Even though the screen appears BLACK, can you still see the WIN Desktop if you hold the flashlight at different angles???? Get back to me with results of test. I will then tell you what options are open to you as a consumer whose screen is now dark and lifeless. I'm louie12fix on fixya or [email protected] aol.com
Apr 16, 2009 | Proview PL913B 19" Flat Panel LCD Monitor
Streaks make letters fatter every 2 inches apart across screen
this is called phase it can be set auto by the button or you can disconnect the power and next day reconnect and leave it in default which can be better than letting the monitor try to set the phase.
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
LCD Monitor goes off after 2 sec.
Check all cracked solder joints and resoldered and check two smd transistors near the inversors good luck
Aug 11, 2008 | Proview PL913B 19" Flat Panel LCD Monitor
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
235 people viewed this question
Top Proview Computers & Internet Experts
 Mike M
Mike M
Siul Oyaratgam
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
