Need to know how to clean filter inside fuel tank
My ryobi cuts off when u gave it the gas to run wide open. Some time if u choke it half way it my run wide open when u gave it the gas to run wide open
You can't clean the filter. You can however order a new filter with the filter attached from www.ryobi.com.
When you say it's not getting enough gas is the weedeater shutting off on you? If so your carb may need to be clean. If that's the case then report back and I can tell you how to do that.
Mike
Ok so how do you clean the carb. Cause I have the exact same problem
I just saw this. All you have to do is follow the fuel lines to the carb. Unscrew the carb from the assembly (make sure you count how many turns to take off as you need to turn it back to the same place when assembling). Once off just get some carb cleaner (autozone, advance) and spray on the carb and make sure all holes are open after you are done.
