Question about HP OfficeJet 4315 All-In-One InkJet Printer
Hp 4315 all-in-one printer scanner, fax
I need a manual.........where can I download one?
  • 1 more comment
  • sammi59 Dec 05, 2007
    I did not get a solution.........simply a response saying you had answered my question, which you did not.
  • sammi59 Dec 09, 2007
    Really appreciate your help.
  • Anonymous Feb 13, 2008
    I NEED AN INSTRUCTION BOOKLET FOR IT.
I need the faxing and scanning only,thank you
Posted on Feb 21, 2008
    Sergeant:
  • 264 Answers
Please go through the link provided below and you will find the mannual for your All in One.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=us&dlc=en&product=1138342&lang=en&
Hope this would solve your issue.
Sammy
Posted on Dec 02, 2007
  • Sameer Kashyap Dec 05, 2007
    I am not sure why you were unable to check the solution however have you checked the link i have provided to you in my last reply, It has the manual that you can download.
    I am providing the same link again.
    http://h10025.www1.hp.com/ewfrf/wc/manua...
    I hope that you get it this time.
    Thanks
    Sammy
My HP OfficeJet 4315 All-in-One printer defaults on FAX mode for some reason. How do I change it to print?
To better help you I did the work for you... I copied this from the HP forum which if you google your issues most of the time you find the answer!
Copied from: http://h30434.www3.hp.com/t5/Other-printing-questions/HP-officejet-4315-all-in-one-printer/td-p/411239
There are generally two print devices set up when an all-in-one with a fax is set up - one is the fax device and the other is the printer. Make sure you have the print device set as the default printer and/or that when you want to print that the printer and not the fax is selected.
Setting the proper printer as default would depend on your operating system, but for most versions of Windows you would go to the printers folder, right click on the non-fax version of the Officejet 4315 and select "Set as default".
Jun 17, 2011 | HP Officejet 4315 All-in-One Printer
Printer is not printing Device menu is set at fax. trying to change it to printer function to print, but manual and on line site does give guidance as to how to change. HP 4315 all in one
you can download the utility driver in the website.. the name would be HP Print diagnostic utility follow this steps
  1. Go to www.hp.com
  2. Click on "support and drivers"
  3. On step 1 click on "download drivers and software"
  4. On step 2 type the product number/ name of the printer (ex: officejet 4315 / Q8081A)
  5. (on the next page it will ask you to select your operating system. example: win xp, vista or 7) Select your operating system, then click on next.
  6. Once you click on next, you can scroll down then look for "Utility Diagnostic tools"
  7. Look for HP Print diagnostic tools then, look for the download link then you have to save it so... you don't need to keep on downloading it if you encounter same problem again w/ the printer.
  8. After downloading the driver, run it.
  9. Scan the problems on the printer. (the tool will tells you if you have issues w/ ports, default printer, printer driver and etc.)
  10. If the fix button is available click on it, if its asking to uninstall the driver please do so..
  11. Restart your computer.
  12. Check if you print any document.
if you want to get the exact link for your printer click here
Root cause: fax printer icon was set as default printer under devices and printers. if you are still having issues w/ it. call HP printers support department 1-800-474-6836
NOTE: If you call HP they may ask you to pay first, because this printer is old.
Good Luck :)
Jan 31, 2011 | HP Officejet 4315 All-in-One Printer
I have a HP officejet 4315 All in one printer/fax/scanner/copier -- I am told my faxes are very blurry -- what does that mean and how do I fix it?
Good Day,
I would like to suggest use your hp solution center click the tab for the HP All-in-One.In the Device support area, click Onscreen Guide or Troubleshooting. If you click Onscreen guide, a pop-up menu appears. You can choose to Help for the HP All-in-One. and If you click Troubleshooting, the Troubleshooting and support page open.
Good luck and God bless.
Jun 10, 2010 | HP Officejet 4315 All-in-One Printer
I do not know how to scan,or set up my hp 4315v all-in-one printer. Can you help me?
Click on "control panel" on your computer, click on "printers and faxes", click on "install printer" (left of screen on my program). Then the installation Wizard should come up and follow its instructions.
Whether or not you have to go to "scanners" (same page as "printers and faxes") I'm not sure. Do the first steps I have listed for a start and if scanner doesnt work use scanner wizard. Hope that helps. Good luck.
Apr 04, 2009 | HP Officejet 4315 All-in-One Printer
HP 4315 won't fax or copy
No. A new scanner assy will cost as much as a new machine. You need the scanner for faxing and copying.. The machine will not work without a scanner assy, it is the light bar that moves across the page.
Feb 19, 2009 | HP Officejet 4315 All-in-One Printer
Won't copy or fax, scanner failure
Uneconomical to replace the scanner assy. sorry
Feb 17, 2009 | HP Officejet 4315 All-in-One Printer
I cannot receive faxes, I have misplaced my owners manual of course!
Check the phone line with a regular phone.
Do you have digital phone service?
Jan 30, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Hp officejet 4315 how to switch from fax mode to print
There is no "print mode", Fax, Copy and Scan are modes one can enter, printing on the other hand is done when a print job is detected from your computer
DRIVERS to suit download link
Download Manual and Setup guide HERE
Please rate solution as fixed.
Nov 19, 2007 | HP Officejet 4315 All-in-One Printer
HP OfficeJet 4315 All-In-One InkJet Printer Logo
102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
