Question about Protron PLTV-32 Television
Dark wisps appeared on right side of screen.....
...looks like candle smoke, in a fixed vertical pattern. Not on the surface, as cleaner did not help. Is this common? cause? fixable? approx. cost? Unit is almost 3yrs old on Christmas (gift) and probably out of warrantee. Never abused, nothing spilled, just appeared!
Help is appreciated.
  • 1 more comment
  • Anonymous Dec 02, 2007
    i have the same problem having a dark half moon shape on right side of screen.it has kind of a ghosty feature to it and appears all of time,certain scenes not as noticeable.this is an acer 32 inch lcd tv.
  • piks56 Dec 02, 2007
    i HAVE THE SAME PROBLEM BUT ITS MORE LIKE A PICTURE BOX, IN THE TOP RIGHT SIDE OF THE SCREEN.
  • tassico Dec 03, 2007
    There must be a tech who has some experience in diagnosing this problem (or at least an educated guess). Help would be appreciated. Thanks in advance.
It is called burn in and you cannot fix it. Your best bet is to toss the PROTRON in the garbage and buy one that doesn't suffer this fate. I would suggest VIZIO, they guarantee no permanent burn in and no dead pixels. Check them out. There web site is Vizio.com. You can also read reviews from customers that have purchased these televisions. CNet also has information. Protron is a piece of junk. Also saw that they are merging with Digital Lifestyles, so would suggest staying away from that company also.
Posted on Dec 04, 2007
SOURCE:
How do I fix the picture?
there is a T con error please replace the T con in this condition
Feb 15, 2016 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
How to adjust headlights, 05 ford 500
Headlamp Adjustment
Headlamp Aiming
  1. The headlamp aiming procedure depends on what type of beam pattern the headlamp is equipped with. Vehicles may come equipped with visual optical left (VOL), visual optical right (VOR) or SAE only (includes sealed beam type) headlamps. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is 1 of the following:
    • SAE
    • VOL and SAE
    • VOR and SAE
  1. Once the headlamp beam pattern is identified, aim the headlamps using 1 of the following methods as applicable.
    • Photometric aimers can aim VOL-, VOR- and SAE-type headlamps only. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim VOL-, VOR- and SAE-type headlamps only.
    • Mechanical aimers cannot be used with VOR- or VOL-type headlamps. Aerodynamic lamps that can be aimed mechanically have 3 nibs molded into the lens of the lamp.
    • Photometric Aiming
      1. For the photometric aiming procedure, refer to the appropriate photometric headlamp aimer instruction manual.
      Screen Method Aiming
      All headlamp types NOTE: Horizontal aim is not necessary for VOL or VOR headlamps.
      NOTE: Consult your state vehicle inspection manual for recommended tolerance ranges for visual aiming.
      NOTE: The sight shield may need to be positioned or removed for access to the adjusters.
      1. Before starting headlamp adjustment:
        • check the tire inflation.
        • check that no other load is in the vehicle other than a half tank of fuel.
        • check that the headlamps are clean.
        • check for correct headlamp operation.
        • check that the vehicle is on level ground.
        • if the vehicle is equipped with air suspension, make sure that the switch is on.
      1. NOTE: The vertical wall or screen must be a minimum of 2.4-m (8-ft) wide.
        Park the vehicle on a level surface approximately 7.6-m (25-ft) from the vertical wall or screen directly in front of it.
      1. NOTE: The center of the lamp is marked either on the lens (circle, crosshair or other mark) or on the bulb shield internal to the lamp (crosshair or other mark).
        Mark a horizontal reference line on the vertical wall or screen.
        1. Measure the center of the headlamp height to ground and record the measurement.
        1. Make a 2.4-meter (8-ft) horizontal mark (using masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
      1. NOTE: This procedure should be done in a dark environment to effectively see the headlamp beam pattern.
        Turn on the low beam headlamps to illuminate the wall or screen and open the hood.
      1. NOTE: For SAE-type headlamps, the appearance of the beam pattern may vary between vehicles.
        On the wall or screen, locate the high intensity area of the beam pattern. Place the top edge of the high intensity zone even with the horizontal reference line.
      2. SAE-type headlamps
        1. In addition to the horizontal line marked in Step 3, a pair of vertical lines must be marked at the center line of the headlamps on the wall or screen.
          1. Mark the center line of the vehicle on the wall or screen.
          1. Measure from the center of the headlamp to the center line of the vehicle.
          1. Make two 1.5-meter (5-ft) vertical marks (using masking tape) on the wall or screen at the same distance from the vehicle center line as previously recorded.
        1. On the wall or screen, locate the high intensity area of the beam pattern. Place the left edge of the high intensity zone even with the vertical line corresponding to the headlamp being adjusted.
How To Aim Headlights EricTheCarGuy
Jan 15, 2011 | 2005 Ford Five Hundred
How do you ajust head light aim on a ford f-150 2008 truck?
  1. NOTE: The vertical wall or screen must be a minimum of 2.4 m (8 ft) wide.
    Park the vehicle on a level surface approximately 7.6 m (25 ft) from the vertical wall or screen directly in front of it.
  1. NOTE: The center of the lamp is marked either on the lens (circle, crosshair or other mark) or on the bulb shield integrated into the lamp (crosshair or other mark).
    1. Make a 2.4 m (8 ft) horizontal mark (using masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
VOR-type headlamps
  1. NOTE: The appearance of the VOR beam pattern may vary between vehicles.
    Identify at the top edge of this high intensity area a distinct horizontal cutoff in the beam pattern. If the top edge of this cutoff is not even with the horizontal reference line, the headlamp beam needs to be adjusted using the headlamp adjusting screw.
VOL-type headlamps
Apr 09, 2010 | 2008 Ford F-150
I have a 2000 ford mustang can you adjust the headlights and how do you do it
SECTION 417-01: Exterior Lighting 2000 Mustang Workshop Manual GENERAL PROCEDURES Procedure revision date: 12/09/2002 Headlamp Adjustment Headlamp Aiming
  1. The headlamp aiming procedure depends on the type of beam pattern the headlamp is equipped with. Vehicles may come equipped with visual optical right (VOR), visual optical left (VOL), or SAE only (includes sealed beam type) headlamps. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is one of the following:
    • SAE
    • VOR or SAE
    • VOL or SAE
  1. Once the headlamp beam pattern is identified, aim the headlamps using one of the following methods as applicable.
    • Photometric aimers can aim SAE, VOR and VOL type headlamps. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim SAE, VOR and VOL type headlamps.
    • Mechanical aimers can be used only with SAE type headlamps. Lamps that can be aimed mechanically will have three nibs molded into the lens of the lamp.
Photometric Aiming
All headlamp types
NOTE: Horizontal aim is not necessary for VOR or VOL headlamps.
    • Check the tire inflation.
    • Check that no other load is in the vehicle other than a half tank of fuel.
    • Check that the headlamps are clean.
    • Check for correct headlamp operation.
    • Check that the vehicle is on level ground.
    • If the vehicle is equipped with air suspension, make sure that the switch is on.
  1. NOTE: The vertical wall or screen must be a minimum of 2.4 meters (8 feet) wide.
    Park the vehicle on a level surface approximately 7.6 meters (25 feet) from the vertical wall or screen directly in front of it.
  1. NOTE: The center of the lamp is marked by a 3 mm (0.12 in) circle on the headlamp lens.
    1. Measure the center of the headlamp height to ground and record.
    1. Make a 2.4 meter (8 foot) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
  1. NOTE: For SAE type headlamps, the appearance of the beam pattern may vary between vehicles.
VOR type headlamps
    Identify at the top edge of this high intensity area a distinct horizontal cutoff in the beam pattern. If the top edge of this cutoff is not even with the horizontal reference line, the headlamp beam will need to be adjusted.
VOL type headlamps
  1. For VOL type headlamps, there will be a distinct cutoff in the left portion of the beam pattern. The edge of this cutoff should be positioned 50.2 mm (2 in) below the horizontal reference line.
    1. Horizontal reference line.
    1. Top edge of the beam pattern.
    1. High intensity zone.
Mechanical Aiming
  1. For the mechanical aiming procedure, refer to the appropriate mechanical headlamp aimer instruction manual.
2010&c18=modelyear&c20=n304745&c35=wsm%2cheadlamp%20adjustment%2csyb%2c417-01%2cgeneral%20procedures&pid=wsm%2ctitle%20page%202000%20mustang%2csyb&pidt=1&oid=functiononclick%28%29%7bdosearch%28%29%3b%7d&oidt=2&ot=img&oi=27&s=1600x900&c=32&j=1.3&v=y&k=y&bw=1171&bh=582&ct=lan&hp=n&[aqe]
Apr 07, 2010 | 2000 Ford Mustang
I just installed the right head light on a 2000 f250. I'm trying to find the specifications on distance and height of the light beams, L &R when adjusting the lights.
Headlamp Adjustment —Screen Method Aiming NOTE: Horizontal aim is not necessary for this vehicle and is not adjustable.
NOTE: Consult your state's vehicle inspection manual for recommended tolerance ranges for visual aiming.
  1. NOTE: The sight shield may need to be positioned or removed for access to the adjusters.
    Before starting headlamp assembly adjustment:
    • Check that no other load is in the vehicle other than a half tank of gas.
    • If the vehicle is equipped with air suspension, make sure the switch is on.
    • NOTE: The vertical wall or screen must be a minimum of 2.4 meters (8 feet) wide.
  2. Park the vehicle on a level surface approximately 7.6 meters (25 feet) from the vertical wall or screen directly in front of it.
    1. Make a 2.4 meters (8 feet) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
  1. NOTE: The appearance of the beam pattern may vary between vehicles.
7ced4e6.gif NOTE: The appearance of the beam pattern may vary between vehicles.
Apr 06, 2010 | 2000 Ford F250 Super Duty Crew Cabs
Dark vertical bar on right side of display
Please let me know if you find a fix. and what the problem was. Eddie.
May 28, 2009 | Samsung DLP HL-P5663W 56" TV
Tv screen constantly has a film on the screen surface
Televisions typically electrostatically attract dust and particles in the air -- it's unavoidable. If you do a lot of cooking (particularly fried foods) near the room where your tv is, it could be that it is attracting grease etc from the air...or, if there are smokers in your house or you burn a lot of candles, it could be residue from the smoke or candles.
(By the way, did you know that beeswax candles are the cleanest burning candles you can buy?)
Hope this helps!
NOTE: If you found this helpful, PLEASE, PLEASE show your appreciating by giving me a good rating!! Thanks!
Mar 16, 2009 | JVC AV-27530 27" TV
Dark vertical line going from top to bottom on the lcd screen.
http://uk.youtube.com/watch?v=qBpg77ZzFFk
watch this it will tell you how to fix it.
Jan 08, 2009 | Televison & Video
Protron PLTV-32 Television Logo
82 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
