This is for a Ford Ranger XL 4 cyl, Xtra cab,I've dropped the gas tank part way, and I am afraid that if I go farther I might break the smog line or fuel line etc., The purpose for my question is that it won't pass smog and I found the hole in the line that goe's across fuel tank, Thanks so much
You should be able to put a piece of rubber fuel line over the section with a hole, clamp both ends. If it's hard to get to, run a long piece of rubber fuel line (inside diameter big enough to fit over smog line), cut the original smog line, attach new rubber fuel line over cut section, wiggle it over the tank to other side where you can cut original line again, and attach both ends with hose clamps. Let me know how it goes, it should work, you can even go around the tank front or back, just make sure you use zip ties or something to keep the hose from hanging down.
