Question about Samsung SyncMaster 793DF 17" CRT Monitor
The screen doesn't display
When it's turned on,the light on my monitor blinks,but the screen does't display can i fix it?
  • 2 more comments
  • jess050669 Dec 03, 2007
    gud am I've alreadycheck the cpu to other monitor it's normally work but my Samsung SyncMaster 793DF 17" CRT monitor the screen still doesn't display anything and i heard the relay inside the monitor produce clicking sound and doesn't on and go back stanby mode.How can i fix it. Thank you.
  • boybawang Aug 19, 2008
    I have Samsung Syncmaster 793mg. my problem is similar.
    1. When I turn-on the system the Monitor screen is blank but the green
    led blinking. I can't see anything. not even the bios start-up texts.
    2.I tried unplugging it's cable connecting to the video-card and a video-outlet-image with "?" appears in the screen.
    3. Even the screen is blank, the computer continues to boot. Infact I can hear the "windows welcome sound".
    Please help!!! and thanx in advance
  • ianbarias Dec 24, 2008
    I have the same problem and I know its not my CPU dirt or whatsoever since I have isolated the monitor problem by connecting it to another CPU and it still doesn't work.
  • boybawang May 11, 2010
    But I know that my CPU is fine because it continues to boot-up while the screen is Blank. I can hear the "windows welcome sound"
    Please help me.
  • 270 Answers
That means the computer is not getting signals from the cpu .. its because of cpu problem .. mainly dust inside hard disk connectors clena and refit memory and hard disk
Posted on Dec 02, 2007
My Dell Latitude D630 has a blank screen.
Check your hardware light on the exterior of your computer and see if it is lit and blinking. If it is, you have an operating system, but just can't see it. That tells me it may be several things:
1. The LCD cutoff switch is in the off position
2. Toggle (Fn) the display to the internal settings of the LCD panel. It may be set to display an external monitor only
3. Plug in an external monitor. If it doesn't display on the external, after pressing the Fn key you have a failed video adapter. If it does display on the external it is most likely a back light or inverter failure.
Apr 05, 2012 | Dell Latitude D630 Notebook
My monitor screen is black and the yellow standby light is blinking. I can not get the light to stop blinking or get the monitor to show anything, but a black screen. What can I do to coerrect the problem?
mcdevito75 here, Press the SHIFT key, a screen should come up telling you too click on your user name, left lower side of screen. If this doesn"t work, press the yellow blinking light on the monitor see if picture comes back, then follow the directions. If this doesn"t work, shut computer down with switch on the computer itself. Hope this helps.
Jul 17, 2010 | Acer Computers & Internet
No display on monitor when powered,Light is on.
change caps 1000mf-10v to 1000mf-25v in power supply and 470mf-10v to 470mf-25 or 16v.
May 12, 2010 | ViewSonic E50C 15" CRT Monitor
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? my new lcd monitor blinks on for 1 second then off but my...
Refresh rate may be set too high for LCD
hook up crt monitor
1. Open control panel-display
Click on settings tab and set to a lower screen res such as 800x600
Try lcd
2. Open control panel-display
click advanced button
click on monitor tab
set screen refresh rate to 60 hz
Try lcd
May 20, 2008 | Computers & Internet
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Monitor will go on for a split second, then screen will go...
they normally turn off like this when they aren't receiving a video signal from the pc (same as when you turn off the pc). make sure that it is connected properly, and that the video output is activated. try disconnecting from the other monitor while its on and connect the problem monitor...if it still isn't working then there may be a problem with the cable or the monitor itself. Try another VGA or DVI cable. Hope this helps
Mar 29, 2008 | Computers & Internet
HD19A / 19-Inch light flickers but no display
One of 2 possibilities come to mind.
1,  The vga chord is loose on the back of the monitor.
2, Your resolution is set too high or low to be displayed.
The blinking light means that the monitor is either not getting or understanding a signal.
Hope this helps.
Oct 12, 2007 | Microsoft Likom HD19A 19" LCD Monitor
Samsung SyncMaster 793DF 17" CRT Monitor Logo
214 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
