Question about SanDisk Sansa m240 MP3 Player
Stuck in "sandisk initializing screen"
Am using the sandisk m240 mp3 player. It seems several people have the same problem of the player being stuck on the "sandisk initializing" screen. Mine is doing the same thing and I can't even get the computer to recognize it. It shows nothing, like it hasn't been plugged in. I put in new batteries, it isn't that and there doesn't seem to be many suggestions??? help
  • 3 more comments
  • cherr Jun 18, 2008
    sandisk initializing keeps blinking, when i hook it up to my mac
  • Anonymous Jul 21, 2008
    I am also having this problem. Please help.
  • Ronnie9503 Oct 03, 2008
    I have exacly the same problem please HELPPPPP!!!!
  • chris_maxwel Jan 06, 2009
    it turns on says "Sandisk Initializing" and keeps blinking
  • Anonymous Jan 21, 2009 do you shut it off??
Yeah, I am also experiencing this. I guess some people answering don't understand the issue here, or at least not mine. when I turn mine on when it is not plugged into the usb, it gets stuck at the "Sandisk initializing" screen, then the "Sansa m240 1.0GB" screen, and repeats itself. I so not know the solution, but I thought I would clarify for those of you who are not comprehending the issue.
Posted on Oct 08, 2009
I removed one screw and took it apart. I then removed a chip (my guess it's the flash chip), put the battery between the contacts, tried to turn it on and nothing happend. Plugged chip back in, put the battery between the contacts again and it worked!
Posted on Jan 17, 2009
That is not helpful when the computer doesn't even see your MP3 Player
Posted on Aug 28, 2008
  • 4,402 Answers
To those that are having problems with the MP3 player not being recognized. With Windows XP there is a little Icon on your Systems Tray that is called the "Safely Remove Harware Icon". Not using this Icon when unpluging MP3''s or zip drives can cause your PC to no longer recognize it. Toshiba Satellite laptops are known for this, others probably have the same problem. The solution here is to install the latest update of the ACPI Flash Bios for the Toshiba Satellite computer. Maybe this is also the problem with other PCs. To prevent these problems allways click on the Safely Remove Hardware icon before removing the MP3 player or any USB flash drive
1 With your m240 set to MSC and connected, go to "My Computer" and "right click" on the "Sansa m240" icon and select "Properties"
2 In that window, select the "Hardware" tab
4. In that "All Disk Drives" window, highlight the "Sansa m240" drive and select "Properties" (at the bottom)
5. In that window, select "Policies"
6. And there, set it to " Optimize for Quick Removal" and click OK and OK again
Posted on Dec 03, 2007
Folks: Turn ON your Sandisk m240 MP3 Player and go to the 'Menu' and select 'Settings', then go to 'USB' and select 'MSC'. After that, connect the m240 to your computer and it'll recognize your Sandisk m240.
Posted on Jan 06, 2009
Used for years. Deleted mp3 files. Tried to reload new mp3 files by select all and drag and drop to audible folder. Message said it was full and would only load partial. Deleted partial load safely...
Sorry mate it has been corrupted and and may not work any more it seems the set up and read file that is like a operating system has been moved or deleted. The same things happens with usb drives.or has been disconnected without using the disconnect usb device icon.
Jan 31, 2011 | SanDisk Sansa m240 MP3 Player
Only displays initial power on screen (SANSA m240 1.0GB)
try changing the works sometimes....
Aug 11, 2009 | SanDisk Sansa m240 MP3 Player
Lost Installation Disk for Sandisk Sansa m240
most of the mp3 players are recognized without installation cd itself.
please answer me the following questions
1. are you using your mp3 player for the first time in your computer or you uninstalled the software and lost the cd .
2. what happens (or shown )in the screen of the player when you connect the device to your pc
Jul 22, 2009 | SanDisk Sansa m240 MP3 Player
keep the hold switch to right side and connect to pc...then format the player or try updating the firmware..tht must do...
Jun 17, 2009 | SanDisk Sansa m240 MP3 Player
Cover plate
my mp3 player have been stuck for a one month and i cant listen any music i have download
Oct 06, 2008 | SanDisk Sansa m240 MP3 Player
LCD screen on Sandisk M240 MP3 not working
it stays on the sandisk screen.its frozen
Dec 28, 2007 | SanDisk Sansa m240 MP3 Player
Stuck on initializing screen
Call Sandisk support. This is a known problem with this model that was sold in December 2006. Apparently later models fixed the issue. They will get your info and do an RMA, and they even provide the UPS shipping label.
They were great to deal with. I hope you have the same success.
Oct 25, 2007 | SanDisk Sansa m240 MP3 Player
Pls help me asp
por mi sansa no funciona se en cuentra en initializing
Dec 25, 2006 | SanDisk Sansa m240 MP3 Player
New SanDisk Sansa m240 MP3 Player
there are 2 usb choices on the sansa m240 one is msc the other is auto detect. msc is for downloading new upgrade software i beleive , because thats the setting sndisk has you set it on to download new upgrade software .it stands for mass storage class .it may need to be on auto detect .
Dec 24, 2006 | SanDisk Sansa m240 MP3 Player
R u holding the holding the Menu button down for about 3 seconds?
SanDisk Sansa m240 MP3 Player Logo
1,223 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
