Usb ports hi can you help please i cant use my usb ports. in device manager there is a error sign against the standard open hcd usb host controllers, when you click it states this device code 12 cant find enough free resources that it can use you must disable one of the other devices to use .if you click on safely remove hardware it shows only the memory card reader slots to remove. inerror reports it states that std open hcd host controller is misconfigured code 47
  • 1,113 Answers
Sounds like something else is chewing up you memory have you got too much allocated somewhere else or control panel/ system /device manager/ serial bus controlers/ std open host controller... update driver, or uninstall and then reboot and windows should hunt it down for you. you may need the driver for it if it cant find it by itself, that means knowing what sort it is (motherboard handbook) and going to site and getting driver.
Posted on Dec 04, 2007
Every time I hook up my mp3 player to my computer it doesn't recognize it, nor acknowledge that something is hooked up. The same thing also happens when I plug in my flash drive. In my device manager I...
Try the possible steps given below and check if it helps.
Remove all the connected USB devices including the Walkman Player.
Reboot the Computer and once it starts up connect only the Walkman to the Computer.
Please be sure that no USB Hub is being used to connect the devices.
Try connecting to different USB port on the Computer.
Press the RESET button located at the rear of the Walkman after connecting to the Computer.
Check if Connecting or Connected USB (MTP) message is appearing on the screen when connecting to the Computer.
Activate Windows Media Player 11 or Windows Explorer in the Computer and check if it is recognized.
After trying all the possible steps above and if the issue persists, then the issue may be with the USB Connector of the Computer or the USB Drivers. Try connecting the Walkman to a different Computer to check if the issue is with the Player.
Thanks for using FixYa
Dec 08, 2010 | Sony Walkman NWZ-E344 Digital Media Player
Hi, i do have a n1996, ms-6547, motherboard, imtrying to download a fix for and also for usb 2 and i can not find them,thanks in advance
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver
If your Device Manager shows an ENHANCED USB Host Controller, the system has High Speed USB (USB 2.0) capability.
Types of High Speed USB (USB 2.0) Host Controllers
· Intel Enhanced
· SiS Enhanced
· VIA Enhanced
· ALi Enhanced
· Standard Enhanced
· NEC Enhanced
The system shown has onboard Intel High Speed USB (USB 2.0) with an NEC High Speed USB (USB 2.0) PCI card installed.
The key word is ENHANCED. If you have an ENHANCED USB Host Controller then you have High Speed USB (USB 2.0)
All other types are USB v.1.1
hope this helps
Nov 11, 2010 | MSI MS-6547 Motherboard
My pc will not detect the usb cable to install my hp c5150. I know there is nothing wrong with the port b/c my computer will detect my ipod and camera. Any ideas why it won't detect my printer cable?
firsty it could be a faulty usb cable else try changing your chipset drivers right click my computer/ computer left clik on manage. computer manager should open left clcik on device manager in your centre screen look for Universal serial bus controllers click on the plus sign look for you universal host controllers you can have from 4 to 8 of them (do not change the enhanced host controllers)
right click one of the universal host controlers click on update driver a wizard should come up look for browse option and next and then look for the option "let me choose driver" and then select the standard usb host controller and apply if you get a microsoft message just click on continue anyway then repeat for the rest of the universal host controllers once all has been changed try installing the printer drivers and when prompted by software to plug in printer you may do so
hope that helps
Jan 26, 2010 | HP PhotoSmart C5150 All-In-One InkJet...
I keep getting the statement: "Hi-speed USB Device attached to Non-Hi-Speed Hub
This is purely because you have a USB 2 device on a USB 1 port. Open the device manager and expnad the list for Universal Serial Bus Controllers. Right click on any one of the host controllers and select Properties. Select the tab called Advanced and place a tick in "Don't tell me about USB errors".
Jan 21, 2010 | Epson Stylus NX400 InkJet Printer
My Panasonic CF-74 doesn't seem to be detecting anything I am plugging into the USB ports or the COM port.
Some motherboard BIOS's allow you to specify how many USB ports you want enabled
go to your Control Panel, System, Device Manager.
go down to where it says Universal Serial Bus Controllers, click the + sign,
you will see a list of devices, probably something like this
via rev5 usb host controller
usb printing support
usb mass storage controller
usb root hub
usb root hub
right click on the ones that say via or intel or SIS, or ALI, or Standard open host controller, and choose uninstall.
you will be asked if your sure, and you will see some of the USB root hubs disappear.
If you are asked to restart, choose no, and remove the other via/sis/intel/etc open host controller (s) from your system, when they have all been removed restart your computer.
when the computer restarts, it will detect the USB controller and connected devices, reinstall the drivers/software
Jun 24, 2009 | Panasonic Toughbook 74 PC Notebook
Hi i have an acer laptop 5000 series the usb ports will not work saying power surge overloaded,would buying a usb card solve the problem.Any help would be much appreciated.
are you using windows xp sp2, this issue normally occurs with it
a fast fix is:
go to start menu> run > type in devmgmt.msc > ok
1) Device Manager will open
2) Locate "Universal Serial Bus controllers" in the list and expand
3) Select the first USB Universal Host Controller.
4) Right click and select "Properties"
5) Go to the "Advanced" tab
6) Check "Don't tell me about USB errors"
7) Click "OK"
Note. If you have multiple host controllers then they should all be affected by the above action.
8) Close Device Manager
further Queries are welcome
Feb 18, 2009 | Acer TravelMate 4100 Notebook
Usb ports not working
  1. Checking USB device status in Device Manager
  1. Right-click My Computer on the Windows desktop and then click Properties.
  2. Click the Device Manager tab to display the Device Manager window as shown at the right. (For Windows 2000 systems, click the Hardware tab and then the Device Manager button.
  3. In the Device Manager list, click the + sign next to Universal serial bus controller.
  4. Verify that a USB host controller and a USB root hub are listed below Universal serial bus. image002.jpg
  5. If Universal serial bus controller, USB host controller or USB root hub are not listed, close the Device Manager and go to USB port incorrectly configured in BIOS
  6. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a yellow exclamation point, go to USB controller IRQ conflict
  7. If you have Windows XP, right-click the Host Controller and select Properties from the drop-down menu. If you see this status message in the Properties window: The drivers for this device are not installed (code 28), go to Windows XP USB 2.0 driver not installed .
  8. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a red X, go to USB controller or root hub disabled in Windows Device Manager.
USB port incorrectly configured in BIOS NOTE: The procedure in this section is intended for advanced users only. Incorrect BIOS settings could prevent your computer from starting or operating normally. If you are not experienced in making changes to your computer BIOS, consult your computer instructions or contact your computer manufacturer for assistance before attempting the steps below.
  1. Follow the instructions of your computer to view the BIOS settings. These settings are sometimes called CMOS settings or system setup.
  2. To view the BIOS settings, press a key, such as F2 or Delete, just after you turn on the computer. Instructions often appear on the screen briefly when you turn on the computer. Also check the instructions and manuals provided with your computer.
  3. Look for USB Interface or a similar setting in the Advanced Setup, Peripheral Configuration or another section of your computer BIOS settings.
  4. Follow the onscreen instructions or read the computer documentation to enable the USB port.
  5. Follow the onscreen instructions to save the new settings and restart the computer.
  1. USB controller or root hub disabled in Windows Device Manager
  2. Click the Device Manager tab. (On Windows 2000 and XP systems, click the Hardware tab and then the Device Manager button.)
  4. Click the line in the Device Manager containing the red X.
  5. Click the Properties button. (On Windows 2000 and XP systems, click Properties on the Action menu.)
  6. In the Communications Port Properties box, click the Resources tab.
  7. Re-enable the USB device by clicking the Enable Device button and follow the onscreen instructions.
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Power Surge error message
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at thumuvikram@rediffmail.com for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
PC can't communicate with GPS unit for initial map load
It will NOT show up under USB controllers. It should appear as "GARMIN Devices" in your device manager. Mine is right under Floppy disk drives. Do other USB devices 'bong' up when connected and 'bong' down when taken off? Of course you have to have your audio on for that. The GPS should 'sound' just like any other USB device when attached or taken off. I find that GARMIN help is of no use. Forums like this have helped me far more.
Feb 04, 2007 | Garmin StreetPilot C330 GPS Receiver
USB connection problem using Windows 98 Second Edition
The cause of this problem can be traced to both the computer's hardware configuration and Windows 98SE (Second Edition). PhotoMAX cameras and other devices featuring USB (Universal Serial Bus) connections may not work with computers running Windows 98 Second Edition and equipped with the following computer hardware: * an AMD processor (350 MHz or higher) * VIA Technologies USB Host Controller or SiS 7001 USB Host Controller To find out what USB Host Controller is on your system: 1. Click Start > Settings and choose Control Panel. 2. Double click the System icon. 3. Choose the Device Manager tab. A window similar to the one shown below appears. 4. Expand the Universal Serial Bus controllers listing by clicking on the "+" sign next to the listing. 5. Note the type of host controller in the listing. The example above shows the SiS 7001 PCI to USB Open Host Controller.
Sep 14, 2005 | Polaroid PhotoMax MP3 Digital Camera
Televison & Video Logo
278 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
