Question about Apple iMac G5 Desktop
Imac g5 i have recently purchased a second hand g5 which is working great appart from when i put in a dvd.a window appears and asks for my password.i have spoken to previous owner and thre are no passwords stored  any ideas thanks
    Problem Solver:
  • 6 Answers
Seens to be a ownership issue due to
because all non mac native will be terated as a atemp to read , write or copy file tha are not OSX file system
Posted on Dec 06, 2007
  • 79 Answers
HI, read through this Apple artice, I hope it helps. Please rate if useful, thanks!
http://docs.info.apple.com/article.html?artnum=106156
Posted on Dec 02, 2007
SOURCE:
I need to unlock a iMac running OS 10.6.1
Step 1:
Turn off your iMac G5
Step 2:
Power it back on. Right when you hear the startup sound, hold down Command and S together. This will bring up a black and white terminal prompt.
Step 3:
If at this point, it asks for a password (firmware password), power back down the iMac, change the amount of RAM (remove one stick of RAM and leave the other in), turn the computer back on and when you hear the start up sound hold down Command + Option + P + R. Keep holding until it restarts again. Once it restarts again, let it boot up, then shut it down again and put the stick of RAM back in. This will reset the firmware password and should allow you to continue onto the next step.
Step 4:
Once you are successfully at the command prompt, type the following commands, pressing enter after each line.
mount -uw /
rm /var/db/.AppleSetupDone
shutdown -h now
Step 5:
That's it! Once you boot back up, you should have a brand new administrator account that you can use to access all files and remove other accounts.
Dec 25, 2012 | Apple iMac G5 Desktop
Replace iMac g5 20 hard drive
Hi John
Try reinstalling via your macbook pro but this way round.Put the Leopard Disk into the Macbook and then start the Macbook in Target mode.on the iMac start it up and hold down the Option (or Alt) key then wait.after a short while you will be offered the HD in the MacBook and the DVD. Choose the DVD and see what happens.
What happens when you do it the other war arounds is that you are installing a startup system for the MacBook onto the HD of the G5 and not the system for the G5. The installer uses the firmware of the motherboard that is running the install to select the correct version.
Another issue is that the disk formatting may be wrong. it's unlikely seeing that you used disk utility from the DVD, but it is possible.
Let us know how you get on.
May 03, 2012 | Apple iMac G5 Desktop
TRYING TO INSTALL MAC OS VIA TARGET DISC MODER
The issue you are having is one in Intel, the other is G3.
This is how to do it. 1. put the cd/dvd into the laptop and restart the laptop in Target mode.
2. connect the laptop to the iMac with a Firewire cable.
3. Start the imac and immediatle hold down the alt/option key.
4. after a moment you will be offered a choice of start-up discs - one of which will be the CD/dvd in the laptop.
5. Start from the CD and then when asked, select the iMac drive as the destination. This ensures that the imac loads the correct version of the OS for its processor. Should work without a hitch.
Mar 03, 2012 | Apple iMac G5 Desktop
Forgot imac password
Start the imac from an install DVD and use the rest password option.
Jan 23, 2012 | Apple iMac G5 Desktop
G5 keeps powering up for a few mins then switches off?
Thank you for contacting Fixya Support, I am glad to assist.
There are a few steps you can try to troubleshoot this issue:
Try a PMU Reset:
* Turn of your iMac if it is already turned off
* Disconnect all connections to the iMac except the power cord
* Now disconnect the power cord for approximately 20 seconds
* Reconnect just the power cable the keyboard, mouse and power cord, and then power your iMac G5 up.
* Check to see if the iMac boots up normally without power interruption.
* If the iMac G5 shuts off again, try these steps, another recommendation would be to remove all connections including the power cord, and lay the iMac G5 on soft cloth face down and with a philips screwdriver, remove the plate on the bottom of the iMac G5 where your RAM memory is located.
Before removing the RAM however, touch your hand on the metal boot to discharge any static current you carry for approximately 5 seconds.
Now remove each RAM card and then reseat (re-install) each card.
Restore the RAM card cover with your Philips screwdriver, reconnect your power cable, keyboard an
d mouse and turn on your iMac G5.
See if this second procedure helps if the first procedure does not work.
Let me know if this helps.
Regards
-Mactechtrainer
Sep 11, 2010 | Apple iMac G5 Desktop
My computer is running very slow. and safari keeps asking for my password. i'm not that computer literate, so simpler language would be greatly appreciated. thanks much.
The computer will slowed because you have installed many of softwares in it. Remove applications from startup. Install a good licensed antivirus in it. Use Google chrome for better surfing.
Jul 25, 2010 | Apple iMac G5 Desktop
Imac G5 will not boot up.
When you boot up g5 hold down the command button (apple logo) and the letter s at the same time to but the g5 in single user mode. When it boot in single user mode type fsck -f so it can check disk on the hard drive and repair Mac OS X. After it done doing check disk type exit and see if it will boot up regularly.
Mar 09, 2017 | Apple iMac G5 Desktop
Connecting external microphone to imac g5
Get yourself a great little gadget called iMic. It's a usb connector that adapts to let you used your headset mic and the mac system os will recognize it very well. Works good .
Costs about 24 bucks or so..
K
Jun 19, 2009 | Apple iMac G5 Power Supply 661-3351
17" iMac quit working
Your Imac may be one of those affected by Apples purchase of inferior capacitators from Taiwan. If you are less than 3 years from the purchase date, apple will repair the problem for you for free. Just take the unit to your nearest local Apple Genius or tech. If you are outside of the repair extension guidelines, I have provided a link here which can show you or someone more skilled how to repair the problem. Ordering a new motherboard and power supply will set you back a lot of money, however the following guide and pdf give you step by step instructions on how to ressurrect your dead imac without speding more than $100.00. I was able to repair my imac using this guide and it was worth it to save a $2k computer that was only 3 1/2 years old. Check it out:
the following information (in italics and bold)  is taken directly from: http://www.jimwarholic.com/2008/07/how-to-repair-apple-imac-g5.php.  (this site is complete with instructions, manual and the full compliment of materials available at an extremely affordable and fair price. I took a chance and repaired my own, it is not as hard as it sounds1)
The iMac G5 Repair Extension Program for Video and Power Issues applies to first generation iMac G5 computers that have video or power-related issues as a result of a specific component failure. If your iMac G5 is exhibiting any of the symptoms listed below and your computer's serial number is within the noted ranges, your computer may be eligible for repair, free of charge. If Apple or an Apple Authorized Service Provider (AASP) determines that your iMac G5 computer is eligible as part of the program, the repair will be covered by Apple for up to three years from the original date of purchase even if your iMac G5 is out of warranty.
This is a worldwide Apple program.
Affected systems will exhibit one of the following video- or power-related symptoms:
Scrambled or distorted video
No video
No power
Note: If your iMac G5 is not experiencing any of these symptoms, you do not have to contact Apple or any Apple Authorized Service Provider.
Which iMac G5 computers are affected by the iMac G5 Repair Extension Program for Video and Power Issues?
The program is available for certain first generation iMac G5 models that were sold between approximately September 2004 and June 2005 featuring 17- and 20-inch displays with 1.6GHz and 1.8GHz G5 processors.
The affected iMac G5 computers have serial numbers where the first 5 digits fall into the ranges noted below.
Serial Number ranges:
W8435xxxxxx - W8522xxxxxx
QP435xxxxxx - QP522xxxxxx
CK435xxxxxx - CK522xxxxxx
YD435xxxxxx - YD522xxxxxx
Some second generation iMac G5 computers have serial numbers that fall within the upper band of the ranges listed below. Only first generation iMac G5 computers are affected by this program.
Where do I find the serial number of my iMac G5?
The 11-digit serial number is located on a label under the foot of the iMac G5. There is a bar code underneath the serial number.
To view the label, hold the sides of the iMac and gently lay the computer face down on a soft, clean towel or cloth.
Is the iMac G5 Repair Extension program available for other Apple computers?
This program applies only to the systems noted in this FAQ. Other versions of the iMac G5 line are not part of this program. Click here for more information on how to identify iMac G5 models
Free guide for how to repair the motherboard capacitors, rescue the hard drive and more.
http://www.jimwarholic.com/docs/Repairing-Apple-iMac-G5-Motherboard.pdf
Feb 22, 2009 | Apple (661-2795) for iMac Motherboard
Imac g5 model:a1058
iMac G5's cannot run windows alone, but older software can be purchased like Virtual PC to run windows on that unit.
Aug 05, 2008 | Apple iMac G5 Desktop
Open Questions:
See all Apple iMac G5 Desktop Questions
Apple iMac G5 Desktop Logo
100 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
tylerbell49
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
