Question about Kaz Honeywell QuietClean HFD-135 Air Purifier
Annoying ticking After months of running normally, my air purifier is now ticking constantly. Has anyone had the same problem and found a solution?
  • g8erhayes Jan 07, 2008
    Mine just started doing the same thing. It sounds like it's coming from the fan motor. I've contacted KAZ about the problem, but still haven't heard anything back from them.
My air purifier was doing the same thing. The ticking noise you are hearing is caused by dust build up on the ionizer pins. When the ionizer pins collect too much dust, they tend to start making the clicking/ticking sound caused by static electricity. The solution is simple. Take the filter out and clean it real good (follow directions on filter on how to clean). Now, with the filter out, if you look down inside the vent where the filter was, you'll see a white piece of plastic with nine holes in it that are about the size of a silver dollar. Directly in the center of each hole there will be something that looks like a needle, those are the ionizer pins and they will probably have dust built up on them. Next, with the filter out, blow out the air purifier with compressed air to clean all the dust off the ionizer pins. This should take care of the problem, it worked on mine.
Posted on Jan 12, 2008
Constant red light
it may need a clean as there is a air flow sensor, if the flow is not right then it will have this on also a faulty sensor will read this aswell.
Mar 24, 2014 | Hoover AH60015 Air Purifier Replacement...
Carrier Infinity air purifier makes constant zapping sound when operating with door in place.
It sounds like static electricity being generated through the filters. I suggest you change the filters and see what happens!
Jan 10, 2013 | Air Purifiers
I am not sure when or how to change the filter for my ecoquest air purifier. I moved into a house with brand new carpets, floors, paint etc. and then had a flood. I was running the purifier fairly...
If you have a HEPA filter, it may need cleaning. Every month at least. If you figured you don't NEED one because of the machines abilities to knock down particulates, you're most likely right. HEPA "filters" tend to grow their OWN nasties after a short time with ANY moisture around at all. The plate may have VOC's crystallizing on the plate. Check the lint screen and if it doesn't smell bad(musty) and you can see light thru it when you hold it up to a light, it's probably only needing a vacuuming. Some people rinse them in warm soapy water. Make sure it's DRY before putting it back in.
Jun 13, 2011 | Ecoquest Fresh Air Air Purifier
All of the lights on the control panel are flashing simutanously and constant. The air cleaner is not working. I just had it tuned up about a month or so ago. Whats happening
Here's something that has worked in the past. Turn the Master ON/OFF switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes before plugging it back in. Once it's plugged back in turn the Master ON/OFF Switch to ON and set the controls as you normally do.I f everything now functions as it should, the unit reset itself.
If that doesn't solve the problem contact the Oreck Service Dept that did the tuneup for you.
Apr 04, 2011 | Oreck XL® Tower Air Purifier
Just received a new air purifier, and was quite surprised to see big pieces of styrofoam in the fan/air output area.....at first we thought it must be packing materials. My question is: I thought that...
That is packing materials. It was placed there to protect the vent louvers on the front from breaking during shipping. Apparently, some of them chipped or broke and found their way into the louver section. Simply clean them out. Small pieces can be sucked out with a vacuum that has a hose and crevice tool attachment.
Mar 07, 2011 | Hunter (30067) Air Purifier
Can purifer work without the ozone card working
It will operate without a purification plate, as long as you are running in RCI mode or normal mode. If you normally run the purifier with some ozone output, then you will need a purification plate. Hope this helps you.
Feb 21, 2011 | Ecoquest Fresh Air Air Purifier
The Honeywell electronic air cleaner constantly "snaps" even though it is clean. I have inspected the wires and fins, clean and spaced properly. Any suggestions?
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal .Remove both the cell and check clean the bottom portion by using a vacuum cleaner attachment. If the snapping continues with the cells remove contact your contractor.
Mar 05, 2010 | Honeywell (F50F1032) Air Purifier
My pureion makes a crackling/ticking sound when running;
Its just a wear in the ozone plastic its normal after continued use
Mar 22, 2009 | Brookstone Pure-Ion UV Air Purifier
Where can I have a Ionic Breeze Quadra Model S1637 repaired?
Try this link, pair for $10- http://breezerepair.com/parts.html
Jul 16, 2008 | Sharper Image Ionic Breeze® Quadra® 4.0...
Blinking blue light on ionic breeze s1871
Wher can you return it? Does anyone have and address? My Dads unit has a blinking blue light and the folks at sharper image say to bad so sad only after 2 months out of warrenty. Is there any one out there that can help? I am done buying things from Sharper Image with their attitude! hlaytos@aol.com
Mar 22, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Kaz Honeywell  QuietClean  HFD-135 Air Purifier Logo
539 people viewed this question
Top Kaz Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Kaz Air Purifier Expert? Answer questions, earn points and help others
