Philips 32PF5531D 32 in. LCD Television
Problem for Philips 32PF5531D 32 in. LCD Television
Dark shadow-like vertical streaks thru LCD screen (Sharp)
By oneshabbypri on Aug 19, 2009
Our Sharp LCD tv (about 45") is about 3 years old and has gotten dark, vertical streaks on right and left sides of the screen. They are more obvious when the screen is bright of course, very annoying. (We had a smaller Sharp tv that did the same thing and the streak just kept getting darker and wider. Eventually the tv just went out and would no longer stay on.)
What can we do about the streaks?
Thanks!
Solution #1
posted on Aug 19, 2009
Somewhat Helpful)
mbelectronic
Rank: Wiz
Rating: 85%, 75 votes
the panel went bad or connect a dvd to see if
the picture is normal if both tvs have the same
symptom then the tvs are not the problem.need a better antenna or get cable.
Was this helpful?
Yes
No
Solution #2
posted on Oct 26, 2009
Not Rated)
missdoc
Rank: Apprentice
Rating: 0%, 0 votes
Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
Was this helpful?
Yes
No
Popular Solutions for Philips 32PF5531D 32 in. LCD
Questions and Unsolved Problems for Philips 32PF5531D 32 in. LCD
Do you recommend Philips 32PF5531D 32 in. LCD Television?
Answer
Answer
Need a new table top stand for a philips 32pf7421D/37.
Answer
Shadow approx 1inch wide, 12inch long; 37 LCD Toshiba, 3 years old.
Answer
menu keeps comimg up on philips modle 32pf732oa/37
Answer
constant images of another channel on the screen with a huge line threw the middle when watching any... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 32PF5531D 32 in. LCD...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
