Question about GPX CDRW3500 CD Player
Cd recording malfunction
My record button is not working but all other functions are performing ok
  • Anonymous Sep 02, 2008
    wont record but does everything else
I have a power supply that burnt out but the unit worked good before that. Can I buy your recorder for parts or do you want to buy mine for parts? You can e-mail me at schepulis@ndtel.com
Posted on Dec 14, 2007
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
When i make a call from my W910 the person on the other end cannot hear me at all. Using handsfree in my car it works perfectly ok
Kindly Using your Sound Recorder function in the phone try to record a sound and listen. If its nothing then the in-built microphone is dead. If you can hear the recording then there is some malfunctioning in the Firmware of the phone. Get it serviced. Its not a big deal.
Regards, Wiqi
Aug 11, 2011 | Sony Ericsson W910i Cellular Phone
I need skype drivers
Skype is telecommunications software allowing for several functions amongst telephony, messaging and voice recording. Once installed on a computer, skype requires compartibity checks either as an internet capacity to acquire media to media between devices. Usually, skype should not malfunction. The computers networking strength should be capable of allowing Skype perform the functions, either as telephone, voice recording, or data transferability. Skype should least require drivers to perform, Skype may have a specific compatibility requirements to perform desirably. Verifying details with the Skype program should provide the desired remaining components.
Jan 26, 2011 | Computers & Internet
The player wont record. All other functions fine including playback and finalising.
You mean it records silence? if it finalises then it does recognise and burn to the disc- so the laser/drive seems to be ok..
If silence, bear in mind there are analogue, optical and coax digital inputs to chose from for record source
Don't forget too these units need the special CD-R audio discs not CD-Rs to record to.
Oct 19, 2009 | Marantz DR-700 CD Player
Handycam CCD TR517 Doesn't record
These models have a switch for 3 different modes of record. one where you press the red button once, one for having to hold the red button in and a 5 second record feature, check this mode. also check and make sure the tape you are using did not have the record save switch slid into record save position..
Jul 20, 2009 | Sony Handycam CCD-TR517 Camcorder
The remote can perform some functions but not others - left and up arrows work occasionally. Makes it hard to program or to delete, or even scroll.
try opening your remote.clean it with alcohol and soft cloth.let it dry.while drying, check the rubber buttons for breakage.assemble and test all.
May 28, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
What does Check record tab mean?
the term "tab" are used for sometime for "switch" and "button". So from general information, I think the camcorder has some kind of switch malfunction. Usually record button (toggles on and off) may be the problem if all other functions in PLAY mode is working. Also you may have "protective record tap" on tape may be changed. Hope this helps. -james
Mar 27, 2009 | Panasonic Palmcorder PV-DV102 Mini DV...
RECORDING LEVEL IS NOW INOP
Wide open as in you cannot control the gain? If so I would suggest controling it from your mixer using a second zone or record out.
Dec 09, 2008 | Sony RCD-W500C 5-Disc CD Recorder
Choppy recording and playback
If the heads become dirty, “NEED HEAD
CLEANING” appears during recording. During
playback, moreover, the following symptoms
appear.
≥Mosaic-like noise appears partially or the
sound is interrupted.
≥Black or blue mosaic-like horizontal stripes
appear.
When normal playback cannot be performed
even after the head cleaning
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Mar 27, 2008 | Panasonic PV-GS150 Mini DV Digital...
GPX CDRW3500 CD Player Logo
77 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
