2000 Ford Focus Logo
Posted on Aug 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the same problem
My trunk is stuck and the mechanic broke my lock on the back of my trunk and i cant get it open and my button on the inside of the car wont pop the lock its just a clicking sound and my light in my trunk is running my battery dead so i wanted to know did you know what the wire look like so i can cut the light off in the trunk?
Peter
Level 2:
  • Expert 77 Answers
  • Posted on Aug 19, 2009
Peter
Expert
Level 2:
Answers
77
Questions
0
Helped
47808
Points
219
Hi there, to just cut the light off in the trunk,
all you have to do is.. use a flat ended screwdriver and flip the light out and remove the blub.
and to do the lock remove the panel on the trunk lid and you will get to the lock mechanicam. and replace it.
I hope it as helped!!
Unlock trunk to 98 toyota corrolla
Usually there is a bar between the lock and the latch.
If the lock is broken and you can gain access thru the back seat, you should be able to take the bar out and turn the latch with a screwdriver.
I have a 2006 Dodge Charger and the trunk release on the key fob and the button the dash will not open the trunk. Can you tell me waht could have happened.
Enter into the trunk space after folding the rear seatbacks down. Pull the yellow emergency trunk release handle that should be dangling right beside the area where the trunk latches to the car. This should get the trunk open so that you can expect the locking mechanics for damage: bent steel, something foreign stuck inside, bad cable, etc.
Trunk wont open
WHEN YOU SAY THAT THE TRUNK WONT OPEN, DO YOU MEAN FROM THE INSIDE OR THE OUT?
WELL IF YOU CANT OPEN THE TRUNK FROM THE INSIDE. TRY OPENING IT FROM THE BACK WITH THE KEY. ONCWE YOU OPEN IT LOOK WHERE THE TRUNK LID MEETS THE CAR WHERE IT MAKES IT S LOCKING CONNECTION. ON THE LEFT SIDE THERE IS A MECHANISM THAT YOU PUSH IN SO YOU CANT OPENING IT. JUST PULL IT AND IT WILL ALLOW YOU TO OPEN THE TRUNK FROM THE INSIDE. GOOD LUCK.
1helpful
Half of key broke off inside trunk lock
you need to have the trunk open and the lock unlocked first then you can get the barrel out of the lock and remove the broken part of the key,,,so dont lock the trunk till you get it fixed,,,
1helpful
2answers
I can't open the trunk of my jetta even when i use the remote as well as the car key. i've already disconnected its battery
think you might have to go in through seat to release it ,something broke inside the boot lid ,last one i done it was the piece that pushed the release mechanism inside on the lock
3helpful
4answers
THE TRUNK CANNOT BE OPENED.THE INSIDE LEVER DOES NOT WORK NEITHER DOES THE REMOTE.
you can open it with a key? right? if so, sometimes there is a "lock out" lever near the trunk latch, the owners manual can show you where it is and if its in the locked position, it wont let the trunk open. The reason is.......if someone broke into your car, they cant just open the trunk.
1helpful
2000 Intrepid Trunk Lock
All newer vehicles have an emergency manual trunk release inside the trunk.
This should be basically a rip cord directly attached to the trunk locking mechanism. Most modern ones have a yellow handle on the ceiling of the trunk that will release the trunk latch if it is pulled. Yours may be a different color, but if you get in there with a flash light you can probably trace a steel wire from the trunk latch back to some sort of handle that looks like you can pull it. Its definitely worth a shot.
I have a 1993 325 BMW and cant get the trunk open. The button on the trunk lid just moves in/out freely. There isnt a lever on the inside to release the trunk. Of course the battery is dead now. I can...
if the doors and trunk are vacuumed operated, make sure all the doors are unlocked..this might make it easier to open the trunk..or get the car running and then try to open the trunk with the car running..turn key all the way to the left and push slowly in..I think it is vacuum operated like the mercedes
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
