Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Big & Small picture during start up
Hello, during start up, the picture seems to get small, almost roundish on the edges. It does this for about one minute. After that, the screen is fine. Any help? Thanks.
    Genius:
  • 1,153 Answers
Convergence maybe vertical area, call pts 1800-844-7871
Posted on Dec 22, 2007
What Kind Of Business Can Begin A 401k? Could My Company Be Not Big Enough?
Business, partnerships, self-employed people, sole proprietorships, and non-profit organizations can begin a Merrill Edge Small Company 401(k). So regardless of whether you have hundreds of employees or none, a Merrill Edge Small Company 401(k) might be the best arrange for you.
Jun 08, 2015 | Computers & Internet
HI, MY TV PCL5415R, HAVE SOUND BUT NO PICTURES SHOW ONLY BIG BLACK SQUARE
Set would seem to be either in PIP (picture in picture multiple mode) or the black box might be the TEXT feature which is found in the closed caption menu.
Nov 04, 2012 | Samsung PCL5415R TV
What does it mean my memory card is protected cause now I can't seem to take any pictures. How do I fix that?
Hello,Please remove your memory card and check to see if the small lock tab is in the locked position.If so unlock it.This tab will be on the upper lefthand edge as you look at it ,it's very small.
Jan 09, 2010 | Konica Minolta DiMAGE G500 Digital Camera
How do you remove rear tail light assembly to replace lamp? I remover the two screws that attach the assembly to the rear pillar but it is still attached to something else.
1. Open the tailgate.
2. Look closely at the side of the brake light cover where it is closest to the tailgate. It is black plastic.
3. You will see two roundish looking outlines in the black plastic (not the two outlines in the plastic that is the same color as your van). There is just enough of a crack to slide a small screwdriver into the crack.
4. Pop the little plastic "doors" up to reveal 10mm nuts with Philips heads.
5. Remove the bolt/screw from each of the two holes. The tail light cover will be loose, but it will not come out yet.
6. Find something small to pry with. It should be plastic or you might scratch your paint.
7. On the side of the van where the tail light cover is flush (the far opposite end of where the bolts were), push a small tool (screwdriver?) under the edge of the cover and pry straight up. There is a peg that fits snugly into a hole in the van. The peg is attached to the tail light cover. With a small flashlight, you should be able to see the peg after prying it up just a little. The peg will pop out and that will allow you to change the bulb.
8. To replace the cover, start by popping the peg back into the hole, then replace the two screws. Finish by snapping the screw covers shut.
Oct 08, 2009 | 2005 Honda Odyssey
Picture goes big and small
Look for button on remote labeled size,aspect ,format or zoom. You can change the picture size to your liking. Different channels are broadcast in diffrent formats.
Apr 26, 2009 | Televison & Video
Freeze plug
Hello, yes over time freeze plugs can corrode over time and start to leak, I am currently building up a motor right now and when I removed the frost plugs they were starting to get thin from corrosion.
Mar 28, 2009 | 1994 Chevrolet S-10
1992 toyota paseo
The thermostat is located on the cylinder head, under a roundish housing, under the distributor cap. Just follow the big hose to the cylinder head. You have to remove the air intake collector to see it. If you do replace the thermostat, make sure that the one that you buy has a small "wiggle valve" on the outer edge of it. This bleeds air pockets from the system, and it is important that it is there. Additionaly, the "wiggle valve" should be installed with it pointing straight up (12 o'clock). This is critical. Regarding the sealer; the thermostat is sealed by an O-ring; no need for any sealer.
Remember to be careful, whilst draining the coolant, if it is hot.
Hope this helps, and Thanks for choosing FixYa.
Nov 14, 2008 | 1992 Toyota Paseo
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
