2001 Honda Civic Logo
Posted on Aug 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just recharged my ac and it worked and then
I had recharged it about 2 months ago and it worked until now. so I just recharged my ac again and it worked and then later that afternoon it was still working and then all of a sudden hot air came out and ever since then the ac has not worked
Anonymous
Level 3:
  • Master 466 Answers
  • Posted on Aug 19, 2009
Anonymous
Master
Level 3:
Answers
466
Questions
0
Helped
216394
Points
1594
You have a leak check all hoses A / C if you look at that oil is leaking somewhere or reload your system from A / C with freon 134 having UV reveal where the leak is
Someone please help? I have a 2005 chrysler 300 touring and when we bought the car 4 months ago the heater would work just the ac, and just the other night the ac broke or just stopped working
The A/C can be read with a scanner. But just a guess. The heat didn't work for maybe three reasons, first the heater core is plugged up, second someone bypassed it because it was leaking on the inside, third the blend door motor is bad, stuck on A/C.
The A/C could be low on freon, again. Most places put die in the system to check for leaks. Takes a black light to see the die, unless it was used in excess. You will need to recharge it to see if it is the problem. If you do it yourself, use at least one can of freon with die in it. If it happens again, you or someone can find the leak.
Where is the fuse located for A/C in the dodge nitro
I HAVE A DODGE NITRO 2011,2 MONTHS AGO THE AC WAS WORKING BUT THE HEAT STOPED WORKING. 2 WEEKS LETTER THE HEAT STARTED WORKING.A MONTH LATE THE AC/HEATER IS NOT COMING ON AT ALL. NO NOISE NO AIR NOTHING.
My 03 Nissan Altima's ac is blowing hot. I recharged it and 2 months later it blows hot again.
Did you ever think, that it was leaking refrigerant in the first place, and polluting the atmosphere.
If you need to recharge it,you must by federal law,recover the existing freon,repair the leaks,pull a vacuum,test that the system holds,then recharge.
You need to get this done professionally, by a shop equipped and trained to work on A/C
Ac seems to work great untill you accelerate,then you can hear the fan motor slow down, cold air stops. when acceleration is decreased seems to start up again. long trips are great except for the uphill...
Have the alternator checked,with the ac on high,and the headlights on,it should read 13.65 volts,to 14.25 volts,checked at the battery,if it is lower than this,replace the alternator,now if the alternator checks out good,have the compressor coil clutch replaced,it will be shorting out,.
2003 Neon air coditioning shutter
the AC servo that kicks up the engine idle speed when the AC is no..Is stuck or faulty...Replace it.
95 Nissan Maxima won't turn over
sounds like a starter motor problem, i would change that first
Ac not working right
You will need to add some coolant. Most auto parts stores and hardware stores have recharge kits. Purchase a kit with a gauge to prevent overfilling.
1994 lesabre AC
check your vacume lines
Top Honda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Honda Expert? Answer questions, earn points and help others
