Question about IBM ThinkPad 600X Notebook
Cannot detet larger hard drives
Ibm 600x .... cannot detect hard drive larger than 2.1gb ..but it can detect hard disk 2.1gb below ...
i already installed winxp on 2.1gb .its working king fine ..
how can i install larger hard disk ?
  • 3 more comments
  • jermyje Dec 02, 2007
    i did that already .. upate the bios , i downloaded it in ibm website.. still the same problem ...
    anymore option ?
    thanks in advance
    i install 4.3gb hard drive ...
    detected as 4.3gb ..
    but when i partition it ...
    it will detect as 2.1gb ....
    it can only partition and format ..for 2.1gb
    yes yes i can install windows .and the maximum capacity is 2.1gb
    windows xp ... i also try windows 98se
    it wont do .. theres no extra space in windows ...
    its only 2.1gb
    Genius:
  • 1,601 Answers
You need to update the BIOS.
Posted on Dec 02, 2007
SOURCE:
Error 174
Error 174 is hard disk drive failure, you'll need a new hard drive. But since that is a 2002 era system you might consider a new notebook too.
Jul 10, 2011 | IBM ThinkPad 600X Notebook
I have ibm deskstar 20GB. Problem is that i want to connect it as an external drive through usb connector. It detects but no partition is shown in my computer. i try all jumper setting define in manual...
In Windows 7, you can use Disk management to detect and create a partition on this drive if necessary.
Steps: 1. Connect your external drive through a USB port.
2. Click Control Panel - System and Security - Create and format hard disk partitions (under Administrative tools)
3. Your drive should appear in the table below. Select the external disk and Right Click on it. You will be presented with several options (Create partition, Format, etc.). Select whatever is applicable in your case.
4. Your external drive should now be detected by Windows 7.
Mar 23, 2011 | IBM Deskstar 40GV (DTLA-305020) 20 GB Hard...
After the boot screen I get a message that says "no bootable devices found"
Try to change your the boot sequence to HDD. If this doesn't change anything you have to reinstall your Operating System. Here is a quick method to reinstall your O.S., but after you reinstall it once:
http://www.fixya.com/support/r4213055-quickly_reinstall_operating_system
If you need further assistance, or have further questions, just leave a comment.
Thank you for using FixYa.
Cheers
Jan 24, 2011 | Dell Inspiron™ B130 PC Notebook
I have problem to install window xp in my laptop, which already have window vista....my notebook donot support to install xp..please tell is there any way to install xp...
What is your problem specifically? Is it that there is no hard disk detected when you try to install windows xp?
Try using third party software to detect the hard disk on your laptop
Try this link. It will basically give you your hard drive driver while installing windows xp. You will also need an external floppy disk drive if you dont have diskette drive in your laptop.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70477
Jan 24, 2010 | Computers & Internet
We have error in IBM Thikpad No 19990302 19990304 19990305
Check that the
operating system is
installed in the hard
disk drive. If not,
install the operating
system.
2. Reseat the boot
device.
3. Check the startup
sequence for the
correct boot device.
4. Check that the
operating system has
no failure and is
installed correctly
Nov 27, 2009 | IBM ThinkPad 600X Notebook
Which operating system supports IBM thinkpad 600x
All versions of windows except Vista and Windows 7.
You may find it difficult to purchase Windows version up and including XP.
You may need to install more RAM and a a 6 to 10 Gb hard drive.
The smallest hard drive available is approx 100Gb but the BIOS in the Thinkpad won't support a hard drive this large.
Nov 19, 2009 | IBM ThinkPad 600X Notebook
My ibm thinkpad r51 is not starting up just keeping giving me error message and it doesn't recognize the hard drive in boot. I have to take the battery to stop the system trying restart the window again...
It appears the hard drive is faulty.
Does the hard disk LED flash when the laptop boots up?
Go into the BIOS configuration and see it the hard drive is detected, (then Startup - Boot - and look at IDE HDD0 it should list the make and model of the hard drive).
If the hard disk is detected it still could be faulty. To test the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port.
If the computer sees this as an external hard drive and you can open the various folders and files then the hard drive is OK and the fault could be the disk controller on the laptop's motherboard.
If the hard disk is not detected the it is faulty and you need to replace the hard drive in the laptop and install Windows etc. to get it working again.
Jul 15, 2009 | IBM ThinkPad R51 Notebook
Error 00163 and 00173 on THINKPAD 600X will not let initialize
Dear that is not bios problem but fist you are format all drive in hdd and after install the windows program and your problem is resolve .................ok
Apr 08, 2009 | IBM ThinkPad 600X Notebook
IBM 600X DVD player
Did you try that DVD on other machine ?? Check on the property that its a DVD/CD drive.Incase more information I'm here to help you.
takecare.
Apr 30, 2008 | IBM ThinkPad 600X Notebook
Ibm 600x .... cannot detect hard drive larger than 2.1gb .. it can detect 2.1gb below ... i installed winxp on 2.1gb .working fine
ibm is providing their computer with a relevant bios updtes . bios updte will solve most of this type of problems
Dec 02, 2007 | IBM ThinkPad 600X Notebook
IBM ThinkPad 600X Notebook Logo
138 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
