Question about Dell M781S Monitor
Brown horizontal lines sporadically appearing on monitor
I have brown horizontal lines which appear on my monitor sporadically. This problem is getting progressively worse. I have tried moving the phone and all other electrical appliances which are near the monitor, but nothing seems to reduce the problem. I have brown horizontal lines on my monitor all the time and sometimes it takes over my whole screen and I can't see anything.
I had the same problem. I fixed it completely today. The horizontal lines disappeared. IT IS DEFINETLY THE DEVICE DRIVER. I confirmed my monitor model tyope (dell M783s) and downloaded the specific driver for this monitor.
I had to do these exact steps or did not work.
1) with the problem screen, disabled the display adapter under the Hardware/Device Manager settings.
2) Restart the PC
3) Boot will come up with brown lines still but the screen will low resolution of 600x800.
4) Then I installed the correct device display monitor driver onto the pc. ( you may need to scan for new hardware, then choose the directory with the new hard drive.)
If you need step by step... just reply back.
Posted on Dec 21, 2007
Horizontal lines across tv
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sony Televison & Video
Monitor
Try getting anything that may have a magnetic field away from the LCD (speakers, phones, any electronic product), does the problem persist?
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
Lines appearing in the screen
This could either be Electromagnetic Radio Frequency Interference or cracks in the screen. The first possibility is not a problem, simply move the monitor. The Second possibility requires the screen to be replaced.
Nov 07, 2013 | Baby Gear
ViewSonic VA2226w, horizontal light coloured lines through image regardless of resolution. They get worse when the monitor has been running for a while. Display otherwise working, powers up and down fine...
The lines appearing on the screen have nothing at all to do with the resolution. If the OSD display is correct (when the LCD is not connected to the PC), then the possible issue could be the RAM. Open the PC case and check if you have more than one RAM stick. Try using one RAM at a time and swaping RAM slots to see if the display is shown correctly. Make sure that the PC is turned off and power is disconnected before you remove/ install RAM. Most of the times lines appearing on the screen are due to faulty RAM. I suggest that you may also connect the LCD with some other PC to check if the issue is with the LCD or not.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 18, 2011 | ViewSonic VA2226W LCD Monitor
I have a HP Pavilion dv7-1270us laptop. My problem is that there is a sporadic, flickering horizontal white 'line' that appears and disappears on the monitor. The 'line' skips from bottom to top on the...
Here is a way to find out if it is the driver or not. Try plugging a standalone monitor into the VGA or DVI drive of the laptop and see if you are getting the same problem. The reason I suggested this is that you could have another display problem on your hands that has to do with the laptop display itself. That may need to be replaced for free (if the laptop is still under warranty) or just get another one on your own. It is pretty simple to remove but I suggest checking the HP site for the technical information on opening the laptop (if it is not under warranty).
Apr 17, 2010 | Computers & Internet
Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Apr 10, 2010 | HP w1907 LCD Monitor
Horizontal lines
i suggest you change video board .
Apr 19, 2008 | Samsung SyncMaster 152N 15" LCD Monitor
Horizontal lines
sometimes I encounter vertical lines below..... when i tap the sides it clears for a time being  but after a few moment again appears
Dec 06, 2007 | AOC 19LVWK LCD Monitor
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
I have exactly the same problem with the identical monitor, but I have not found any solution. It seems to be the monitor causing it because I can't see the lines, when I make a screen dump.
Jun 07, 2006 | Samsung 793DF 17" CRT Monitor
Computers & Internet Logo
294 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
