Question about Dell W2600 26 in. LCD Television
Service codes I have a Dell "W2600" lcd. it worked ok while i was in US.now i am in pakistan "Asia", and i have a problem with my Dell "W2600".1. there is no sound2. there is no color in pictur I need 'Service codes' to resolve this problem. Please Help me. My name is yahya My Email:- [email protected] I am working as (tecnical incharg) at THOMSON service senter, Headoffice branch in Pakistan at lahore # 72 commercial aria lahore cantt Pakistan.
    Genius:
  • Dell Master
  • 1,691 Answers
It is not service codes that you need. The set is not matched to the broadcast standard where you are located.
Many of the flat panel TV models work with a PC interface for the factory setup. If any parameters have changed with the age of the set, the fault is failing components, and not adjustments to be done. Over-compensating for a fault is not a fix.
As for your TV set, if I recall correctly, the factory service setup is done through an interface to a PC with the service software. The interface on some sets works with the HDMI cable, a USB type connector, or a serial connector, or the back cover has to be removed and there is an interface connector on the processor board.
Jerry G.
Posted on May 15, 2008
SOURCE:
Dell W2600 26" LCD Television. My standby light is
If you can Solder and know what capaciotrs,resistors are you can ,or you can exchange out the boards. Look for Bad Capacitors on the Power Supply Board, this is the most common problem on these TVs 1000uf 16v 2200uf 10v 3300uf 10v they will be vented or puffed up on Top.
Dec 15, 2010 | Dell W2600 26 in. LCD Television
Dell W2600 TV. Picture goes black after being on for 10 min.
http://www.shopjimmy.com/catalogsearch/result/?q=W2600
Back lights invereter or power supply. look for 24vdc on the power supply which is needed for the inveeter board.
look for bad caps in the power supply.
Nov 24, 2009 | Dell W2600 26 in. LCD Television
Dell no sound
I also have Dell W2600 TV and have sound problems
Dec 14, 2008 | Dell W2600 26 in. LCD Television
Dell w2600
there is no signal to the main board. it needs to be replaced along with firmware M016, REV code A07. that should do it.
Oct 13, 2008 | Dell W2600 26 in. LCD Television
Dell W2600
you can get a 10uF capacitor from any scrap board, but make sure it's the right working voltage.
10uF means it is 10 microfarads
the 50 bit means it is rated at 50 Volts.
I hope it works out for you ok, because Dell are a waste of time.
Aug 12, 2008 | Dell W2600 26 in. LCD Television
Dell W2600
you are loosing communication signal from remote to TV. The main board is responsible for the communications. its the board with the most connections located on the back under the back cover and top cover of the circuit boards. Replace that board, u should be ok. Do a ebay search for main board for dell w2600
May 21, 2008 | Dell W2600 26 in. LCD Television
Dell w2600 lcd tv
For a used part, or a complete used set like yours, try eBay. One thing to consider, is if someone is selling a used set there is a chance that its faults, or potential faults may be the same as the one that you have.
Jerry G.
May 15, 2008 | Dell W2600 26 in. LCD Television
Schmatic for Dell w2600 lcd tv
I've tried to get a service manual and Dell will not provide. The only way to fix this problem is to send it to a company called DECESIONONE(If you want to spend a $265 flat fee + labor + parts) Dell sends a lot of their repairs to them but they won't give out a manual either.
Apr 07, 2008 | Dell W2600 26 in. LCD Television
Dell W2600 26 in. LCD Television Logo
142 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
