Televison & Video Logo
Posted on Aug 19, 2009
No picture or sound on my luxor tv 32765
No picture or sound
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1541
Points
6
Luxor tv no picture no sound
1helpful
Luxor tv keeps losing picture
Luxor is a budget brand made in Turkey for the Swedish market. You likely have failing components, probably electrolytic capacitors. You put the set on, they warm up and fail. They can be replaced but you are better to invest in a new set by one of the major makers like Samsung, Sony or LG. A quick search shows they have some history of faulting
https://www.google.com/search?q=Luxor+tv+keeps+losing+picture
My Luxor tv has no picture only green and blue stripes, but has sound
Pull up the menu and see if it looks normal, if it doesn't chances are you have panel issues and it's not repairable, if menu looks ok it could be either the main or tcon, replace the tcon first as it's much less costly
No Picture on TV - we have sound but blank screen?
Your TV might have either loose connections or damaged cables or an inactive power sources might be the cause of the problem on your TV. Your TV could also be set on a wrong input. Make sure that your TV is set to the proper input to avoid this problem. Firmware update issue: Your TV screen maybe having a black display on the screen due to the firmware not being up dated.
Sound and no picture ?
If you can also change channels on it, then it will be most likely the T-Con board that has a fault on it. It's quite a common fault these days. In fact I have told three other people just now of the same problem all on different TV's.
If you know what you are doing you can replace the board quite easily most times. Providing you get the right board.
I HAVE HAD MY LUXOR 52 INCH FLAT SCREEN TV ,BOUGHT FROM ASDA APROX 5 YRS AGO,,, IT HAS NOW STOPPED WORKING,,, THERE IS SOUND BUT NO PICTURE
Did you shine a flashlight behind the screen to see if the image is present, if so the backlight is burned out.
My relative in UK send me a luxor tv here in the philipines..THE SOUND IS OKEY BUT THE PICTURE IS BLUERD..SOMEBODY CAN HELP ME
power voltage drop of 10 volts where you are
The more significant difference is that 60Hz systems usually use 110V (120V) or thereabouts for the domestic power supply, while 50Hz systems tend to use 220V, 230V etc
if found to be the issue and no slide switch to change on the TV somewhere
you may need a converter to equal 60 hrz
sound ok
any luxor should work there
i am thinking local signal signal
cable or roof antenna in the place
if auto auto tune or manual tune wont give a picture
not sure if a converter is needed
i am thinking try
. if coax cable old
re do all connections or replace with new cable
could get a TV antenna guy to reset the roof direction signal
if no better ..have doubts but
different channel wave lengths or faulty signal receiver
does the user manual cover world wide distribution or support
information
no online luxor TV support contact number
just a wiki information link
a long phone number ???
the internet email address is looping [email protected]
http://luxorhelp.com/luxorhelp/wiki/index.php?title=Tech_Support
How do you connect luxor 50inch smart tv to bluetooth. My phone finds the tv but i cant see how to type in pairing code
How do you connect luxor 50inch smart tv to bluetooth. My ...
www.fixya.com/.../t26003543-connect_luxor_50inch_smart_tv_bluetoot...
4 hours ago - first turn on bluetooth and goto bluetooth settings and goto authentication and turnoff it.then bluetooth is connected ... when it asked for the pincode ...
40inch luxor tv - YouTube
? 0:29
https://www.youtube.com/watch?v=XrVJZtkV4sc
Aug 25, 2011 - Uploaded by jasonmctavish24
I bought this tv, now the picture is good for blu rays and my xbox etc. But it says 'DAVE' in really faint ...
Dec 11, 2015 • Cell Phones
I just got a new TV luxor lux221. I have a sky box. I have sound but no picture. How do I get a picture
SCART usually picks up on an AV socket or channel 0.
You may need to change your input source on the remote control until the on screen display reads HDMI.
That's how it works on my Mum's Sony Bravia.
Luxor tv no picture or sound
Connect the TV to another power outlet that you are sure, works. Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
