Neff W4380X1 Front Load Washer
Problem for Neff W4380X1 Front Load Washer
Washing machine won't stop filling
By martysmith on Aug 19, 2009
Neff front loader wont stop filling with cold water runs ok if you turn the water off at the right time?
Recently went from tank water to mains pressure could that do it?
Thanks
Marty
Best Solution
posted on Aug 19, 2009
Helpful)
justaskjoe
Rank: Guru
Rating: 85%, 2217 votes
Hello Marty, there are only two possible reasons for your trouble.
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Neff W4380X1 Front Load Washer
Questions and Unsolved Problems for Neff W4380X1 Front Load Washer
Do you recommend Neff W4380X1 Front Load Washer?
Answer
Answer
I have washed the drawer, scrubbed the water outlet with a touthbrush even and I still cant get it... (More)
Answer
don't have the manual and don't know how to use the timer mode
Answer
I have a Neff W4380X1 washing machine that will not spin. It bypasses the spin cycle, it drains... (More)
Answer
The machine was going through a wash program when it justed stopped and the counter continued to... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Van Nuys, CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
