Question about Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61 i
I recently replaced 1 fans and a color wheel now about 1 month later my lamp blew would this be related some say after replacing a color wheel is normal to have your lamp blow
  • 179 Answers
It is not related to the failure of the fan or color wheel by anything other then the age of the set..the lamp has a normal life of 4000 to 6000 hours and since your set is around 3.5 years old it probably has that amount of time on it..the lamp is consumer replaceable and many places sell them..the lamp number should be on a small sticker on the side of the set
Posted on Dec 02, 2007
Samsung hln617w TV Dlp lamp won't turn on already replaced lamp, ballast, color wheel
It sounds like the main power supply has a bad capacitor. its a typical issue with a lot of electronic. look on the main power board that the outlet cord comes in to the TV and check all the cylindrical components for swelling, leakage, or singe makes.
Dec 13, 2013 | Samsung HLN617W 61" Rear Projection HDTV
SAMSUNG HLN617W turns on, picture is perfect, then picture turns off after a couple minutes.. sound still works.. hear a noise that sounds like a fan starting up and shutting off. Picture will not turn on...
It's not the lamp, most of the time they suspected it and the fan gone to malfunction when encountered this kind of symptoms but the fault came from the color wheel. You have to replaced it to resolve the issue.
Oct 07, 2011 | Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
I've recently replaced the bulb, thinking it would solve it from turning off (powering down) every so often. Replacing the bulb slow the problem down, but as of late, the problem has worsened. I've also...
Ballast board it is what powers Lamp on and CK the Lamp Fan if it stops and is not keeping Lamp cool then set will shut off.Fans are not to stop running while set is turned ON. Encompass Parts Distrubtion
1-800-638-3328 they might have it in stock.
Feb 16, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617w non power up
Most of the time when these sets won't turn off it's caused by the DMD but check the color wheel connectors first, especially the flat ribbon cable. Make sure it's in the connector in the correct direction, only has contacts on one side and make sure the ribbon is not torn.
Mar 03, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Will my lamp still turn on if my color wheel needs replacing? How will I know if it is my color wheel or ballast that needs replacing??
If the color wheel doesn't start rotating or get up to the proper roatation speed then the lamp will never fire.
Jan 05, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W
If it is it will be the first I've heard of one shattering... The CW spins at 7200 rpms and at that speed anything is possible. What color is the glass?? Clear and it's not the CW.. My bet is on the lamp. Does the lamp fire up?? You need to do a bit of investigating and let me know and I'll try and help..
Good Luck!
Dec 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
3 blinking lights no visual...just bought new color wheel
recheck those plugs from color wheel to dmd bd, when was the last time you replaced the lamp?
Oct 18, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Color wheel replacement
closed position is short. Check color wheel ribbon connector, contacts face to back of set.
Sep 13, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
96 people viewed this question
Jerry Greenberg
Jerry Greenberg
