Question about Mintek DVD-2580 DVD Player
Dvd not reading
I load dvd and loading and keep getting no disc what is wrong
  • WichitaVOR Feb 22, 2008
    When I try to load a disc I get NO DISC. I removed the cover and tried loading again, and again NO DISC, and noticed the disc is not spinning. I don't know for certain that it's supposed to, I'm only assuming that it is. I checked voltage across the drive motor, no voltage. Good continuity from drive motor to plug on circuit board.
  • 593 Answers
The spindle motor magnets have started to flake, causing the DVD's to slip. like on a slip mat. You need to take the cover off and remove the flaky magnetic particles on the magnets that clamp onto the DVD's. You can put a very light coat of rubber cement on the lower magnet and let it dry completely, this should give the lower magnet/spindle motor some traction on the disc and get it spooling up in the correct amount of time.
Posted on Jan 03, 2008
5 Suggested Answers
SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Posted on Feb 02, 2007
SOURCE: wrong disc displayed
try to find crack for region code and set it up to be region free. that should do the trick.
Posted on Sep 25, 2007
Jay_Sav
  • 93 Answers
SOURCE: dvd keeps saying loading but won't play
Sounds very much like you have a either a dirty laser, or a laser unit failure. Put a cleaning disc through the machine, and see if it improves. If not, then you need to either have a new laser fitted, or a new machine.
Posted on Mar 14, 2009
vortash
  • 431 Answers
SOURCE: It won't read disc. After loading, it reads No Disc
Sounds like a read error fault , possibly a laser malfunction sometimes dirt on the lens will cause this try a good CD cleaner if this is no good I suggest a free engineers estimate at least you can then ask again on here how to fix it . My honnest guess is either a duff laser or software corruption . I have known seating of the tray to cause this also not returning fully back into machine , usually caused by children and alien matter ? shall we say such as choclate or M&MS kids shove stuff everywhere ? bless them lol
hope this helps Regards Vortash
Posted on May 12, 2009
Ixhave amemorex dvd player recived from friend keeps reading wrong disc or loading for long periods
If a DVD has been cloned the speed and angle of the laser may not be compatible with the players read head. If you are using Commercial DVD's then the alignment is standard and should work OK. If the player is CD\DVD only you cannot play Blu-ray discs.
Dec 25, 2013 | Televison & Video
Loaded dvd and now it won't play and it won't open/close
Hi i have had a similar problem to this before. I never could get it open without force, but if it is only the disc you are after then i would recommend forcefully removing the disc with a knife opening the dvd slot or by unplugging everything and unscrewing the dvd player altogether there might be something lodged in the dvd player preventing it from reading or opening. Be sure to press the power button when you unplug as it may contain electricity still.
Jul 18, 2010 | Daewoo DV6T844B DVD Player/VCR
I don't know if my first REQUEST for Assistance was received, at any case, I REQUESTED to find WHY my GO.VIDEO COMBO Player is NOT READING any of my blank DVD DISC( SONY, IMATION, MEMOREX, DVD+R ), IT KEEP...
If there is nothing on the disc, it will read, "no disc". It will only read and/or identify discs with media loaded or burned onto it. Your unit is a player, not a DVD+R (recorder). Can record VHS, but not discs.
Jun 30, 2010 | GoVideo Go Video DVD/VCR Combo
Dvd wont load up.. keeps sayin no disc
The most common reason for the DVD not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your DVD plate, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your DVD including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your DVD on your TV Combo going again!
Hope this help...
Jun 05, 2010 | Televison & Video
Disc won't load. Get
there a problem of the DVD disc...
try to insert another disc..
if "wrong disc" message appear again...
insert the Disc Cleaner of the DVD.. so that you can clean the lens surface of the DVD Player...
Oct 23, 2009 | Televison & Video
Keeps saying wrong disc
first i downloaded the manual and read it through... it mentioned wrong disc but did not give any solution so i rang Teac and they told me it was a malfunction and by the time i paid for them to look at it i could buy a new dvd..... so i am going to buy a new dvd..... not really a solution but the only one available
Jul 06, 2009 | Teac DV-3500 DVD Player
Wrong disc problem
This is a known problem - there is no fix - if you call coby customer service they will tell you to try a dvd lens cleaner -this will not fix the problem. Best advise - throw it away.
Feb 26, 2008 | Coby DVD-224 DVD Player
No Disc keeps popping up
yes , the eye is not reading correctly, if it is still under warranty i'd have the factory replace it, if not , any tv repair place can help u out, hope this helps jason
Dec 28, 2007 | Sampo DVE-620 DVD Player
I have a trutech dvd player modelT600-D. Loading only..
It clicks and keeps loading after a while it says"wrong disc," I just have it for a few months and it acted like this. I checked inside, it seems like everything is correct but it just clicks and never spins. or it says error disc... i just bought this GRRRRRR!!!!!!!
Dec 09, 2007 | TruTech TT320
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Mintek DVD-2580 DVD Player Logo
93 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
