Question about Sirius Satellite Radio Receiver
Antenna not conecting to radio - Sirius Satellite Radio Receiver
  • mercedes69lo Nov 24, 2008
    It says antenna not detected. What could be the reason.
    Problem Solver:
  • 35 Answers
I would take it to radio shack. Reason is that you can beat your self up over no signal and sit there and waste time on trying to think I fixed it ALMOST! In fact that is not the solution. Is your antenna catching as it is incerting into the femle connection...slightly snapping in or not? Is it falling out? Either way you may have radio shack test this part for you.
Posted on May 10, 2008
SOURCE:
When it is in tuner mode the subs ant speakers work but when u swich it to cd only the subs work
on the factory radio conection you need to power up the factory amplifier, for any rason is conected to the power antenna wire (blue), you need (blue/white) from your aftermarket radio.
Sep 26, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Dose it work good like i live in a prtty good nabor hood dose it get good distance will it conect withe other bigger cb radios
Typically, this type of handheld has a useful range of approximately 1-2 miles. This distance will be increased with other radios being mobiles and base stations. Distances of 5 miles is possible if the other person has a good base station antenna. I would not expect much from the stock rubber ducky antenna.
JTRadiojunkie
Aug 30, 2010 | Maxon HCB-10C CB Radio
My antanna light keeps lighting up. ive checked all conections and even put tin foil between all the conections from my cable threw my spring and my antanna
cobra 29 red light is normal but if you have two red lights that means that your swr is to high. take all that stuff you put on the antenna connection,get rid of the spring and adjust your antenna using an external swr meter. Get the swrs down around 1.5 and the second red light ,which is the AWI or antenna warning indicator,will also go out.
Jun 14, 2010 | Cobra 29 LTD CB Radio
Where is the radio antenna connection located in the trunk
i have mercedes 500 sel radio antenna i can not conect it to move the antenna and bring voice from radio
May 27, 2010 | 2003 Audi A4 Cabriolet
Where is the antenna conection jack.
There has to be a lead on radio unless it is totally wireless. Either with a plugin or electrical junction. trace down antenna wire to backside of radio it is there or remote via wire
Mar 09, 2010 | 1996 Ford Taurus
Problem getting signal. Antenna conected, but still nothing
Please make sure the the Antenna has a good earth and that the SWAR is as low as possible, 1.1. is best but anything below 1.7 is good.
Jul 11, 2009 | Cobra 29 LTD CB Radio
Roady xt Antenna Problems
when it reads antenna it means there something wrong with either the connection or the antenna itself, it could be the location of the antenna or the antenna is going bad. if there is no obstructions on the car blocking the antenna i would advise purchasing a new antenna. you can get one at http://shopdelphi.com/consumers/satradio/xpressrc/
Feb 07, 2009 | Delphi Roady XT XM Radio Receiver
I can't hear FM on the Radio of my mitsubishi Galant 1998
The antenna lead may be the cause of this, or a poor ground to the antenna or radio.
Aug 27, 2008 | 1998 Mitsubishi Galant
Can't Get A Radio Signal When I Connect A Cox Cable
Hi...
Some cable companies dont put the FM band on cable and some others put an FM trap (which kills the FM band) in line with the cable.
One of those is your problem.
You'll need to buy a FM antenna
Jul 25, 2008 | Sony STR-DE597 Receiver
Sirius Satellite Radio Receiver Logo
110 people viewed this question
Top Sirius Audio Players & Recorders Experts
Anthony Ward
Anthony Ward
Larry Alex
Level 1 Expert
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
