Question about Belling DB3 Dual Fuel (Electric and Gas) Kitchen Range
Belling DB3 Duek Fuel Cooker
I Want to clean the glass on the inside of oven door, between the glass
  • unerd Jan 03, 2008
    Hi, i have the same problem with the same oven, there dont see to be any screws/clips immediately replated to the glass plus, it can't slide out the top as it's blocked by the oven, any help?
  • Anonymous Mar 30, 2014
    WHER CAN I BUY A REPLACMENT PART
  • 833 Answers
I'm not familiar with this unit exactly but I'll give you some guidelines. You have a double layer or more of glass and the glass inside the unit is your problem. Generally, cleaning glass on ovens is no problem if you use cleaners that leave no residues, don't stress the glass and don't scratch it. Prepare a flat surface covered with newspaper to clean your glass. You may use a blue glass cleaner, a scrubby or VERY fine steel wool. Never use any cleaner which leaves residue. Use lots of liquid and very little pressure. Finish with a soft cloth. Clean the inside of the door and any of the gasket you can get to. Use only a sponge and detergent unless the area is really a mess.
First, be aware that the door is spring loaded and as you remove items, it will tend to snap closed. Note that there are probably screws that are near the base of the door, probably accessed from below. Remove these first. Then, remove side screws and carefully remove the panel holding the glass. This probably comes out into the room. There is a danger that the glass is not secured inside the panel so have the door fully open when 'dropping' the outside panel. Note the positions of all clips. You may even want to take a digital picture or two. When reassembling, never overtighten anything! All parts should lay flat and insert easily. Get assistance with reassembly...you'll need another pair of hands.
Posted on Dec 03, 2007
Above the door on the oven frame thre is a sliding retaining plate held by a screw in a slotted opening. Release this screw and slide the plate to the right (for the main oven door) then the door can be lifted out. Once the door is out the glass can be slid out for cleaning. Be careful to replace the the glass face in the correct direction to the oven. Hope this is helpful.
Posted on Apr 09, 2008
Tip
Common faults with Belling DB3 Dual Fuel Range
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling DB3 Dual Fuel (Electric and Gas)...
Where can I buy spare parts for belling db3 dual fuel
Hi, it depends what parts your after but eBay is pretty good for parts. Element rings etc.
Jun 02, 2014 | Belling DB3 Dual Fuel (Electric and Gas)...
Belling db3 oven
yes its most likely the element they are common in burning out ....because the fans still running,
Dec 17, 2007 | Ovens
Belling DB3 Main oven door falling off its hinges
The same thing is happening with my oven. I have found a web page which sells the parts and removing the door and replacing the hinge would be easy enough. The design of the door however, may mean the problem just happens again.
http://www.espares.co.uk/part/cookers-and-hobs/belling/db3/p/1092/154/0/547474/550894/door-hinge.html
Nov 23, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Belling DB3 Control Panel
Not easy. Briefly, in addition to the screws you mention, the cooker side panels need to be removed to give access to removal of the control panel side clamps. Then the indicator lamps have to be disconnected, and timer etc. buttons have to be pulled out to allow removal of the the control panel. Then the main control unit (timer etc.) needs to be unscrewed from behind the control panel.
Replacement is reversal of above.
Oct 27, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Instruction Manuals
This seems to be a British company. Suggest you write to them at www.belling.co.uk/ They have a contact link.
Sep 04, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Belling db3 duel fuel cooker
they just pull out but need a fair bit of force
Apr 24, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Belling DB3 Dual Fuel (Electric and Gas) Kitchen Range Logo
497 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
