Question about LG LRFD21855 Stainless Steel French Door Refrigerator
FF error code
I am getting a ER-FF which is for the fan so the fridge and freezer both don't cool. I called LG and they told me to unplug the unit for three hours. I plugged back in after 4 hours and had same problem. Called back and they told me that I had to wait longer and that was the only thing it could be (98%). After 15 hours still not working and no help from LG.
    Champion:
  • 210 Answers
FF error code - cc82481.jpg The cause of the problem is here on the back wall, water gets trapped and freezes, over time a big ice ball will form. Defrost unit and cut off the insulation here, the water can now longer get trapped. Problem solved.
Sgt 48
Posted on May 31, 2008
One other thing to check is a buildup of ice stalling the fan, not necessarily a defrost problem.
Posted on May 18, 2008
    President:
  • 878 Answers
John, sounds like the evap fan motor quit. Now you have to determine whether it's the board or fan motor itself. You should have a tech sheet on the bottom or on the back of the plate covering the main board. You want to see if you have 115V going to that motor from the board. I only have a diagram for a top mount but the boards should be close. Your board should be on the back, left side. On the board you will see con1 (connector 1). The blue wire should be your nuetral. Now look on your schematic for the F-fan, follow it up, on mine it's connector 2 pin 5, grey wire. With a meter measure the voltage between the blue and grey wires. It should read 115V. If you have that voltage, the board is ok, you need to replace the evap fan motor. If you don't have that voltage, your board is the problem. Just make sure you don't have any ice blocking the fan blade itself. I looked your board up on the net and it runs around 76.00 at repairclinic.com. Let me know how you make out. Catriver.
Posted on Dec 02, 2007
LG lfx31945 REFIGERATOR...FREEZER NOT COOLING. ER FF CODE
LG Help Library: Error Codes - Refrigerator ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library
  1. Cached
  2. Similar
Feb 26, 2018 - FF Error Code. A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup. ... If you notice frost buildup along the walls of the freezer compartment, the leveling and door alignment of the refrigerator will need to be checked.
SOLVED: Error Code ER FF - Fixya
www.fixya.com/support/t121701-error_code_er_ff
  1. Cached
  2. Similar
Oct 18, 2006 - Error Code ER FF Our refrigerator is 1 year & 1 week old. A few days ago it started making a noise that sounded - LG LRBC22544 Bottom Freezer question. SOLVED: Error codes Er rF 10 posts 14 Nov 2013 Lg lfx31925st 00 code er ff 10 posts 21 Sep 2013 SOLVED: How Do You Repair An lg lfx31925st error ... 11 posts 16 Nov 2012 SOLVED: LG refrigerator lrsc26944tt error code ER FF 11 posts 25 Jan 2009 More results from www.fixya.com
FIXED LG refrigerator error code Er FF - ApplianceBlog
https://www.applianceblog.com/mainforums/.../8302-LG-refrigerator-error-code-Er-F...
  1. Cached
  2. Similar
Mar 31, 2007 - Hey guys, This LG has me stuck. I have run the smart board entirely through the diagnostic mode and it says everything is OK - hours later a code comes up "Er FF" Model: LRSC26922TT Serial: 407KRPV00464 I have had no luck finding any useful info on the web.... nothing but horror stories about LG. FIXED LG Refrigerator LFXS32726 - Error Code E rF 3 Aug 2016 LG LFX31925 drain iced up (ER FF code) - How to remove freezer ... 24 May 2016 FIXED LG LFX31925ST Giving error code ER RF 3 Sep 2013 Kenmore elite refrigerator error code er FF 3 Mar 2013 More results from www.applianceblog.com
LG REFRIGERATOR REPAIR. HOW TO REPLACE FREEZER FAN. FF ...
9k=? 4:42 https://www.youtube.com/watch?v=Yiifd2sTrZI
  1. Similar
Jan 3, 2013 - Uploaded by SOCALAPPLIANCE LG Refrigerator repair. FF error code / ee ff . Bad freezer fan. Bad evaporator fan. How to repair an LG ...
Mar 22, 2018 | LG Refrigerators
My LG LRFC22750 shows an error code ER FF and my refrigerator is getting warmer while my freezer is still cold. What should I do to fix it.
The FF error means that the freezer fan isn't working properly. The motor may have malfunctioned or ice has built up and is preventing the fan from turning. Unplug the refrigerator, remove the food to other cold storage locations (cooler, another fridge) and allow it to defrost. Dry up any moisture around the unit. Plug it back in and allow it to cool for 4 hours. If the error returns, the refrigeratr needs service.
Generally, you need to replace the fan motor and the motherboard in the refrigerator. (The motor keeps trying to spin until it becomes damaged, even if the problem was ice build up.) The fan pushes the air into the refrigerator to keep it cool. The freezer is more directly cooled by the refrigerant cycling through the unit. If your refrigerator is still under warranty, contact LG. (There is a 1 year warranty on most of the unit. The sealed refrigerant system has a 7 year warranty on those parts.)
I hope this helps.
(Unfortunately, I do not have a source for parts.)
Mar 26, 2015 | LG 22 Cu. Ft. French Door Refrigerator,...
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
What does the message "Er
Hi
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. This can be caused by frost accumulation on or around the freezer fan. Unplug the unit for 3-4 hours to allow this to melt off. If error code persists, call Customer Service.
Please get back to us if you have further query or else please accept the solution.
Sep 02, 2011 | U-Line BI-95
Refrigerator displaying error "ER FF".
Hope this helps.
Jun 10, 2011 | LG LRFC25750 Refrigerator French Door
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
The door panel says "Er FF" and now it is not cooling
Er FF - Freezer Fan Error - This can be caused by frost accumulation on or around the freezer fan. Unplug the unit for 3-4 hours to allow this to melt off. If error code persists, call Customer Service.
Oct 30, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge is no longer cooling. ER where the
Sounds like the FF(Freezer Fan) is wearing out or is worn out. This assembly supplies the circulation for the freezer as well as the refrigerator. When is slows down or stops the circulation of cold air to the refrigerator is the first thing that is effected. The minimum cost to replace this assembly is around $300.00
Jul 10, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
FF error code
The ER-FF problem that you have is: ERROR -FAN FREEZER so it means that you have a problem with maybe the fan motor or if it's a bottom mount freezer maybe ice built up on the fan motor so it's blockin the fan motor.
Hope i helped u a little bit ! :)
Francois Pelosse
Jan 19, 2009 | Freezers
LG LRFD21855 Stainless Steel French Door Refrigerator Logo
186 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
