Question about Denon DRA-397
Panel lock touch any button on the unit and it says panel lock...how do disable this feature?
  • 1 more comment
  • Anonymous Feb 03, 2008
    I have the same problem. i tried holding the speaker a A & B buttons while powering on, which is supposed to reset the microprocessor, but the display just went back to 'panel lock on'. Makes the denon unasable. Anyone have a solution?
  • Lefty L Apr 12, 2008
    Same problem - any suggestions?
  • espoir Apr 26, 2008
    I have the same problem. i tried holding the speaker a A & B buttons while powering on, which is supposed to reset the microprocessor, but the problem persist. This problem makes the denon receiver unasable.
    I think it's a manufacture problem.
Press mode and speaker b while turning the receiver on. the reset the processor..
Posted on May 15, 2008
SOURCE:
How do I reset anti theft in my 2002 ford f150
tis a process so here goes..... Central Security Module (CSM) enable/disable mode allows autolock feature to be turned on or off. To enter enable/disable mode, close all doors. Ensure ignition switch is in LOCK position. Perform the following steps within 30 seconds:
Turn ignition switch from LOCK to RUN position.
Press power door lock switch UNLOCK button 3 times.
Turn ignition switch from RUN to OFF position.
CSM module should chirp horn indicating CSM module is in enable/disable mode and ready to accept program changes.
Press power door lock switch UNLOCK button once to command CSM module to toggle autolock feature on or off. Press power door lock switch LOCK button once to enable/disable autolock feature. CSM module will chirp one time to indicate autolock has been disabled.
CSM module will chirp once, followed by a longer chirp to indicate autolock feature has been enabled. Press power door lock switch UNLOCK button once, then turn ignition switch to OFF position to exit enable/disable mode. CSM module should chirp once to verify a feature change. Best to you.
Dec 31, 2017 | Ford Cars & Trucks
Code for CL
On many washers, CL is child lock. This feature locks the most of the front panel buttons; it's useful when you clean the control panel. It also keeps small children from starting the washer with a pet (or sibling) in the unit.
Look on the control panel for a small lock icon or the words Child Lock. This will be in a much smaller font than most of the icons/text on the washer. You need to press and hold the appropriate button or pair of buttons to disable the lock. If a pair of buttons are used, the lock icon will be in the middle of a line between the buttons.
Please add a comment with the specific make/model of your washer if you would like more information about cancelling the lock. On my washer, the CL will remain on even if you unplug the washer for several minutes.
Jun 12, 2017 | Washing Machines
My dryer ran through the dryer cycle turned off. Hours later I noticed the "control locked" light is on and the dryer will not even light up to set program.
Hello. I really need the make/model number to help you accurately. However, depending on the model dryer you have, look on the control panel for a button or buttons that have a "key" symbol or the word "lock" underneath. Normally, you would hold the button down for 3-5 seconds until the lock light goes out. This is the indication that the control panel is unlocked and normal operation can be initiated. The manufacturers put a panel-lock feature on the units to prevent "busy little hands" or others from changing settings, for unattended safety, etc. Dishwashers, ovens, ranges, and other appliances also have locks for the control panel. If your dryer initiated a control lock by itself, this would indicate a shorted button on the control panel--soft touch buttons and glass touch-control panels are notorious for doing this. If I have the model number, I can usually provide the part number and/or procedure for getting into diagnostic mode to see any stored error codes(if any) which would help pinpoint a problem. I hope I helped you!
Oct 03, 2015 | Dryers
Dishwasher won't start when start button is pushed. Control lock button flashing.
Hello. From what you're describing, you've locked yourself out of using the dishwasher, lol. Look on the control panel for a button with a "key" symbol beneath it or the words "control lock/5 sec" or something to that effect. What that means is you have to push and hold the button for 5 seconds or so until the lock is disengaged(not a physical lock--it allows operation again from the keypad) The purpose of the control lock is to keep "little busy fingers" or others from changing the settings or starting the washer without supervision. Someone may have inadvertently touched the key for too long and initiated the lock feature. I see it all the time as a tech in the field. This feature is especially important on the touch panel models of dishwashers and the glass, touch panel ranges for obvious reasons.(I nearly removed my fingerprints on a touch panel range while servicing the above-the-range microwave.) I hope I helped you!
Sep 20, 2015 | KitchenAid Dishwashers
Cannot disable panel lock
http://denon.custhelp.com/app/answers/detail/a_id/15/~/panel-lock
This may not work, as it appears to be for a different model, but it states:
How do I unlock the panel on my DRA-397?
Power the unit off using the On/Off button. (not the larger On/Standby button) While the unit is powered off, press and hold the "Speaker B" and "Mode" buttons. Without releasing those buttons, power the unit back on. This will unlock the panel.
Jan 26, 2018 | Denon Audio Players & Recorders
I have a double draw dishwasher . the child lock key comes up and the dishwasher does not start
The lock button activates/deactivates the Keylock or the Childlock functions. This button has either a key or a padlock icon. I believe that on this model it is a padlock
Keylock
The Keylock feature disables all the buttons on the control panel.
To activate, press and hold the button until you hear one beep (3 seconds). The symbol
appears in the electronic display when the Keylock feature is activated.
Childlock
The Childlock feature locks the drawer and disables all the buttons on the control panel.
To activate, press and hold the button until you hear two beeps (5 seconds). The symbol
appears in the electronic display when the Childlock feature is activated.
To cancel the Childlock feature, press and hold the button until you hear one beep and the
symbol disappears from the electronic display.
This information can also be found in your product's Use and Care manual. If yours has been misplaced you can download or print one from Fisher and Paykel's website. http://www.fisherpaykel.com/customercare/userguide/index.cfm
If this doesn't work... And I've seen these units do some odd things. Try unplugging it for about an hour (if plug is not under sink you can turn of the breaker that powers the unit). Then plug it back in and see if that works. These dishwasher like many modern day appliances have solid state microprocessors in them which sometimes need reset just like a computer.
Hope this helps.
May 17, 2011 | Fisher and Paykel 23 in. DD603H SS...
LG touch phone. Touch screen keeps blanking out, it that the touch screen will not work. Screen shows everything but the touch of the screen does not work. I have took out the battery and replaced it. It...
when phone is idle, the auto lock feature locks out the screen. you can set the time when lock engages or disable completely. To unlock, press top right corner button or use touchscreen options by sliding finger up from bottom to top or press unlock button on bottom of touchscreen
Feb 19, 2011 | AT&T Cell Phones
How do I use the Child Lock option on Samsung WF-B1456GW?
You can use the child lock feature in 2 ways.
1. To prevent operation of the washing machine when no wash cycle is running
To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
2. To prevent any tiny fingers from tampering with the machine while a program is running.
After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Feb 09, 2011 | Washing Machines
I want to disable the "click" feature of the touch paD on my HP Pavilion DV2000 laptop. It is too sensitive and I want to only click using the buttons. Can you help me find the settings ?
Some laptops have a button directly on them to disable the touchpad feature, if you do not have one of theses. Look in your control panel for touchpad software. Synopsis TouchPad software is one of the more popular softwares, If you see this red ICON in control panel, open up the configuration window for it and there you will able option in there to disable the tap click.
Nov 02, 2009 | HP Pavilion dv4000 Notebook
Kenmore ultra wash dishwasher
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Denon DRA-397 Logo
488 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
