Question about Zanussi ZWD1470W Front Load Washer / Dryer
E20 message My washer dryer keeps stoppping in the drying cycle, beeping and displaying an E20 message. If I restart the cycle it'll go for a while and then stop again with the same message. This only happens with the dryer though, not on any of the washing cycles. My washer dryer is a ZWD1471W Jetsystem Progress 1400 spin, 18 months old. I got an E20 message first when using the dryer . Then I found the washer wouldn't work. When I check the filter there seems to be no blockage, but after I do this then the washer will work for 1 or 2 washes, but then sometimes the E20 message comes back. This is generally rectified by opening up the filter, even though their is nothing their blocking it still.  Sometimes I can get away with using the dryer once, but then the E20 message comes back. The machine seems to be getting over hot on the top right side panel at the back. Ive checked all the outlet hoses and pipes and they seem fine.
The filter is blocked. Disconnect your power source. Open the panel. Have a towel or wet vac handy and a screw driver. There is a silver ring circling the drainage hose with a small screw on top. Loosen the screw. Pinch the hose on top and let water drain to wet vac or towel. Completely remove the hose from it's housing. Reach your thumb and index finger inside that same hose and pull out the filter. It looks like a small plastic cup with holes in it. Clean it out, wash it. Use your fingers or dry vac hose and feel the bottom of the inside of the hose where the plastic cup came from. Remove any debri that excaped past the filter with fingers or suction with hose til you can feel with your fingers that the bottom of the inside of the hose is clear. return the cup back inside the hose. Put the silver ring over the lip of the hose then place the hose back on it's metal housing which is attached to the machine. Make sure the hole is secured around the entire metal (if not you will get leakage). Tighten the small screw, pull down at the hose making sure it will not come off with the pressure of the water. Clean up any leakage. Close panel and I promise you, your problem will be solved. Good luck, from Cheryl AlAlexander
Posted on Jan 18, 2008
Dryer beeps during dry cycle
if the dryer is beeping on it's own most likely you have a bad board part WP8563974
Oct 28, 2017 | Whirlpool Cabrio WED6400SW Electric Dryer
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
Oct 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
E20 error message
maybe you should just get a new washing machine
Dec 11, 2013 | Washing Machines
I have a Kenmore elite dryer, and the signal cycle keeps beeping and the light switches from on to off with every beep...it does it about 6-8 times then may wait 20 seconds to 5 mins b4 it does it again. ...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 09, 2010 | Kenmore 67082 Electric Dryer
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Error E20 showing ........stops during wash cycle and clothes not dry on drying cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Apr 06, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Error codes
if this is a fridgidaire washer, I guess it's a clogged coin catcher. You have remove the front access panel and clean it out. I am working on that now.
Nov 05, 2007 | Washing Machines
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
E20 During Drying Cycle
if the wash cycle runs ok then unlikely to be the drain pump or hoses. put drain hose into a bucket and check waster comes out during dry - it wont be large amounts of water. can you hear the drain pump running during the dry cycle?
Mar 08, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Zanussi ZWD1470W Front Load Washer / Dryer Logo
510 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
