Linksys Wireless-G Broadband Router
Problem for Linksys Wireless-G Broadband Router
Hooking linksys to gigafast
By ninja007 on Dec 02, 2007
I just got a gigafast wireless router and am trying to hook my linksys wireless g router I have for my desktop into it. I am having no luck at getting the linksys to connect to the gigafast so I can receive wireless through this router. Help?
Comments:
Dec 07, 2007
- Okay, so I mislabeled what I was trying to do. I have a gigafast router and a linksys adapter for my desktop. Both are wireless g. I have effectly gotten the linksys to establish a connection with the gigafast router...but it only stay connected for a brief period of time and then loses its connection....after searching for a connection it subsequenty says that I am disconnected from the network...after a few seconds though I can acess the internet even though it tells me I am disconnected from wireless. It cycles through saying it is disconnected but still able to connect to searching for wireless internet, to being connected then back to being disconnected but still able to receive internet. It is extremel frustrating. So,for this question I am asking your help now. Also, I do not have an ethernet cable attached to the dektop.
Dec 07, 2007
- Yep, I am going to need help pulling this one off. I can disable wireless but cannot figure out how to configure the network adapter.
Dec 07, 2007
- okay, I did not have the linksys monitor icon in my systray nor have any idea where to find it. If you have an idea I am capable of the rest.
Best Solution
posted on Dec 06, 2007
Helpful)
pasha19
Rank: Guru  Linksys Expert
Rating: 86%, 760 votes
There are some question's that should probably be asked before we begin. Generally a wireless adapter or network card is present in a computer to allow it to access a wireless router which is connected to an internet service provider (generally a dsl connection through a phone line or a cable modem from your cable provider. Your request seems to be to get a computer to talk to a wireless router to talk to a wireless router to talk to your internet service provider (dsl or cable). I will assume after reading this that you probably have or will get a wireless adapter for the computer to talk to one or both of the wireless routers you appear to have. Wiring two wireless routers in the same house may be useful if the home is large or the wireless routers operate on different bands (a, b, g or frequencies) and you have different computers that require the different bands. however both wireless routers are in my experience connected to each other using a wire. Once we clarify the above we can probably address the connectivity issues for the devices you require.
Comments:
Dec 07, 2007
- No problem your response certainly cleared up some confusion on my part based on the earlier description.
I have linksys wireless network card in an old toshiba laptop running Windows XP Pro SP 2 that had numerous disconnect problems when operating using the linksys monitoring software to connect to a WPA encrypted router. The solution that is working for me was to disable (left mouse click on monitor icon in systray) the Linksys Wireless Monitor program and configure the network adapter using Windows Wireless Networking and the problem was resolved. Do we need to step through the process or can you handle the change if it sounds appropriate for you?
Thanks
Dec 07, 2007
- WARNING TO OTHERS REVIEWING THIS ALL NETWORK CARDS MAY NOT PERMIT CONFIGURATION BY WINDOWS INSTEAD OF THE MANUFACTURER PROVIDED UTILITY
The following also assumes you are running Windows XP
Sample ----
Shorthand for instructions Start > All Programs > Accessories > Command Prompt
Means Click Start then Select All Programs from the menu then select Accessories from the menu then select Command Prompt from the menu
OK?
Open the Linksys Monitor
Using the Linksys monitor Icon in the systool bar
right mouse click on the icon > Open the Monitor
Select the Profiles Tab
Click Edit to review the current profile
Write down each entry and
press next without changing anything
repeat this step until there is no next button
Click Exit
Close the Linksys Monitor
If one of the above items was a network key (password) that contains "*********' length may vary -- this is not the password you will need to access the router configuration to determine the network key (password) (probably WEP or WPA.)
Instructions for getting the password are probably in your router's user guide or request additional help here if needed --DO NOT PROCEED BEYOND THIS POINT WITHOUT GETTING A PASSWORD, IF REQUIRED.
Step 1 - Disable the Linksys Monitor (not the adapter)
right mouse click on the icon > Turn Monitor Off
In my case the icon turns grey
If anything fails in a subsequent step you can reactivate the
monitor as follows
you may also need to reply Yes to a message to disable
Windows XP Wireless Zero Configuration
Step 2 - Enable windows configuration of wireless adapters
Use Windows XP Wireless Configuration
Reply Yes to the message to switch to the Windows XP
Wireless Zero Confitguration Utility
Step 3 - Assure Wireless Adapter is configured
Start > Control Panel
Double click Network Connections
Right mouse Click on Wireless Adapter >
View available Wireless Networks
Click on your wireless device
Enter your network key (password)
Step 4 - Test to see if the network card is working
Step 5 - If the network card is not working
Dec 08, 2007
- Check in the menu for a Dual Band A & G Network Adapter or Linksys or something about Network Adapter -- if you find the menu item let me know. If the an icon in the located menu matches a systool icon that is the Linksys Icon. If not we will do the Open Monitor Steps using the icon you found.
Second Look in the Control Panels
Start > Control Panels
Select Classic View
Can you see Network Setup Wizard?
We will use that instead of Use Windows XP Wireless Configuration.
If you can confirm both of those we should be able to find some instructions that will work.
Was this helpful?
Yes
No
Popular Solutions for Linksys Wireless-G Broadband
Questions and Unsolved Problems for Linksys Wireless-G Broadband
Do you recommend Linksys Wireless-G Broadband Router?
Answer
Answer
I installedlinskys wireless g broadband 6 months ago. I tried to get onto the internet and I am... (More)
Answer
Cannot get our dell lap top to pick up the wireless at home our other lap top at home connects and... (More)
Answer
find or your down find it for today afternoon got it GGGGGGGGGGGGG
Answer
talked to cox server they tried to get it a connection. It's not working router for wireless wont... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Linksys Wireless-G Broadband...:
Top Router Experts
Rank: Guru Guru
Solutions: 1451
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
