Question about Dryers
Dryer will ramdomly not heat
My dryer will not heat about 60% of the time. Sometime spinning the heat selector dial around then restarting seems to make it work but more and more often it won't heat. I've tried all heat settings and both cycles (auto and timed) with no improvement. Thanks
I have a Amana dryer, 6 years old. It heats only first 20 minutes, and then no heat. But the drum works till the timer is out. Would you give some hint?
Thanks,
Posted on Dec 19, 2007
  • 248 Answers
Gotta go with Washer_tech. Would go with coils myself. More often than thermo problems.
Posted on Dec 04, 2007
  • 164 Answers
If it is a gas dryer, your gas coils are going bad. as the machine heats the coils fail, and when it cools the coils work again. very common problem
Posted on Dec 03, 2007
  • 76 Answers
It sounds like the thermostats are going, unplug machine and remove the back panel, which is a bulgy bit on the back (not the main panel) you will find two thermostats with four wires above the heater. replace these.
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
GE Dryer model DSXH47 keeps shutting off after about 30-40 sec.
It could be the door switch. If it vibrates a bit then the door switch senses it's open and shuts down. Give it a look
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 07, 2009 | GE DSXH47GGWW Dryer
Dryer spins, no heat, timer does not seem to function
Your timer mechanism is damaged. this will happen if the timer motor is faulty. it will not advance the cycle correctly. replace the timer/control asap. Please rate and have a great weekend:)
Jun 05, 2009 | Hotpoint Dryers
Maintenance lights won't go away
elaine hopefully this will help. advance your selector dial to the 6 o'clock position, press start 3x. advance your selector dial to 7 o'clock position, press start 3x. turn the unit off then on. try using it as normal.
Apr 24, 2017 | Whirlpool Dryers
Dryer will spin but won't heat up
Hi
Things that could stop a electric dryer from heating:
  • house fuse or breaker ( needs two of them )
  • heating element, burnt wire
  • thermostat(s), thermal fuse ( not all models ),
  • motor heat switch, timer, selector switch,
  • burnt power cord/plug.
You can check these things using an ohmmeter/multimeter from here.
Things that could stop a gas dryer from heating:
  • glow bar igniter,
  • thermal fuse ( not all models ),
  • coils on the gas valve, gas valve, thermostats,
  • motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 20, 2009 | Whirlpool Dryers
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryer won't spin
low voltage to the motor or a bad motor
Dec 03, 2008 | Dryers
Dryer spins but wont heat - element okay
HAVE YOU CHECKED THE MAIN FUSE FOR THE DRYER?WHITE AROUND THE SIDES AND DARK IN MIDDLE,UNSCREW THE KNOB COUNTER CLOCK WISE TO REMOVE KNOB,SHOULD BE 2 SCREWS HOLDING TIMER REMOVE THEM AND THE PANEL SIDE SCREWS,THANKS-MIKE
May 29, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Intermittant heat for drier
check for flow of air through the dryer arts as it sounds like the clicking is the thermal cut out activating, this prevents the dryer from overheating, the common cause for overheating is blockage (no air flow) or the fan that blows the air round the machine is not working, or not working properly, so check the fan see if its turning etc hope i have helped, if so please rate me
Oct 03, 2007 | Dryers
Dryers Logo
117 people viewed this question
Top Dryers Experts
Marvin
Marvin
