Question about Roper RAS8445KQ Top Load Washer
WASHER TOP LOAD NO POWER RAS8333PQR
I HAVE A TOP LOAD MODEL NO.RAS8333PQO WASHER THAT I RECENTLY REPLACED THE CLUTCH, DUE TO THE WASHER NOT SPINNING. EVERYTHING WAS GREAT FOR 4 DAYS. I TRIED WASHING A LOAD AND THE WASHER FILLED BUT THATS IT. WHEN I PULL THE SWITCH FOR THE POWER THERE IS NOTHING. NO SOUND OF HUMMING. IT ACTS AS IF IT IS GETTING NO POWER. I CHECKED AND RESET THE BREAKER EVEN THOUGH IT WASNT TRIPPED, UNPLUGGGED, TRIED ANOTHER OUTLET AND STILL NOTHING. THE WASHER IS ONLY 3 YEARS OLD.
  • 447 Answers
Is the Lid switch broken??
Posted on Dec 02, 2007
Model 23832100
Sounds like clutch not catching,this may need to bed in .The fact it works okay with no load and no spin with load sounds like clutch/ but also could be motor torque.Ask repair man to recheck work done.
Jan 14, 2014 | Kenmore 24032\24036 Top Load Washer
I have a roper ras8333pqo. Sometimes the washer will not spin and the motor will sounds as though it is spinning. I rotated the drum. I then closed the lid and it started to spin...is this the coupler? ...
Could be a bad clutch/brake mechanism or a bad coupler.
This video will show how to repair it.
http://www.youtube.com/user/RepairClinic#p/u/0/9K1KHEogf3c
Sep 04, 2011 | Roper RAS8445KQ Top Load Washer
Hi Fixya, I have a Kenmore top load washer Model# 23812100. I have spin issues. I replaced the lid switch and the coupler and the spin cycle is now spinning slow and seems like it wants to spin but...
Make sure that the motor is spinning with correct TORQUE. If this seems good then the washer must SPIN inthe cycle. A loss of RPM can then be due to the clutch slippage as it fails to engage fully to the motor. Best is to check this assmebly and change the spare requied.
check for tips on the link below;
http://www.espares.co.uk/advice/washing-machines/a/7
Jul 19, 2011 | Kenmore Washing Machines
Roper model rax4232pq stops spinning with more than 3 towels as a load
sounds like your clutch is bad . the clutch is what controls the strength of the spin
May 12, 2011 | Roper RAX4233PQ Top Load Washer
Washer still stops spinning at 7 minutes after clutch cleaning
When you did your Clutch Maintenance how much rust was present on the One-Way Roller Clutches, the Spinner Shaft Coupler did you series use upper One-Way Roller Clutches bearing ring?
How long ago was the Clutch maintenance performed
Any error codes with the ""stopps spinning at 7 minutes""?
What is the Series number of your FAV6800A?
Did you ues this Clutch Fix post to clean up and check that the One-Way Roller clutches are locking up solid in the CCW/Spin direction for both the Clutch Pulley mounted One-Way Roller Clutches if you series machine uses the Upper Bearing Ring?
If so then I would take that same wash load and run Quick Spin Test page 14 of the Service Manual. You may have to center the wash basket load (balance) before you start the test.
Will the machine step thru the all the RPM rages from 90 RPM to 85. which = 850RPM.
If not try the same test with out the load.
Let's rule Outer Tub Bearing drag........Rich
Jun 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune FAV6800AW Top Load Washer: my washer is stopping and not spinning with about ...
See if my Clutch Fix post will get you started if your machine model type is a FAV6800A or FAV9800A……Rich
May 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Our 5 year old Neptune won't progress through the cycle past 24 minutes, and won't drain, though it sounds like it is spinning. We had a new clutch put in about 3 years ago. The repair guy said to replace...
It is not the controller. It sounds like it spinning since the motor is turning. If the motor turn then it is not the control board problem. The culprit is that the mechanism is not working. The motor has 2 directions of rotation. One is for agitation through a mechanism, as helix. The part cost about 10$. Other direction is for spinning. This includes the transmission pulley, the brake and the clutch. The clutch and the brake are hardly needing replaced unless a wrong diagnostics had been made. The thickness of the transmission pulley is worn out due to a friction force every time the spinning mechanism is engaging. When it is worn out, it is short to push the clutch so no engagement happens, hence no spinning. And this parts also cost $15. The only cost is the labor to take the machine apart to replace this. If you enjoy doing it then I recommend you should. There is no instruction to describe how the system work, but if you observe the mechanism carefully, you will understand how it work. The best simulation to gain understanding is to unplug the machine take out the panel, turn the belt in either direction so you can see how it engage to the 2 different mechanisms then you will see how it works. Good luck.
Apr 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AWW top loader washer
Double posting, are you still having the issue, did reseating the clutch clear the issue?
Mar 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
218 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
