Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Freezer not frezzing
Light is on motor working, but not freezing. was fine untill this AM. It is a frigidaire upright freezer about 5yrs old
  • Scotty Brannon Apr 15, 2008
    same problem with mine put in service valves and noticed the low side was running in a suction??? Where is the most likely place for a restriction??
  • 145 Answers
The most common place for a restriction on a frigidaire upright with evap shelfs is the top shelf where the cap tube comes into it. I blew mine out with nitrogen. It might work for yours but doesn't always work.
Posted on Apr 18, 2008
  • 833 Answers
DR....let's go down the list:
First is freeze up. This happens when too much humidity gets into the unit from the air and forms ice on the coils. Defrost the unit using warm air or leave it open and off for two days.
Problems that cause this: high humidity, 'window shopping', unit not left closed or bad gasket. If the gasket looks damaged, it will need to be replaced. Gaskets that have accumulated dirt don't seal. Use a mild cleaner to fix this. If you have doubts about an area where the seal is questionable...use a sheet of paper about 2-3 inches wide, close the door and pull it through. No resistance indicates a poor seal.
Make sure you clean out the condenser...the coils where the heat is rejected by the unit.
It is possible that you have refrigerant or defrost timer issues. To check for low refrigerant, start the unit after defrosting it. Note that the larger pipe attached to the big black thing....the compressor...will start to frost. It should then start to form ice while the unit is running...about 5 minutes. If the frost stays and the pipe is not REALLY cold, you have a problem with refrigerant. Sealed units are warranted for 5 years. Defrost timer issues are best left to a tech.
Posted on Dec 04, 2007
My freezer does.not freeze and the hi temp light is on.
Had the same problem, I unplugged freezer for two days, pluged back up, has worked fine since.
Jul 11, 2012 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Layed down freezer to transport in car for long journey left 4 hrs before start up working fine freezing but side edge behind door seal feels quite hot since
this is normal until all the freon has had a chance to get recirculated throgh the system.
make sure the evaporator fan is also working in order to properly cool the freezer.
Oct 09, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire upright--"Hi temp" warning light on door. Don't know why freezer temperatures are so high (into 30s), food is thawing. Electrical seems to be fine. Have not noticed problems with door. New...
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
Jan 11, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Not Freezing
Check the door seal all the way around. We purchased one recently that was slightly dented (not noticeably and the seal was not tight.) You need to get in touch with whomever you purchased it from immediately so that it can be repaired or replaced.
Aug 18, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
FRIGIDAIRE UPRIGHT FREEZER ONLY 2 BOTTOM SHELFS FREEZING
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
199 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
