Question about Zanussi 32 in. DE6755 Dishwasher
Zanussi 32in DE6744
Our dishwasher is jammed into a space that is too narrow.
We cannot remove it to attempt a repair (or even to replace it)
Any help on moving or dismantling the dishwasher without
dismantling the fitted kitchen?
  • 17129 Answers
SOURCE: how do i replace upper spray arm duct on
To replace spraying arm check for tips on this link:
Posted on Nov 07, 2011
0 characters
1 Points
My Zanussi dishwasher DE6744 leaks clean water during the wash cycle. The water appears to be coming from the plastic tank overflow holes, left hand side as you look from the front. Any ideas?
I have the same machine and I took mine outside and turned it on its side and removed the clean water feed and all the screws holding the white plastics off and then un-clipped them off and I saw that there was a blue tube that was leaking on mine, I cut the end off and reattached it with a new clip and hey prestow all working now with no leaks.
Dec 29, 2009 | Zanussi 24 in. DE6744 Free-Standing...
Zanussi Dishwasher Model no DE6744 Not working
HI. After me fiddling about with the machine,checkingto make sure water was available to it and trying to locate the float switch (whicu i didnt) .
Then i left it standing overnight aqnd the believe it or not it worked in the morning.
I let it run through the cycles of a program which it did ok.
Hoping it carries on ok. Kenethyorky
Aug 11, 2008 | Dishwashers
There is usually a float switch inside the DW body. Usually a polystyrene lump. This may be stuck in the up position, or a pool of water may still exist within the case.
When you say trips the electric - is this your wall MCB or ELCB ? If it is that then there is a major electrical fault on this machine that needs investigation.
Jun 11, 2008 | Zanussi 24 in. DE6744 Free-Standing...
Dish Washer
If you live in a hard water area the 5 in 1 tablets will only work half way. Consider Calgon powder or the tablets which can be left in the dishwasher cutlery basket as an additional measure. Hard water areas are notorious for leaving chalky residue on cutlery regardless of 3 in 1/5 in 1 tablet promises.
Also your dishwasher will require rinse aid too as most machines need this to mix in with the general water and soap solutions when the dishwasher is on its final rinse.
Apr 19, 2008 | Zanussi 24 in. DE6744 Free-Standing...
Zanussi DE6965
I had the same problem with my dishwasher. The fault is because the water is not heating but in the majority of cases I would bet that the problem is not with the element but with a burnt out track on the control PCB. I was advised by a zanussi dealer that this track being repaired will not fix the problem indefinately but looking at the PCB the track which burnt out is just the 240V live and switched live from the relay, therefore replacing the track (solder some wire where the track was to the pins of the relay) should fix the problem indefinately.
I have successfully repaired my machine, it has been working for a couple of weeks so far with no problems. A couple of tips:-
1. The relay/tracks in question are beside the two separate connectors at one side of the PCB close to the big 12V relay (it should be obvious as there should be scorch marks)
2. If the two separate connectors above are swapped on reinstallation it will appeaqr that there is no power so before removal of the wiring take a note (or picture) of orientation of the wires.
3. Do not attempt this if you are not comfortable working with mains voltages and ensure that all power to the appliance has been disconnected before dismantling.
4. To ensure a good solder joint clean the area before resoldering with switch cleaner, or just scrape any residue away if no switch cleaner/ IPA is available.
Good luck, let me know if this fixes your problem.
Jan 17, 2008 | Zanussi 24 in. DE6965 Built-in Dishwasher
Won't work
I hant not seen this unit but what it sounds like to me is the control bord that controls the functions on the washer may be bad. you should try and find if there is a tech sheet somewhere in the cabinet or under the dishwasher. that will help you to also see if there may be a fuse or thermal fuse that may be bad. good luck
Aug 05, 2007 | Zanussi 24 in. DE6744 Free-Standing...
Humming noise
humming is the motor powered up but not turning. burning smell is the motor overheating. cause may be the motor capacitor which is a cheap part. try replecing it and hope thge motor survived. could also be a foreign object in the pump impellor
Mar 13, 2007 | Zanussi 24 in. DE6744 Free-Standing...
Stopped Working
The problem is with the PCB, this is the board behind the buttons, you can buy this for £120 or you can get it fixed by QEA for about £45 link below. I am not an engineer but I replaced mine in 10 minutes.
Sep 25, 2006 | Zanussi 24 in. DE6744S Free-standing...
Still too long for a cycle
how long does cycle take? if program actually finishes there is unlikely to be a problem. factors which can affect cycle times are inlet water temp and rate water is entering the machine
Aug 15, 2006 | Zanussi 24 in. DE6744 Free-Standing...
Zanussi 32 in. DE6755 Dishwasher Logo
18 people viewed this question
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
