Question about Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television
Closed caption I bought a Sony Bravia multisystem tv that doesn't have closed caption. How can I have close caption availavility?
  • 320 Answers
There are external close caption boxes that you can add to your system. But be aware: many cable boxes do not process the close captioning information "through", forcing you to use the close captioning on the cable box.
Posted on Oct 19, 2008
SOURCE:
How can I turn off CC on my SONY 52XBR. I used the Remote control settings and selected off on the cc display, but the cc never turns off. I also used the menu button on the side of the T.V to select
If Closed Captioning is being displayed even though the CC option in the TV menu is set to Off , then it is being produced by another device, such as a cable or satellite set-top box. To remove the Closed Captioning from the TV screen, it must be disabled on the device that is decoding the Closed Captioned signal.
NOTE: Some set-top boxes may automatically display Closed Captioning on the TV screen when the set-top box sound is muted. If this is the case, turn off the Mute function of the set-top box
Oct 31, 2014 | Sony Tv Xbr Bravia Kdl-52xbr5 52 Lcd Tv...
How to remove closed caption on Sony Bravia TV
Check the menu of set and a box if used--both usually have that feature.
In menu look for closed captions (CC) and turn off--settings may exist for leaving it to only come on if sound is muted.
Do not if using a box for signal overlook that also having the same feature.
May 31, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
There is a big block in my TV screen covering 8 to 10 inches. I have a Sony Bravia, model KDL-40S4100, and i bought it in 2008.
if it is a black block, look in the menu under closed captions and see if it is in the text mode. if so change back to cc1 or turn off.
Aug 19, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony Bravia KDL-32XBR4, closed caption turned on and being displayed. We wanted to use the "display options" to make the closed caption bigger. The "this is how it will look" looks...
Go into the tv menu again,Go to"Display Options"closed captioning u pick captioning bigger for as a default,but did u push the button on the remote said Enter?Press the enter button for the defualt caption will see the left side of the tv captioning default u want.Now the if u,used the CC button.U will get the bigger bold matalic captioning u want.
Nov 24, 2010 | Sony Televison & Video
HOW DO I REMOVE THE SUBTITLES FROM MY SONY BRAVIA
The Subtitle option is available only with the connected devices like DVD Player, Blu-ray Disc Player etc. The option avaialble in the TV is known as Closed Caption. The Closed caption option can be turned off by selecting the options below:
Press Menu button on the TV Remote. Select, Setup settings. Then select Caption Vision option to OFF. This option is for turning off the Closed Caption option in the TV to OFF. For disabling the Subtitle option in the connected devices like DVD Player and Blu-ray Disc Player, press the SUBTITLE button on the supplied Remote continuously to select OFF.
In few of the TV broadcasting channels the Subtitles cannot be turned OFF as this is being broadcasted with the channels.
Good Luck! KenSolutions
Oct 28, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
All of the sudden a large rectangular box appeared on my sony bravia
check in your on screen settings if you have closed captioning on.
Dec 09, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Cannot lose close captions from screen even though it has been turned off at the menu. Any suggestions?
Check the caption settings in the menu for your video source, (cable box or satelite reciever), the signal could be originating there.
Dec 04, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Closed Caption on Sony Bravia
Try a master reset on the TV. With the TV powered on, prss and hold down the up button on the remote (there are 4 buttons grouped together for up down left and right) and while holding down the up button, press the power button on the TV. The unit should power off and then turn back on and ask you to select a language. Let me know if this helps and be sure to rate this solution. Thanks!
Nov 11, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television Logo
551 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
