Question about Goodmans W280NS Television
Goodmans LD26450HD Was on the TV thismorning and it suddnely went off. I powered off and left for 1 hour, Turned it back on Standby light comes on, Try to boot it up standby light Flashes TV will not come up Help me please
I have same problem with mine on ld2650hd
Posted on Jan 14, 2008
KONKA KDL32AT23U 32 in LCD Television No back light, sound OK
Not likely it is the back light if you can eventually get it to come up.
Some general information (cap?):
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.3_29_2012_1_25_02_pm.jpg
Mar 29, 2012 | Televison & Video
42" plasma worked fine this
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Sep 15, 2011 | LG 42PC3D 42 in. Plasma Television
Tv popped and turned off, now won't come back on. left it unplugged for about ten minutes, and the standby light came on but went off when the power button was pressed
Power supply board is dead.Replaced the power board will get the power back.Buy a refurbish power supply board at Shopjimmy.com,Ebay.com for the power supply board.
Feb 10, 2010 | Sharp LC42SB45U 42 in. LCD TV
We have a Bush TV, model number RF6685VPL/A. We switched it on thismorning and the colours have all gone strange, with various shades of purple around the outside of the screen. It has been turned off,...
This sounds like a purity fault due to a magnetic build up, you will need to call out a service engineeer to have the TV de-gaussed firstly, which is a simple process. If this does not cure the fault, then the internal circuit for de-magnetising maybe a problem. The worst outcome can be the tube is at fault & would need replaced.
Nov 01, 2009 | Televison & Video
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Sep 30, 2009 | Sony Televison & Video
Bush lcd tv turned itself off won't come back on
My Olevia LCD TV did the same thing. I turned off the back power switch and pulled the power cord as well. Left off for a couple of minutes and then re-connected cord and turned on main switch. I then turned on the front power switch and it come on just fine. These new sets have computer-like guts so you have to re-boot them sometimes. I hope this works for you.
Feb 21, 2008 | Televison & Video
Tv wont turn on
same "standby light" problem, with TV not turning on.
Jan 13, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Televison & Video Logo
516 people viewed this question
Top Goodmans Televison & Video Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
