Wireless switch crashes laptop
Hi there. Had problems recently with my laptop where Windows wouldn't start, saying hal.dll fault. I took it to be repaired but now my wireless switch crashes the laptop when it is pressed. Do I have to re-install Windows using recovery cd or is there a way to change a setting? I've already been in device manager and update the driver but still no luck.
  • 2 more comments
  • SarahLong320 Jan 01, 2009
    Everytime I have the wireless switch on, my computer goes to blue screen and crashes. The weird part is this only happens in my apartment. I switched the router off and it still happened when I turned the wireless switch on. When the computer is not at my apartment, it works perfectly.
  • Rob3768 Feb 23, 2009
    Had a Netgear DG834G router that packed up recently, so didn't use the Sony Vaio Z1XSP for a couple of weeks. I Installed a new Belkin N+ router and now my laptop will not start up unless I turn off the Wireless LAN switch.
  • Anonymous Mar 07, 2009
    I am currently working on a Sony VGN-A290 that gives me the Blue Screen of Death every time I turn on the Wireless Switch. I re-installed the whole OS and Applications and even updated to the latest Wireless Driver and it still crashes. Could this be a faulty Wireless Adapter from Sony?
  • Anonymous May 01, 2009
    vaio crashes when it comes in contact with belkin N+ router, if router is off or wireless switch on vaio is off, vaio works fine. Works fine with G wireless. Updated driver and still wont work
    Sergeant:
    Champion:
  • 270 Answers
Repairing xp is not a better solution to problem . a re install may be better and tension free
Posted on Dec 02, 2007
  • roycmarshall Mar 01, 2011
    I have the same problem with crashing when wireless is turned on.... I have done about 4/5 recoveries bur it remains the same!......blue screen. Without the wireless, the computer works fine.
    Rob
  • 72 Answers
From the pattern shown for the Sony Vaio systems, I recommend a concerted effort to get an answer from Sony or the Wireless card manufacturer. The issue has to be in the implimentation of the Wireless N for that card.
Posted on Nov 27, 2009
Notebook says that windows could not start because the following file is missing or corrupt <windows root>/system32/hal.dll.
Causes of the missing or corrupt hal.dll error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
To fix it:
1) Restart your PC, sometimes the hall.dll error could be an error itself and your PC should boot up fine.
2) Go into the BIOS by pressing the Delete key as the laptop boots. Then navigate to disk boot priority and make sure this is set to your main hard drive (the one that has Windows installed on it). Save and exit the BIOS. Sometimes if you have a USB flash drive/Pen drive or external hard drive it may automatically switch the boot priority to that.
If these two quick steps don't fix the problem then head over to here and continue reading up about repairing the boot.ini file.
Mar 10, 2011 | NEC PKM35-4A33 Buzzer (802870018009A) PC...
Have acer aspire one, when started got screen saying file missing or corrupt window root system 32 hal.dll, nothing else cannot bring up safe mode do not have windows xp cd, in nursing home cannot afford...
I am going to start with the assumption you have already tried to reboot, then next choices from there go kinda like this...
Run windows XP restore from command prompt. (From safe ,mode type C:\windows\system32\restore\rstrui.exe and press Enter. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Replace the boot.ini file (run msconfig) This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Right click on c: drive, click on properties, then tools, click on the error checking button, the put a checkmark in each box, Click start and it may say it needs to run on next reboot click OK the reboot. The physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Run a repair install of the operating system. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Nov 29, 2010 | Computers & Internet
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Nov 09, 2010 | Acer Aspire 4720 Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
The file <windows root>\system32\hal.dll.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
Systemroot/32 /hal.dll missing
You can download hal.dll here http://www.dll-files.com/dllindex/dll-files.shtml?hal (but are you sure it's missing and not just "hidden"?)
Nov 15, 2009 | Computers & Internet
Windows XP won't start
for that you need winxp bootabler disk.
Tehn boot your computer with tht and go to recoverry console.
Then type in command prompt "chkdsk /r"
then press "y"
then it fixc error on harddisk.
Then after completing it restart your computer and boot with harddisk then it ok.
Jun 20, 2009 | Computers & Internet
Windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 10, 2009 | E-Machines eMachines Desktop PC
Internet explorer will not open. Error message below.
Okay, the driver for IE (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32\
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the IE application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the IE driver, and the problem will be fixed!
Mar 12, 2009 | Dell Vostro 1500 Notebook
\system32\hal.dll. MISSING FILE
YOU NEED TO DOWN LOAD THIS PROGRAM FROM MICROSOFT.
WWW.WINDRIVERS.COM/HAL.DLL
OR
WWW.WINDRIVERS.COM/SYSTEM32/HAL.DLL
ONLINE ADDRESS BAR: WINDOW DRIVERS FOR SYSTEM32\HAL.DLL
OR FIND THE FILE IN THE ORIGINAL SOFTWARE YOU INSTALLED THE WINDOWS VERSION ONTO THE SYSTEM
ROD
Feb 12, 2009 | Acer Aspire 5000 Notebook
Computers & Internet Logo
1,635 people viewed this question
David Payne
David Payne
