Question about HP LaserJet 1300 Printer
My paper keeps jamming how do i solve it?
My paper keeps jamming. What could be the reason that it keeps doing it?
    Scholar:
  • 88 Answers
You need a new paper pickup feed roller- about $5.00 and easy to replace. This is generally the one part that wears out on these printers. see this article.
http://www.printertechs.com/tech/mkinst/mk-1300-3puroller.php
Posted on Dec 02, 2007
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
Blinking Light with no cartridge problems My HP Deskjet D1460 has its light blinking with no status messages that suggests an error. However, I am unable to print as the light keeps blinking. Could...
Hi
this problem has many reasons :
- no paper or error in paper feed sensor.
- jammed paper in printer thats prevent it continue.
- try to disconnect usb cable and if its stop lighting reinstall the driver
- else you must search about hardware errors
Apr 26, 2011 | HP DeskJet D1460 InkJet Printer
Hi, my HP D4360 DeskJet printer isn't printing. Both the power and resume lights are on and blinking, as well as both the ink lights. Any advice would be much appreciated. Thanks
The power and resume lights blinks due to two reasons. 1) If there is any kind of paper jam in the printer.Then its internal assembly cannot move so the lights blinks.So clear the paper jam if any.Open the cover and check if any paper jam.also there is a access door at the back to check any paper jam.The back plastic door can be opened to remove paper jam. But if you are confirmed that there is no paper jam then the other possibility. 2) The printer cartridges are faulty and needs replacement.There are two print cartridges in the printer.One color and one black.Any of the one can be faulty or in some cases both are faulty.But before replacing cartridge remove the cartridge and clean the brown dotted circuit on cartridge then reinsert the cartridges and check.But if this does not solve the problem then replace the cartridge one by one and solve the problem. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 05, 2010 | HP D4360 DeskJet Printer InkJet
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
PAPER JAM ERROR MESSAGE keep showing!!
Make sure that all rollers in the paper tray is working properly. If not, then this might be the reason why your having this issue. Try calling your manufacturer to have it replaced, if it's still under warranty.
Dec 03, 2009 | Office Equipment & Supplies
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
The paper feeder of my canon super g3 jams every time
Yes, there is an easy solution, possibly. Mainly because you say it may do a single job, and then it keeps jamming. Do you see the second sheet jamming in when it is not called for? Anyhow, you may try cleaning the rollers, all of them, like I did here: http://annoyances-resolved.blogspot.com/2009/09/paper-jam-buy-new-laser-printer.html This completely solved my problem of persistent paper jams.
May 04, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
CLX-2160N Paper Jam?
my printer Samsung CLX-2160 give me the message "paper jam", but I checked a lot of times inside and there is no paper. What's the real problem? How can I solve?
Mar 04, 2009 | Samsung CLX-2160N All-In-One Printer
HP LaserJet 1300 Printer Logo
383 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
