Question about Timex (T307S) Clock Radio
1996 ford ranger 2.3L 8 plugs single overheadcam
Need to know how to find TDC on crankshaft in the proper firing order to put timing belt on ...bought with out timing belt on l think the crankshaft has been rotated...
  • 1 more comment
  • Anonymous Dec 17, 2007
    need to find timeing order . how to get the #1 pistion TDC on comepression stroke
    timing belt has broken or torn apart, need to replace, but there are more timing marks on the pulleys than regular
  • braddah Mar 11, 2008
    belt was broken set crank on tdc on compression stroke set timing mark on com set timing mark on oil pump gear? try to start it cranks but wont run check for spark and its gettin but still seems to be out of time starter doesnt crank smoothly replaced starter cranks better but still doesnt run
    tried turning crank 1 turn and reinstall belt with same results have any ideas? fusterated in paradise.
Belt was broken set crank on tdc on compression stroke set timing mark on com set timing mark on oil pump gear? try to start it cranks but wont run check for spark and its gettin but still seems to be out of time starter doesnt crank smoothly replaced starter cranks better but still doesnt run
tried turning crank 1 turn and reinstall belt with same results have any ideas!
Posted on Mar 18, 2008
I am fairyly sure the 2.3L is not an interference motor, if it is an interference motor, it is possible for the pistons to have contact the valves, causing damage. Hopefully this did not happen, lets assume it did not (can do a compression check for this). If you have fuel and spark, then it sounds like you are out of time 180 degrees (exhaust stroke, not power stroke):
1. Remove the coil wire from the ignition coil.
2. Remove one of the number one sparkplugs.
3. Place your finger into the sparkplug hole and have an assistant turn the engine over. When the the compression lifts your finger up or out of the hole, stop engaging the starter, and note the crank pulle location. The timing pointer should be just behind (to the left if looking from front of vehicle) of the mark on the crank.
4. Back the crank up if not overshot too much (say less than an inch/25 mm) and line the TDC mark up on the pointer, make sure you are on one line of sight
5. Remove the distributor cap, and mark on the outer housing the number one plug wire location, check to see if the rotor is on the #1 sparkplug wire, it should not be if this is the problem
6. Remove the distributor hold down bolt, remove the distributor and turn the distributor shaft until the rotor points to the number one mark
7. Reinstall the distributor, this may require wiggling the crank slightly
8. The distributor will have rotated slightly for the gear to mesh with the cam, turn the distributor until the rotor is on the number one plugwire again, and reinstall the bolt, but do not tighten it snug.
9. Check the timing with a light to the vehicle specified value by turnin the distributor as needed.
Posted on Dec 18, 2008
Resetting timing after replacing head gasket
Do you have the timing belt on and the tensioner set correct? If so, just rotate the crankshaft around until the notch on the crank sprocket is lined up with the pointer on the oil puimp housing (TDC). Now the camshaft sprocket's notch or pointer should be at the top and exactly in line with the mark on the rear timing belt cover. If it's not correct, you'll have to release tension on the belt, remove it, and set the camshaft to the mark. But before you do that, turn the crankshaft back (counterclockwise) just three notches. Then you can turn the cam to line up, then return crank to line up, and continue with belt installation, setting the tension, and re-checking timing marks after rotating the crankshaft a couple of revolutions. Once you know the timing is set to TDC, no further timing adjustments are possible, because the computer controls timing. I don't know how important it is, but just to let you know: Chrysler recommends after belt removal or replacement that one perform the "crankshaft and camshaft relearn alignment procedure" using the DRB scan tool (Chrysler's scanner device) or equivalent scan tool.
And the firing order on all four cylinder engines is the same: 1 3 4 2.
I hope this helps you out. Cheers.
May 11, 2012 | 1996 Plymouth Breeze
Engine Timing marks on a 4.0 ford ranger on a 2005
Rotate the engine so that No. 1 cylinder is at TDC on the compression stroke. Check that the timing marks are aligned on the camshaft and crankshaft pulleys. An access plug is provided in the cam belt cover so that the camshaft timing can be checked without removal of the cover or any other parts. Set the crankshaft to TDC by aligning the timing mark on the crank pulley with the TDC mark on the belt cover. Look through the access hole in the belt cover to make sure that the timing mark on the cam drive sprocket is lined up with the pointer on the inner belt cover.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/ernie_b93ee48ba0eab50b
Nov 02, 2011 | 2005 Ford Ranger
Need timing blet diagram 1992 ford ranger 2.3
Hi, the crankshaft marks are on the belt pulley and timing cover, so you have to mate it up to see them. The cam sprocket mark goes on the bottom, and aligns with another mark on the timing cover. There is a plug you pull out and hole to look thru to align the cam sprocket/shaft.
Jun 01, 2011 | Ford Ranger Cars & Trucks
How do you set the timming on a 2.3 when your putting the new timming belt on
The IGNITION timing on your Ranger is computer-controlled and is not adjustable.
Should the camshaft drive belt/timing belt jump timing by a tooth or two, the engine could still run; but very poorly. To visually check for correct timing of the crankshaft, auxiliary shaft, and the camshaft follow this procedure:
There is an access plug provided in the cam drive belt cover so that the camshaft timing cam be checked without moving the drive belt cover.
  1. Remove the access plug.
  2. Turn the crankshaft until the timing marks on the crankshaft indicate TDC.
  3. Make sure that the timing mark on the camshaft drive sprocket is aligned with the pointer on the inner belt cover.
Never turn the crankshaft of any of the overhead cam engines in the opposite direction of normal rotation. Backward rotation of the crankshaft may cause the timing belt to slip and alter the timing.
REMOVAL & INSTALLATION
See Figures 1, 2 and 3
Fig. Fig. 1: Timing belt cover on the 2.3L and 2.5L engine
Fig. Fig. 2: Timing belt assembly on the 2.3L and 2.5L engine
Fig. Fig. 3: Releasing the timing belt tensioner using a special tool
  1. Rotate the engine so that No. 1 cylinder is at TDC on the compression stroke. Check that the timing marks are aligned on the camshaft and crankshaft pulleys. An access plug is provided in the cam belt cover so that the camshaft timing can be checked without removal of the cover or any other parts. Set the crankshaft to TDC by aligning the timing mark on the crank pulley with the TDC mark on the belt cover. Look through the access hole in the belt cover to make sure that the timing mark on the cam drive sprocket is lined up with the pointer on the inner belt cover.
Always turn the engine in the normal direction of rotation. Backward rotation may cause the timing belt to jump time, due to the arrangement of the belt tensioner.
  1. Drain cooling system. Remove the upper radiator hose as necessary. Remove the fan blade and water pump pulley bolts.
Dec 11, 2010 | 1995 Ford Ranger Supercab
1991 ford ranger 3.0 what is tdc on crankshaft timing marks
No 1 should be at TDC, balancer should be at zero, Gear/pulley marks should be aligned both cam & crank, distributor should have rotor ready to fire #1.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 17, 2010 | Ford Ranger Cars & Trucks
Trying to put timing marks wright on a1995 ranger
Your question states both 94 and 95 for model year.
94 and 95 ranger had a 2.3L.
  1. If not done:
    1. Loosen tensioner adjusting bolt.
    1. Using Camshaft Belt Tension Adjusting Tool T74P-6254-A, pry tensioner clockwise against spring tension as far as possible.
    1. Tighten adjusting bolt to hold tensioner in released position.
  1. Align crankshaft so number one piston is at TDC (top dead center) with crankshaft key pointing straight up and circle on crankshaft sprocket (6306) aligned with notch in engine front cover (6019) .
  1. Align triangle on camshaft sprocket with triangle on inner timing belt cover.
  1. Align diamond on oil pump sprocket with diamond on inner timing belt cover.
    Timing Mark Alignment
Feb 27, 2010 | 1994 Ford Ranger Supercab
Timing marks on 1999 Ford Ranger 2.5L.
  1. Loosen the alternator retaining bolts and remove the drive belt from the pulleys. Remove the water pump pulley.
  2. Loosen and position the power steering pump mounting bracket and position it aside.
  3. Remove the four timing belt outer cover retaining bolts and remove the cover. Remove the crankshaft pulley and belt guide.
  4. Loosen the belt tensioner pulley assembly, then position a camshaft belt adjuster tool (T74P-6254-A or equivalent) on the tension spring rollpin and retract the belt tensioner away from the timing belt. Tighten the adjustment bolt to lock the tensioner in the retracted position.
  5. Remove the timing belt.
To install:
  1. Install the new belt over the crankshaft sprocket and then counterclockwise over the auxiliary and camshaft sprockets, making sure the lugs on the belt properly engage the sprocket teeth on the pulleys. Be careful not to rotate the pulleys when installing the belt.
  2. Release the timing belt tensioner pulley, allowing the tensioner to take up the belt slack. If the spring does not have enough tension to move the roller against the belt (belt hangs loose), it might be necessary to manually push the roller against the belt and tighten the bolt.
The spring cannot be used to set belt tension; a wrench must be used on the tensioner assembly.
  1. Rotate the crankshaft two complete turns by hand (in the normal direction of rotation) to remove the slack from the belt, then tighten the tensioner adjustment and pivot bolts to specifications. Refer to the necessary illustrations. Make sure the belt is seated properly on the pulleys and that the timing marks are still in alignment when No. 1 cylinder is again at TDC/compression.
  2. Install the crankshaft pulley and belt guide.
  3. Install the timing belt cover.
  4. Install the water pump pulley and fan blades. Install upper radiator hose if necessary. Refill the cooling system.
  5. Position the alternator and drive belts, then adjust and tighten it to specifications.
  6. Start the engine and check the ignition timing. Adjust the timing, if necessary.
Nov 25, 2009 | 1999 Ford Ranger SuperCab
Camshaft timing mark crankshaft timing mark
Belt covers need to be on. Timing mark on crankshaft (while on compression stroke) should line up with TDC mark on cover. then Camshaft mark, needs to line up by looking through access hole of cover, and align mark on cam sprocket with pointer on inside of belt cover.
Oct 22, 2009 | 1987 Ford Ranger
Needing schematics for timing belt on a 2000 se
Removal & Installation
2.0L Engine
  1. Remove or disconnect the following:
    Negative battery cable Spark plugs Catalytic converter Right front wheel Right inner splash shield Accessory drive belt and idler pulley
  2. Rotate the crankshaft to Top Dead Center (TDC) and install Crankshaft TDC Timing Peg T97P-6000-A.
  3. Rotate the crankshaft clockwise against the peg.
  4. Remove or disconnect the following:
    Water pump pulley Valve cover Crankshaft pulley Timing belt covers
  5. Install Camshaft Alignment Timing Tool T94P-6256-CH into theslots of both camshafts at the rear of the cylinder head to lock thecamshafts into position.
  6. Loosen the timing belt tensioner bolt and relieve the tension onthe timing belt by disconnecting the tensioner tab from the timingcover back plate.
  7. Remove the timing belt.
    0900c152801e2a75.jpg enlarge_icon.gifenlarge_tooltip.gifFig. Crankshaft alignment position-Ford 2.0L (VIN 3) engines
    0900c152801e2a76.jpg enlarge_icon.gifenlarge_tooltip.gifFig. Placement of Camshaft Alignment Timing Tool T94P-6256-CH-Ford 2.0L (VIN 3) engines
    0900c152801e2a77.jpg enlarge_icon.gifenlarge_tooltip.gifFig. Timing belt tensioner index marks-Ford 2.0L (VIN 3) engines
To install:
NOTE Always replace the timing belt after loosening or removing it.
  1. Install the timing belt.
  2. Engage the timing belt tensioner tab into the timing cover back plate.
  3. Adjust the timing belt tensioner until the index marks are aligned. Tighten the tensioner bolt to 17-20 ft. lbs. (22-28 Nm).
  4. Remove the camshaft alignment tool and the crankshaft TDC peg.
  5. Install or connect the following:
    Timing belt covers Crankshaft pulley. Tighten the bolt to 81-89 ft. lbs. (110-120 Nm). Valve cover Water pump pulley Accessory drive belt and idler pulley Right inner splash shield Right front wheel Catalytic converter Spark plugs Negative battery cable
  6. Start the engine and check for proper operation.
Apr 08, 2009 | 2000 Ford Contour
Timex (T307S) Clock Radio Logo
5,866 people viewed this question
Top Timex Audio Players & Recorders Experts
Gyula Lacz
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
