Question about Sony PlayStation 2 (PS2) Console
PS2 Power Cable
I accidentally pulled the top case and the cable that comes under the drive comes out.I put it back in all correct but the light didnt turn green and always in red. What shall I do? another one is the game NARUTO it always loads up after an hour and my hands always hurts what should i do about it all?
How to unlocked all the characters in naruto shippuden with the cheats
Posted on Mar 07, 2008
  • 63 Answers
This is normal just press the button that is red and it will work like normal again! you will have to always do that because that is off because there is two ways to turn it off at the back and holding the green light till it turns red
Hope this helps - Josh Howard
Posted on Feb 02, 2008
SOURCE:
Where can I find the procedures to remove the Keyboard from my ASUS Laptop Model: PRO31F . Appears there may be debris under the keys preventing me from typing correctly as there is several keys that will...
Hi
if you click on this link www.asus.com go to support/downloads have a look there for the manual and download it
save it to your desktop or documents or even a pen drive for future use
you will need adobe reader installed to be able to read the manual
good luck
Feb 12, 2011 | ASUS Computers & Internet
The games will play for a little bit then they will freeze
if you are good with repairing things try this it worked for my 8 year old ps2 you will need a phillips head screw driver and some rubbing alcohol and q tips 1 pull off rubber feet on bottom re move six screws you will have to rip or cut do not open sticker care fully open case watch out for ribbon cable going to power reset button 2 open top of cd player part carefully re move cdtray can be tricky may have more screws 3 carefully wash lens with q-tip and alcohol then dry with a dry q-tip put back together wait about 15 minutes then plug er in try it out if this didnt work you have a bigger problem good luck
Nov 09, 2008 | Sony PlayStation 2 (PS2) Console
Replace CD-Rom Drive
solution: open front blue magnetic case door, look on either side of the power button, there are finger holes in the other blue cover.
lift out from bottom to top. this cover comes off, not the whole
case. inside find tabs next to cd drive, squeeze and pull out. note: the side sliders were they come out, they will come off the
cd drive when removed. it is easier to replace the top drive by removing the bottom drive, put in the top half way, then put bottom back in half way and slide them in together.
voice of experience. hope this helps
Jan 12, 2008 | Compaq Presario 5000 PC Desktop
Ps2 disk tray wont open, power light is on, eject light is off
if the ribbon cable that goes to the lens came out its gota go back it. has a plastic tab on the top that lifts up and down to lock it in place....
If its the eject/reset button the ribbon might not be in all the way
Dec 30, 2007 | Sony PlayStation 2 (PS2) Console
Sony PS2
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact [email protected]
Nov 07, 2007 | Sony PlayStation 2 (PS2) Console
PS2 Wont Play
Oct 30, 2007 | Sony PlayStation 2 (PS2) Console
Playstation..2
Hi Sammy,
You have a connection problem in the Reset Eject circuit.
  7. Check to be sure the ribbon cable coming from the reset/eject cable is fully inserted in the second connector from the front.
If this is not the case, you may want to check out www.playstationclinic.com . This could be a circuit problem and may need technical knowledge to gain repair.
Playstation 2 doesnt work
You are posted in the Big PS2 section, so I hope you got a Big PS2, not a slim. If you do have a slim, I think your motherboard is shot. If you do have the big PS2, you need to open th case up and Disassemble it to find out whats wrong.  Your probably have a SCPH-50001 and when you dropped it some of the plastic inside broke.
You need to remove the 8 screws on the bottom, which are hidden by square screw covers. You can pop the screw covers up with a knife blade.  Remove the Warranty label on the cases seam next to where the power cable hooks in. Lift the case from the back slightly and pull it forward just enough to clear the CD drawer. Then roll the over cover counter clockwise being carfeul not pull reset/eject button cable loose. In this motion lay the case cover to the right side upside down.
Now remove the little screws holding the cd Drive cover on.  Yo may ned to use a screwdriver to put in the rectangle holes and pry outward to release the catch at the back of the CD drive cover.  See if you see any damage and write back a comment here . Hope this helps.
I can fix it for a reasonable price for you if you're in the USA.  www.playstationclinic.com
Oct 21, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
88 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
