Question about Kenwood KM800 Major Classic Stand Mixer
Gearbox input toothed cog
Hi
I have a chef 901. The toothed nylon cog at the input to the gearbox has two rubber grommets that connect it to the metal cross piece and thence to the gearbox. One of the grommets has dissolved (god knows how!). How do I replace it!
  • 515 Answers
I don´t think you can get a new one, you have to replace the gearbox on the machine.
Posted on Jul 11, 2008
Tip
GEARBOX DRIPPIN OIL KENWOOD CHEF
IF YOUR GEARBOX IS DRIPPING OIL TRY CHANGING THE GREASE INSIDE WITH SUPERLUPE FOODSAFE GREASE.AS YOUR OLD GRESE HAS PROBABLY BROKE DOWN AND LIQUIFIES. ALSO CHANGE OR WASH AND DRY THE FELT COVER UNDER GEARBOX.
**** AT KENWOODCHEFUSEDMIXERSANDSPARES.
07507400101
on Jan 05, 2010 | Food Mixers
Hi, I'm from Malaysia.I have a Kenwood Chef model A701A.While creaming cheese the power whisk does not rotate.Could you please help to overcome this problem.thank you.
Hi from the Philippines and welcome to FixYa, I am Kelly
Is it just the power whisk or all attachments that do not rotate? On the A701A there is a clutch and spring fitted to the gearbox. (Spring loaded clutch) There is a pin in the cover that actuates the clutch. If the pin is broken or come out of the cover then the front of the machine will not work. (you may have to have someone fabricate a new pin!) If the clutch spring has broken you will experience the symptom you described also.
There is also a belt from the motor to the gearbox and the belt may have broken or come off.
The belt can be found on Ebay here:
http://cgi.ebay.com.sg/KENWOOD-CHEF-MAJOR-GENUINE-TOOTHED-RUBBER-BELT-197944-/200565225066?pt=UK_Home_Garden_Kitchen_Mixers&hash=item2eb29e766a
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Kenwood Food Mixers
The problem's in a Kenwood Chef food mixer. Model is Chef A703C which I imagine will date back to the 1980's or 90's Problem # 1) The bearing on the top of motor is sloppy. It howls when operating the...
Try Ebay for parts, and the links below, they sell parts and service machines.
http://www.kenwoodchefusedmixersandspares.co.uk/
http://kenwoodchefrestore.co.uk/Service.htm
Mar 11, 2010 | Kenwood KM300 Chef Stand Mixer
Mixer will not turn on.
Please what model of Kenwood you have ?
if is 901 press the green boton. inside when you up the head.
if with that not working. is necessary check the motor and change some components .
regards
Kenwood Chef Restore
Dec 28, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Kenwood chef A901, not working
Found a kit on ebay for 9.99 which fixes the speed cntrol problem on 901 chefs do a search for kenwood motor repair comes with instructions you would need to be ok with a soldering iron
Dec 14, 2008 | Kenwood KM800 Major Classic Stand Mixer
There was a smell of burning, i.e. very hot wiring insulatiuon (?) on old Kenwood Chef Model 901. Could it be the motor or some other component, and can I repair it? If it is due to overloading due to...
Hi sometimes, its not the motor, maybe its the speed control, in this model same A701 its centrifugal system, if the capacitor or resistor not working fine, give this smell . you must give your Kenwood for repair or check
Aug 16, 2008 | Kenwood KM300 Chef Stand Mixer
I have attachments (Mincer and pasta maker)for a Kenwood Chef 901 E that fir onto the front. However these attachments don't seem to fit onto a Kenwood Chef 701 A - the hole at the front seems just a...
Hi ...
all Attachment for models A700D. A701 / A , A702, A703
NOT fit in models A900 ahead
anyway, the front of kenwood A900, and KM series its same, you can fit, but not of the models A700/701/702/703C
in http://www.kenwoodchefrestore.co.uk
you can see the compatibility of attachments
Regards
Aug 06, 2008 | Kenwood KM300 Chef Stand Mixer
Item: kenwood chef km201 Problem: Leaking grease from mixer shaft
How old is the machine?
The leaking comes from the lower gearbox assembly, ther are two kind of gearbox. There are two kind of vertical drive shaft, 14mm and 12,7mm that goes through the gearbox.
You can try to replace the grease, make sure that is vegetable grease.
May 02, 2008 | Kenwood KM300 Chef Stand Mixer
Kenwood chef.mixmaster
Try to replace the grease in the gearbox, make sure to use vegetable grease.
Nov 03, 2007 | Kenwood KM300 Chef Stand Mixer
Kenwood KM800 Major Classic Stand Mixer Logo
257 people viewed this question
Top Kenwood Food Mixers Experts
jason
Oscar Netto
Oscar Netto
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
