I had been able to use my canon lide20 scanner with windows vista for over 10 months. Then it started giving me the cannot find twain scource and toolbox - reconnect scanner error. After email communication with canon, I tried to reinstall the drivers but the installation process does not start after the files are extracted. Has anybody faced a similar issue and have a solution?
Some scanners, you have to select the source Twain source) before you do the scanning. Scanning sources could be listed as: scanner, printer,camera etc. So choose scanner and you should find the name of the scanner listed there. After doing this step, go ahead and do the scan. I hope this will work for you. Best of luck. luciana44
I tried everything to solve the problem of "cannot find twain source".. uninstalled,reinstalled, tried canon downloads,bought driiver repair software, everything. never did find a solution ,but would not give up coz the damn thing used to work and still does if you test through control panel. i now use the scanner by opening windows publisher, insert picture,insert from scanner, then save as jpeg in pictures.dont know why it works but it does and i can now continue using my scanner.hope it helps somebody
Have you tried deleting the scanner from add/remove hardware under control panel? If not, try disconnecting it from the computer, then try deleting it, then retry the install one more time.
Was this helpful?
Yes
No
Popular Solutions for Canon CanoScan LiDE 30 Flatbed
hi i hav one lide 20 model scanner how can i install it if u provide me it's setup , it s very...
(More)
hi i hav one lide 20 model scanner how can i install it if u provide me it's setup , it s very helpfull for me
Error message on Canon scanner -there is a twain error, device might not be connected. I am using...
(More)
Error message on Canon scanner -there is a twain error, device might not be connected. I am using Windows 7 Home Premium recently upgraded from Vista Home Premium. What do I need to do to be able to use scanner LiDE30/N1240U? Thanks
I plug in my cannon lide 20 scanner and it begins scanning immediately and continues to go even when...
(More)
I plug in my cannon lide 20 scanner and it begins scanning immediately and continues to go even when it reaches the end of the flatbed so I have to unplug it!
